  • July 12, 2025, 03:00:33 PM
Author Topic: auto clear...  (Read 928 times)
Offline Bootlegger
auto clear...
« on: February 01, 2012, 08:22:51 AM »
 y1   I posted this on the open forum also, a frien of mine made me a power panel and I want to keep it clean.
  Can I brush auto clear on it, if not what should I use, and why?
  Thanks a lot, Gil :!
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: auto clear...
« Reply #1 on: February 01, 2012, 08:31:11 AM »
I answered you on the Open forum. y1
Offline Paul Wood
Re: auto clear...
« Reply #2 on: February 01, 2012, 04:03:47 PM »
Gil,
You can brush it on, but it is pretty expensive stuff.  Also, you'll have to be aware of the working time to complete the project before it starts to catalyze.  I would suggest using something like Minnwax polyurethane or an equivalent.  Don't use the water based clears (not fuel resistant), but the solvent based products are good for flight boxes, etc.
Offline Bootlegger
Re: auto clear...
« Reply #3 on: February 02, 2012, 04:35:30 AM »
 y1   Doc and Paul, I sure do thank y'all for the help, put a coat of auto clear on it yesterday, and another today.
  Paul I already had it in house, but will remember the poly urethane trick.
  Again thanks, Gil #^
Gil Causey
AMA# 6964
Re: auto clear...
« Reply #4 on: February 02, 2012, 08:51:26 AM »
Now give it time to cure.   As with almost any finish there is a cure to touch time and a cure to use time.    H^^
