Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 13, 2025, 03:55:05 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Building Tips and technical articles.
Paint and finishing
(Moderator:
RC Storick
another question about film...
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: another question about film... (Read 858 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
on:
August 16, 2012, 07:06:57 AM »
Guy's I am gonna use film covering for the first time and I'm thinking about S L C, any suggestions?
I'm gonna use it on a foam wing that has the L/E, T/E and center section balsa covered, so will the heat gun cause problems melting the foam?
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
ray copeland
25 supporter
Trade Count:
0
Captain
Re: another question about film...
Reply #1 on:
August 16, 2012, 07:20:56 AM »
Yes, a heat gun held too close for too long will definitley melt the foam. I have done this before! It can be done just be very careful, usually a covering iron on low to med heat is plenty to adhere,tighten or iron out wrinkles.
Logged
Ray from Greensboro, North Carolina , six laps inverted so far with my hand held vertically!!! (forgot to mention, none level!) AMA# 902150
john e. holliday
25 supporter
Trade Count:
0
Admiral
Reply #2 on:
August 16, 2012, 08:34:17 AM »
If using the SLC, read the instructions closely and then go back and reread. I use a Monokote type iron to put the edges down. Also I wipe the edges down with alcohol that the next peice will go over. Once all edges are down, I then use the hot air gun. Keep it moving so holes don't suddenly appear. If they do its and easy fix using the scrap peices. Make the patches oval or oblong.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Paint and finishing
(Moderator:
RC Storick
