  • June 13, 2025, 10:41:03 PM
Author Topic: Brodak dope  (Read 12565 times)
Offline James Mills
Brodak dope
« on: September 01, 2008, 05:30:40 PM »
Is there another thinner you can substitue for Brodak dope (like with SIG)?
James
AMA 491167
Re: Brodak dope
« Reply #1 on: September 01, 2008, 07:26:37 PM »
James,
The big thing with thinners is to use the same thing from the wood up. I've had more problems from changing thinners than almost anything else. Brodak dope is made by Randolph's, so I imagine that Randolph thinner would work.
Re: Brodak dope
« Reply #2 on: September 01, 2008, 09:11:11 PM »
Randolph thinner is what I've used for two planes in a row now. Both have Sig nitrate base, Brodak color, and Randolph clear. No compatability problem. Just don't use the rattle can primers like I did. That DID cause a problem.
« Last Edit: September 02, 2008, 01:04:07 AM by Clint Ormosen »
Offline Mike Scholtes
Re: Brodak dope
« Reply #3 on: September 01, 2008, 09:12:36 PM »
Check your other thread on Stuka for more answers.
