  • June 17, 2025, 03:59:37 PM
Author Topic: How many coats of clear  (Read 3277 times)
Offline rich gorrill
« on: April 22, 2016, 02:37:07 PM »
Hi all, finished brush painting new plane, four coats of Sig dope. My question is how many coats of clear should I apply over the color using a Preval spray unit. I know to thin it 50/50.  I only painted the fuselage and tail feathers, the wing is ultracote.
T.I.A.
Rich
Re: How many coats of clear
« Reply #1 on: April 22, 2016, 02:47:14 PM »
Rich,
What clear are you spraying?
Charles
« Reply #2 on: April 22, 2016, 04:59:32 PM »
Sig.
« Reply #3 on: April 22, 2016, 05:38:39 PM »
Sig clear dope.
Some say it's fuel proof and others say they have had issues.
Do you have a photo of your model?
Charles
« Reply #4 on: April 22, 2016, 09:23:45 PM »
at 50/50, 5 or 6 coats.
« Reply #5 on: April 23, 2016, 03:55:16 AM »
Thanks Randy.
« Reply #6 on: April 23, 2016, 10:50:09 AM »
I my self quit trying to spray clear dope.   I usually brush on 8 coats.
« Reply #7 on: April 23, 2016, 11:17:34 AM »
Doc, I wasn't very clear on my first post. I brushed on 5 coats of clear followed by 4 coats of color. I now want to spray on final coats of clear to prevent the color from being brush dragged. All Sig.
Rich
« Reply #8 on: April 24, 2016, 12:17:19 PM »
This will depend on brand of dope and if you intend to wet sand and rub it out.  I've found Certified non- tautening clear has a lot more filler in it and doesn't take as much- but be careful or it will get heavy faster.  I have only an airbrush which I use for color.  Then I spray on two coats- has to be thinned about 70-80% to airbrush to lock it down.  Then I brush on two 50/50 coats,  thinned some with retarder.  After three weeks it's hard enough for a good sanding/polishing.  If I weren't going to rub it I'd just do one coat.  Two or three with other brands.  One coat Certified = two or three other brands,  especially Sig Lite Coat although it's a great product.  You'll just put more coats.
« Last Edit: April 24, 2016, 12:57:16 PM by Dave_Trible »
