  • June 19, 2025, 05:45:19 PM
Author Topic: Confusing readings on hangar 9 tachometer?  (Read 1560 times)
Offline Matt Curtis
« on: August 18, 2024, 11:27:55 AM »
I have the newest version of the hangar 9 tachometer and I get a reading of 287 with my k&b .28 with a 10/4 prop. Bottom numbers are searching with I think 430 and 418? Cannot figure this out? Why does it have all these different readings? I setit for 2 blade prop. I don't remember the older versions working like this. They would just show 1 reading and there was no trying to figure it out.
Re: Confusing readings on hangar 9 tachometer?
« Reply #1 on: August 18, 2024, 11:42:53 AM »
This one? https://www.horizonhobby.com/product/micro-digital-tachometer/HAN156.html
These've been around for decades. I made a push-on tube to shade the lens, and it helps, but it's still a bit touchy to light intensity and direction you point it.
What you described is puzzling. A typical stunt-ish engine reading should be something more like 960 for a launch setting. They wouldn't bother with the 10's digits, because the engine will show more variation than that.  D>K Steve
Offline Colin McRae
  • Are we having fun yet??
« Reply #2 on: August 18, 2024, 04:00:42 PM »
I went thru 3 of these Hangar 9 tachs and all 3 stopped working after a relatively short period of time.
I gave up and am now trying a G.T. Power RC mini tach which is similar to the Hangar 9. After about 6 months now it is working fine and accurate. But longevity, who knows!
