  • June 16, 2025, 04:25:44 PM
Author Topic: Panel lines  (Read 1477 times)
Offline david beazley
Panel lines
« on: November 11, 2012, 06:18:49 AM »
Is there a primer in panel lines?  I have searched threads on them but still have questions.  How does one lay them out? Pencil then ink?  How do you deal with the inevitable screw ups?  Can the ink be removed and reapplied without affecting the dope finish?  I am probably guilding the lilly, but I'm building a Brodak profile P-51B and want to attempt panel lines. I am planning to do an Excaliber III scheme that's hanging in the NASM.
http://airandspace.si.edu/collections/artifact.cfm?id=A19530088000
I also am trying to figure out whether to use paint masks or vinyl for lettering and canopy outlines. This is not planning on being a 20 point finish, but I try to push myself on each new build.
AMA # 2817
Offline MarcusCordeiro
Re: Panel lines
« Reply #1 on: November 11, 2012, 09:18:30 AM »
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
