  • June 16, 2024, 02:43:33 PM
Author Topic: WKSI Stunt Contest: John Ashford  (Read 1518 times)
« on: August 20, 2012, 08:50:14 PM »
  Anybody know if John Ashford made it home OK? He was having some car issues I described in another thread, and he was pretty confident that he would be OK, but I just want to be sure. Is he a member of the Tulsa club?
  Thanks in advance,
Offline Allen Brickhaus
  • ACE
Re: WKSI Stunt Contest: John Ashford
« Reply #1 on: August 21, 2012, 05:42:57 AM »
He repaired a bad but new gasket on his automatic transmission due to faulty installation at a Maryland dealer.  Have not heard from him, but hope he is tucked safely in his own bed.
Allen
Offline Elwyn Aud
    • Inferalandings Photo Page
« Reply #2 on: August 21, 2012, 06:26:37 PM »
I'm not sure where John calls home now. He lived in Guthrie, OK for several years but I heard he moved north to Kansas or Missouri a while back. He dropped off the radar for a while following the move.
« Reply #3 on: August 21, 2012, 07:41:16 PM »
John has not signed on here for about 3 months. I sent him a email asking him to check in. Maybe he is checking email.
Tight Lines = Fun Times
« Reply #4 on: August 21, 2012, 09:41:50 PM »
   Hi Paul;
   I hope he does. I really didn't want to leave him stranded and I don't think I did, but I sure would feel better hearing from him. He was traveling alone and had no one with hime to help if needed, and I don't know if he had a phone with him or not. He's an old school shade tree mechanic, and he was thinking along the same lines and I was about his problem, and I wouldn't have left if I had any feeling he was going to be stuck. The dip stick for his tranny wasn't showing any fluid still after he had put in the last quart he had, and I suggested he go straight to the auto parts store (less than a mile) and get at least 6 more quarts and keep adding there until it got to at least the low mark on the dip stick. He would have had no idea how much was in the transmission, and with a bad leak at the pan, and pump pressure behind it, he could have lost quite a bit. Wouldn't have been very good for him to drive very far with it that low. He said he went to the catfish and frog leg place with everyone Saturday night, and it was shifting fine then, and it got him to the field Sunday morning, and still wasn't leaking. Been a long time since I've worked in the automotive business, but I'm guessing that it should have held anywhere between 8 to 12 quarts of fluid. Hope he checks in soon.
   Dan
« Reply #5 on: August 22, 2012, 05:43:06 AM »
Well I too hope he made it home okay.  Transmissions are a peice of equipment I vowed I would never work on, especially automatic ones.  Old Ford Mini Van got me to Ames Iowa and back one year with no signs of trouble.   Couple of days later after replacing some bad tires was on the way home and it would not go from a stop light.  Shifted to low gear and got it home.   Reverse and low was all it had.  Still had plenty of fluid in the case according to the stick.  The old Chevy truck started whinning on me when I had it.  Replalced filter on it.  Maybe some one can google John and find his number.
Offline Curtis Shipp
  • AMA 753063 / Advanced Stunt Flyer Finally
« Reply #6 on: August 22, 2012, 08:20:52 AM »
John was going by Les Demitt's house and stay with him a few days. If anybody knows him you can call. Maybe he is still there.
Life is to short to be sour.
« Reply #7 on: August 24, 2012, 05:14:47 PM »
    Just bumping this up in case someone sees it.
  Dan
« Reply #8 on: September 04, 2012, 08:33:24 PM »
John made it back.
If you look in the thread of the dallas contest, you can see him in the background of joe Gilberts flight.
« Reply #9 on: September 05, 2012, 01:14:47 AM »
  OK , cool! After not hearing anything from anybody, I took the "no news is good news" tack to this. I think this was the first time I have met John and he's a good guy and glad he made it home OK.
  • ACE
« Reply #10 on: September 05, 2012, 05:53:15 AM »
You are correct in your assumption of John.  Good Dude.
Allen
Offline Sean McEntee
« Reply #11 on: September 05, 2012, 08:36:18 AM »
  Yep he was in Dallas this weekend...very good dude :D
