General control line discussion => Open Forum => Topic started by: Dennis Toth on June 30, 2021, 08:01:45 AM
Does anyone know if Zinger is still making there wood prop line? I have gone to their website and they show all the props but there is no way to order them. I tried the email and it gets kick back. I like the Zingers as a great kit prop as there is lots of material to reshape.
Best, DennisT
Zinger is no longer in business. I can't verify this but I heard family members did not want to continue after the death of the founder of the company.
You might try the MECOA website. At one time, they still had a bunch of Zingers but it has been a long time since I looked at that to see what was available.
You are right about the Zingers being a pretty good prop kit. In stock form, they are terrible. But, when reworked, they can be made to perform quite well, if you know what you are doing. The issue here is time. Is it worth the effort? I say it is if this is the only way to get what you want.
Yes, Zingalli ( or whatever his last name was ) closed the business in order to retire and then was killed in an airplane crash afterwards. Lots of them out there still, so you may put out a want add for the sizes that you need. I only use them for the initial flights on new airplanes in case I have a problem so I won't break a good prop, and then when the serious trimming starts I put on something better.
