General control line discussion => Open Forum => Topic started by: George Waters on September 17, 2017, 04:25:25 PM
Does anyone have the McMasterCarr number for the wire to make line clips from? Thankyou George
Hard "Spring-Back wire" (spring temper), not "bend and stay" wire. Anything in the .047", .049", .051" range should be fine.
.051 Hard Stainless Spring Back Wire - #: 8908K56 https://www.mcmaster.com/#8908k56/=17hl5ok
Music wire seems to work just fine, also.
Thanks for the info, Igot safety wire by mistake before. George
I started using line clips made out of music wire, planning on switching to stainless when I started seeing rust. That was four years ago, I'm still waiting. If you fly electric the story may be different -- I suspect that everything in my flight box has at least a thin coating of castor oil on it.
I use 1/16" music wire too. It holds up just fine.
I won't call that a recommendation, just saying it's been working fine for me for a long time..
Rusty
Last Sunday I picked up wire from Jim Lee, Lees Machine Shop. All the wire I got from the hardware store rusted even though it still makes the max pull testy. H^^ H^^
I've used .047 music wire for many years. More than adequate strength for any CL airplane with the double loop end!
I just made a few using the jig borrowed from Ty. I had K&S music wire on hand so tried a couple but I found it difficult to work with. This from a guy who does metal work for a living, so I ordered 100 feet of .049 302/304 Hard Stainless Spring Back Wire from McMaster-Carr. $11.37 plus about $8 shipping.
What a difference! Much easier to bend and get it into the correct shape without a lot of fooling around. Getting 4 clips per foot, they come in at a nickel a piece.
The K&S wire is rated somewhere around 350,000 PSI in tension, the 302/304 hard stainless at 205,000. That works out to a single .049 wire strength at 386 pounds in tension and I figure the actual strength double that at 773 pounds because of the clip configuration.
Does that sound right to all the engineers out there?
LeeMachineShop.com
Then "Ordering" then select "Line Clip Bender". Jim has the wire hidden there! :-)
Considering that you're flying on .015" or .018" 7-strand, anything solid of .020" or would be plenty.
This is based in the "weak link" theory.
One thing about "tensile strength". A line clip can fail by straightening-out, so tensile strength isn't the ultimate goal.
Paul, you might want to bend some clips of .020" wire and use them on your planes, but I wouldn't do it on mine. MAYBE .039", but nothing less....
That's my opinion.
Theory is one thing, but everyday real world use is another.
LeeMachineShop.com
Well, that would have been a lot easier, Jim, since you made Ty's tool in the first place. If I had known you sold the wire, I wouldn't have had to buy 100 feet of it. H^^
