Hi Mike, I agree with all suggestions made heretofore! Back in the day I must have had 4 or more Yaks from Sterling and now there's another one just begging to be finished in my new building room! However there is two P-51's from Sterling which I have been flying, one since 1974 and the other since 1992! One is powered by an FP .20 the other by an FP .25! Both are flapped and both never flew this well back in the day with Fox 35's and K&B's of all varieties! I must also say that both have had LA .25's mounted and that engine flew every bit as well as either of the others did!
What the modern engines really accomplished was to make the wing finall work as it should have all along! Others prefer 9 X 5's (MAS) props but I enjoy the (9 X 4) APC prop for these engines, both LA and FP. AS to tank size the 2.5 to 3 ounce varieties are best if you don't want to still flying when everybody else goes home! In addition I prefer muffler pressure and 10-11-11 formula fuel.
My P-51 has been rendered in "B" foremat and was the basis for my first sortie into Mono Coat covering. I did the entire plane including the fuselage and hinges in the then "new" flat colors; Olive Drab top and Polar Gray bottom! The MonoCoat hinges result in a completely sealed hinge line for all surfaces, going all across the full surface, which makes the controls much more positive and effective! These a re truly fun projects and my just score you a prize or two depending on what skill class you fly in if you are a competitive type o/w they are at the top of the chart for pounds of fun derived for penny of capital invested!
Tally Ho,
Phil Spillman
T
