  • June 26, 2025, 03:08:43 PM
Author Topic: Thrust to weight ratios and wing loadings  (Read 1532 times)
Offline Michael O
    • Propellerhead
« on: April 13, 2007, 06:58:15 AM »
I am a Swedish retread and new to this forum. I grew up with 1/2A C/L aircraft, but most of my modelling career have been spent flying R/C aircraft. Because there seem to be an almost infinite amount of C/L wisdom available in this forum I have a couple of questions:
What is the typical thrust-to-weight ratio of a stunt aircraft (old time, classic and new)?
Also, is there some optimum wing loading for C/L aircraft? My reason for asking is that I have seen some very light Noblers that to me appeared to perform worse than heavier aircraft of the same type.
I am fully aware of the limited usefulness of the concept of static thrust-to-weight ratio, but I really would like to know what I should be aiming for.
Michael O  H^^
Re: Thrust to weight ratios and wing loadings
« Reply #1 on: April 13, 2007, 07:07:07 AM »
Michael O  H^^
Hi Michael,
Many people do quote certain wing loading ranges in relation to different designs.  11oz. to 13 oz. seem to be the range I hear a lot.
The note about the Nobler is somewhat baffleing to me, but I don't disagree.  Baffleing because Mr. Gieseke has always built his Noblers very light!  ??? ???
Bill <><
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: April 13, 2007, 07:25:32 AM »
Have been a bunch of discussions on the ideal weight for a Nobler and the general conclusions as far as I understand things is with a 1-1 flap ratio it needs to be a little on the heavy side to preform properly. I never have a problem building too light I always seem to end up around 12 ounces per... Was speaking to an expert from Dallas and he told me he always builds for a target of around 13 ounces because the heaver wing loading seems to preform better in wind. Bill's 11-13 seems to be the most often quoted..
Not sure anyone can answer your thrust question, most of us have heard the number means nothing so haven bothered to measure it.
