  • June 14, 2025, 02:17:11 PM
Author Topic: Stunt or combat engines?  (Read 1202 times)
Offline HemiGTX
« on: June 02, 2024, 06:17:55 PM »
I picked up a couple stunt planes that came from an estate.  I suspect that the gentleman who built them never really intended to fly them as they look like they are ready to go, until you take a closer look.  Two of the stunt models have engines that may be more appropriate for combat.
One engine is a Torpedo .35 that has the exhaust stack on the left side.  The other one has a Fox .35X with a two piece square venturi.  It appears to have ball bearings and has a larger crankcase and mounting bolt pattern than a Fox .35 stunt.
Are these more oriented toward combat?
Thank you!
Re: Stunt or combat engines?
« Reply #1 on: June 02, 2024, 06:46:40 PM »
  If the Torpedo is a green head, all the exhausts were on the left side. I don't know if i have ever heard their reasoning for that. If mounted upright or inverted, no problem, but if on a profile with the engine outboard, the exhaust points up and the engine can load up and flood easily.
  The Fox is definitely a combat engine. I have seen this before in old models, where I think the original builder just thought he could use the extra power. In the old days, they really didn't define "power" by what event you were flying.
« Reply #2 on: June 02, 2024, 07:11:52 PM »
Thank you!
I have had both. The Torpedo was used a lot for stunt in the 60's.  Was used a lot on profiles around here for who knows why.  As Dan pointed out, it's easily flooded BUT, I figured out how to put just the right prime through the exhaust and bump start it.  Upright they are OK but still not that great for stunt.  I have used a Fox 36x on a stunt plane, but I don't recommend it.  It wants to run on pressure with a big venturi.  Hard to slow it down and too heavy.  Top line combat motor in its day though.
Offline HemiGTX
« Reply #3 on: June 02, 2024, 07:33:30 PM »
Thank you for the information.  The Fox was mounted inverted and I’ve swapped it out for a .40LA.  The Torpedo is indeed mounted on a profile Stuka Stunter.  It has a tongue muffler, so I could fly it at my field if I can get it running.
