  • July 11, 2025, 07:13:06 AM
Author Topic: Anyone try this stuff  (Read 1516 times)
Online Paul Taylor
Online Motorman
Re: Anyone try this stuff
« Reply #1 on: May 26, 2015, 03:08:41 PM »
If it'll glue cocobolo and glow in the dark I'm in.
« Reply #2 on: May 26, 2015, 03:21:20 PM »
Uhhh well, it separates easily at 190 degrees F.  I sure wouldn't use it here in Tucson and carry it around in the back of my truck in the summer time!  Come back to the truck and find a lot of sticky airplane pieces on the floor!
 %^@   HB~>
No thanks!
Offline Phil Krankowski
« Reply #3 on: May 26, 2015, 04:53:03 PM »
It is a PVA type glue such as Titebond, Elmers white or wood, and a multitude of other glues.  I have not used it myself, although I have looked at it before.  I am not a luthier.  The linked data sheet spells out the composition pretty well.
The 190F "problem" exists for all PVA type glues.  Incidentally while the glue joint is weakened it regains strength when it cools, if not actually broken. In this case I am nearly positive that "separates easily" means "the wood is much stronger than the glue".
I do not know if some percentage of strength is lost after heating and later cooling, only that the glue will became stronger than the wood I was working with at the time.  I was not using the linked glue. I do not know the brand that was used, but would guess Elmer's wood glue since it was a high school wood shop project.
I was referred to this product previously because of the bottle.  It is supposed to be very nice, but I don't have one of those either.
Phil
« Reply #4 on: May 26, 2015, 04:56:45 PM »
Well, for repairing string instruments, I always use hide glue in granular form.  It must be dissolved in hot water and kept at least 180 deg F.
This is the traditional glue because it can be taken apart later with very hot water.
Offline Ward Van Duzer
« Reply #5 on: May 30, 2015, 10:54:59 AM »
Yes. Been using it for years! Been toting it here for years!
And Randy, I haven't seen many guitars falling apart in Tucson!
W.
Offline Steve Thornton
« Reply #6 on: June 01, 2015, 12:52:41 PM »
http://www.lmii.com/products/finishing/adhesives/lmi-yellow-instrument-glue
I use their LMI Instrument Makers White Glue and I really like it.  It is polyvinyl but "dries glass hard" and it sets up in 15-20 minutes.  My garage is truly hot in the summer (feels like about 250 degrees C) and no glue release related tragedies so far.  I think Will Hinton put me onto it.
"Most of us won't make it out of this world alive."
Steve Thornton
