  • June 23, 2025, 07:55:45 PM
Author Topic: Need large dia. tubing for my chicken stick  (Read 1113 times)
« on: December 20, 2017, 06:57:15 AM »
The soft tubing (maybe latex??) on my chicken stick is wore out.  Where do you guys buy it?
Offline Dane Martin
  • heli pilot BHOR
Re: Need large dia. tubing for my chicken stick
« Reply #1 on: December 20, 2017, 07:25:02 AM »
I get blue silicone "water hose" from All Hose Inc or House of Hose here in Las Vegas. Its the high temp stuff for coolant lines. Its soft and flexible. I've been using mine for a few years now.
Offline Garf
    • Hangar Flying
« Reply #2 on: December 20, 2017, 08:56:33 AM »
I used air brake line from busses. Plastic, medium hard, red, soft enough to not break props, hard enough to not need a handle. 3/4" diameter. Available from truck repair shops.
« Reply #3 on: December 20, 2017, 09:17:22 AM »
McMaster-Carr has all sorts and sizes of tubing.  I'm sure you can find what you want there.  They give very good service and are easy to deal with.
https://www.mcmaster.com/#standard-plastic-and-rubber-tubing/=1armze2
« Reply #4 on: December 20, 2017, 03:02:50 PM »
I get it from trains. Oops, forget I said that.
Offline Guy Markham
« Reply #5 on: December 20, 2017, 04:10:22 PM »
Go buy this one and you will have no worries Mate!   www.rollingchickenstick.com  y1
You only have to floss the teeth you want to keep!
Offline Norm Furutani
« Reply #6 on: December 20, 2017, 04:20:15 PM »
I see flexible vinyl tubing in the big box plumbing department. Usually by the foot. Should be OK.
Offline Russell Shaffer
« Reply #7 on: December 20, 2017, 08:11:16 PM »
Bicycle hand grips cut in half.
Russell Shaffer
Klamath Falls, Oregon
Offline pmackenzie
  • Pat MacKenzie
« Reply #8 on: December 23, 2017, 10:08:37 AM »
Yikes! ~^
MAAC 8177
