I use sanding sealer on all wood, that's everything, cap strips etc, about 3 coats, sanding to a smooth finish, then put the silk on with thinner, and the tissue on all wood parts. I only dope the loose silk with shrinking butyrate, until it's tight, then dope everything with non-shrinking butyrate, sanding in-between, sanding sealer doesn't shrink, and sticks well to bare wood.
Cheers
