  • July 01, 2025, 05:24:17 PM
Author Topic: Wrist pin pads  (Read 1049 times)
Offline Dwayne Donnelly
Wrist pin pads
« on: June 15, 2022, 06:12:14 AM »
Lost one of the wrist pin pads from a Merco 40, please what material can I use to make another one.
Thanks y1
« Last Edit: June 16, 2022, 05:31:05 AM by Dwayne Donnelly »
Offline Massimo Rimoldi
Re: Wrist pin pads
« Reply #1 on: June 15, 2022, 06:20:09 AM »
Hi.
PTFE (teflon) is ok.
Massimo
Re: Wrist pin pads
« Reply #2 on: June 16, 2022, 08:04:45 PM »
Some K&B engines used Teflon wristpin pads, but IMO, they didn't last terribly long, so keep that in mind and make more than you think you'll ever need. A lot of older engines used brass pads, of course, but I would opt for plastic. There is a graphite impregnated version of Delrin that would be my choice...but I don't remember the name of it. I machined bushings from it, about 40 years ago, and it was nice to machine (Hardinge chucker) and quite slick.
By "graphite", I mean the lubricant type graphite, and not the carbon fiber type graphite. I wish folks wouldn't use the term "graphite" interchangeably with "carbon fiber". Fishing rod makers are the WORST on this.  y1 Steve
Re: Wrist pin pads
« Reply #3 on: June 17, 2022, 12:11:49 PM »
Thanks guys, I forgot I had a couple of old 4 strokes that use them, I was able to reshape one to fit.  ;D
