Building Tips and technical articles. => Paint and finishing => Topic started by: David_Ruff on December 25, 2023, 07:52:29 AM
Wondering if 2K Max would cause a problem with Ultracote polyester iron on.
Planning to mask off anything with the Ultracote.
I am planning to use 2K over Krylon on the fuselage of the Skyray 35.
I will use wood lacquer on the balsa fuselage, then Krylon.
Also I use glass resin on the engine mount area to insure it is fuel proof.
I have done it and it’s not a problem just scuffing the ultra cote with scotch pad
