  • July 20, 2025, 09:59:59 AM
Author Topic: 2k clear on Rusto?  (Read 1890 times)
Offline James Holford
2k clear on Rusto?
« on: July 24, 2018, 06:23:00 AM »
Has anyone sprayed 2k rattlcan clear over Rustoleum with good results?
 If so, what was your process?
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline big ron
Re: 2k clear on Rusto?
« Reply #1 on: July 24, 2018, 07:04:38 AM »
you can try it on the cardinal fuselage that is white rustoleum gloss protective enamel
John Blanchard
Brusly, Louisiana
 AMA 1054488
« Reply #2 on: July 24, 2018, 08:42:48 AM »
Sounds good
Jamie Holford
Lafayette, La
AMA #1126767
Online Dennis Toth
« Reply #3 on: November 13, 2018, 11:03:13 AM »
Jim,
It should work fine if the Rustoeum is fully cured out, about two weeks at normal house temperature (72F). You should do a light sanding of the surface and then a cleaning with degreaser  before appling the 2K.
Best,   DennisT
