  • June 13, 2025, 05:54:37 AM
Author Topic: Polytone paint  (Read 2855 times)
Offline Mike Griffin
Polytone paint
« on: February 10, 2016, 09:26:44 AM »
Has anyone tried this product?
http://www.stits.com/store/poly_tone_qts.html
Thank you
Offline Richard Logston
Re: Polytone paint
« Reply #1 on: February 10, 2016, 05:11:49 PM »
Yep, used it on my Starduster One. Like it allot. Still have some in storage but have not used in on models. I think it is fuel resisent. Need to try it some time. Logair358430
Re: Polytone paint
« Reply #2 on: February 10, 2016, 07:22:31 PM »
Hi Richard, I called Stits and talked to them for quite a while.  They do a big business with the modeling community .  I am going to try it.
Re: Polytone paint
« Reply #3 on: February 12, 2016, 04:02:20 PM »
Mike, Give us a report when you try it. Richard
Offline Jim Svitko
Re: Polytone paint
« Reply #4 on: March 04, 2016, 03:09:16 PM »
I called the Poly Fiber people to ask them about the Poly Tone.  The employee I talked to said that the one-part Poly Tone has limited chemical resistance.  When I told him that I wanted to use it on model aircraft that use methanol/nitro fuels he advised me not to do it.  He seemed to be knowledgeable about dope and other finishing methods and he did not think any of the one-part finishing methods would produce the desired fuel resistance.  He claimed that even gasoline (av gas) would attack the Poly Tone to some degree if not washed off quickly.
The two-part systems from Poly Fiber are the products he said would provide the chemical resistance if you wanted to go thru the added hassle of using these types of products.
I suppose one way to find out for sure is buy some and do your own tests.
Re: Polytone paint
« Reply #5 on: March 04, 2016, 05:39:08 PM »
Well, you might use this as a base coat then use a two 2 part clear on top.
