  • August 04, 2025, 04:12:41 AM
Author Topic: Krylon vs Rust-o-leum, Sharp edge!  (Read 2798 times)
« on: October 28, 2015, 07:09:36 AM »
I've been using all aerosol can paints in finishing my most recent models. I used Krylon exclusivly on the Flite Streak and the P-40.
I had absolutely no issues with paint not sticking when I removed all masking including fine line blue tape.
So, Krylon paint in aerosol cans, did get the job done and done quite well.
Rust-o-leum. I have absolutely no experience with this Brand.
My interest is, anyone having issues with Rust-o-leum when the masking is removed, especially fine line tapes used for edges?
Does the paint stick?
I hate to change a winning game, but there's a color I like with Rust-o-leum that I cannot find with Krylon.
Thanks in advance.
Charles
Offline Ken Burdick
Re: Krylon vs Rust-o-leum, Sharp edge!
« Reply #1 on: October 28, 2015, 10:12:11 AM »
I've had good luck with Rusty paint with one exception. It really needs to cure. If not, the solvent in the 2nd coat will bubble the first coat. It applies well, seems to stick to what I put it on. (silk/nitrate dope) bare wood with primer etc.
k
Offline dennis lipsett
« Reply #2 on: October 28, 2015, 10:51:49 AM »
Unless Krylon has changed it's formula it is not fuel resistant.
Dennis
« Reply #3 on: October 28, 2015, 10:58:08 AM »
Dennis
Ken,
Thanks!
Dennis,
I apply clear over colors, so being fuel proof isn't an issue.
Charles
Offline Paul Wood
« Reply #4 on: October 28, 2015, 03:23:14 PM »
Before I switched to Dupli-Color lacquer, I used Rustoleum a lot. Never had a problem using fine line tape, but if you don't let it cure for at least a week, it is still soft enough to leave an impression from the tape. The edge pulls clean and I never had a problem with paint lifting.  It takes forever to paint multiple colors, but I always had good results. I even had good results painting over plastic film if I lightly scuffed it and applied a fine coat of primer.
Offline Ken Burdick
« Reply #5 on: October 28, 2015, 03:42:24 PM »
yah....what he said.
I used a minwax clear poly-u for my top coat. They sell a crystal clear (Rustoleum) but it's not fuel proof.
Rattle-can
« Reply #6 on: October 28, 2015, 03:43:48 PM »
For what I have happening with this model, it would be easier to spray the darker color first followed by white.
I should, and possibly will, do a test to see how white covers?
How does white cover?
Charles
« Reply #7 on: October 28, 2015, 03:49:14 PM »
Charles
white is always poor coverage, its a function of the pigment not the particular paint product,, some whites may ,, MAY cover better,,
being a painter,as a painter you should know Charles that putting a light color over a dark color is always a crap shoot
Offline Ken Burdick
« Reply #8 on: October 28, 2015, 04:42:01 PM »
as white goes, it covers pretty well
« Reply #9 on: October 28, 2015, 05:03:46 PM »
Working with auto paints, you could dust a bit of white primer.
I have absolutely no experience with aerosol rust-o-leum.
My first experience with aerosol cans and using them to paint a model was the Flite Streak.
I was happy with the results. Aerosol cans, go figure.
Krylon doesn't offer the color.
Charles
« Reply #10 on: October 28, 2015, 05:05:38 PM »
Ken,
That's an interesting model.
Got other photos, closer shots?
Charles
