Building Tips and technical articles. => Paint and finishing => Topic started by: James Holford on July 24, 2018, 06:23:00 AM
Has anyone sprayed 2k rattlcan clear over Rustoleum with good results?
If so, what was your process?
you can try it on the cardinal fuselage that is white rustoleum gloss protective enamel
Sounds good
Jim,
It should work fine if the Rustoeum is fully cured out, about two weeks at normal house temperature (72F). You should do a light sanding of the surface and then a cleaning with degreaser before appling the 2K.
Best, DennisT
