  • July 14, 2025, 12:51:38 PM
Author Topic: Airless Sprayers  (Read 1782 times)
Offline Dick Pacini
Airless Sprayers
« on: February 01, 2012, 05:16:26 PM »
Will airless sprayers work with dope?
AMA 62221
Re: Airless Sprayers
« Reply #1 on: February 01, 2012, 05:20:19 PM »
I tried an airless sprayer with lacquer, ONCE...........
BIG Bear
RNMM/AMM
Offline Russell Shaffer
« Reply #2 on: February 01, 2012, 10:16:43 PM »
They put out a lot of paint really fast.  There are some light duty models for spraying stain and other such thin products, so yes, it will spray dope.  But, there will be a lot of it all at once, just right for spraying your deck.
Russell Shaffer
Klamath Falls, Oregon
« Reply #3 on: February 02, 2012, 12:07:15 AM »
I would also have some concern spraying a volotile material such as dope since most of the pumps and motors are designed for water based materials. although commercial rigs use an external pump so they may be ok, but that would be a bit of overkill,,
I dont think that you could get dope to spray in any manner acceptable without a lot of experimentation regardless so I think its a bad idea, brushing would be better in the long run, ( and I am a spray guy so keep that in mind)
Offline bob branch
« Reply #4 on: August 10, 2012, 08:26:05 AM »
Airless sprayers give a much different pattern than our normal guns. A normal gun shoots a pattern that thins out at the edges. This lets us blend in the passes and get a level coat. An airless gun does not do this. It shoots an even coat of paint from one edge to the other. This results in layering at every pass. It means a lot of sanding to get a level surface or your paint blend will have to be perfect so it levels quickly and very well before the coat closes. ie, you ain't gonna make it.  What airless does really well is shoot really heavy paints. I use it on boat bottom paint where the paint is quite literally 50 to 75% solids... like copper solids. Its like mud compared to what you would try to shoot thru a regular gun. To get a racing quality finish its then wetsanded (yes, over your head... I hate painting boats!).  Where you have a surface with laps like the side of a house or on a deck it works out better because you have edges to shoot at. But shooting it on a horizontal surface is a pain. Without the feathering edge it gets thinner the further the surface is from the gun.
Also the comment about it putting on a lot of paint is very right. You would not get a light finish out of one of these type guns. But they are point and shoot. So not a lot to learn.
bob branch
Offline MarcusCordeiro
« Reply #5 on: August 10, 2012, 08:57:19 AM »
I wouldn't give them a go either.
A friend just used one to spray the paint and I think just like the rest of the people.
The model got overweighted, in my opinion.
And it really leaves that orange peel finish.  n1
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline bob branch
« Reply #6 on: August 10, 2012, 09:52:36 AM »
Marcus
That orange peel comes from the force the paint is ejected at. NEVER put your finger in front of the orifice of an airless spray gun. It will shoot thru it.
bob branch
« Reply #7 on: August 10, 2012, 10:47:53 AM »
Marcus
bob branch
Thanks Bob
That's great advice. Tell my friend about it.
Aces High!
