Hey all,
I just started building a Sig Twister. I noticed that one of the flaps is a 1/16 of an inch bigger in chord. Should I:
A. Sand them equal.
B. Mount the bigger one on the inside, or outside for a slight advantage in performance.
I'm kind of confused on this subject. I've read a lot of posts about larger inside panels to compensate for the slower speed of the inside wing, and line weight. But I've also found posts about having a larger outside flap to compensate for the tip weight. Can anyone shed some light on this subject?
TIA,
Gonzo
On the Twister the inboard wing is a little longer than the outboard and therefore the inboard flap is a bit longer than the outboard. Making the outboard flap slightly wider actually makes the area of the two equal or at least approximately equal.
I believe most experienced stunt fliers now aim to make the flaps of equal area on stunters.
A few like myself actually lean toward making the outboard flap slightly larger than the inboard (only about 3-5%). The reason for this is the theory that since we fly in a circular path the airplane is slightly crabbed toward the outside of the airflow and the fuselage has a potential to blank a portion of the flap area close to the fuselage on the outboard side. Just theory but it does seem to work. It also allows for a bit more tip weight to be carried without dropping the wing on corners. The extra tip weight helps on overhead maneuvers, especially in severe wind.
At least that's my story and I'm sticking to it.
I've noticed little tabs growing on the outboard flaps of some folks in the past, that don't support this theory.
These little tabs magically appear during trimming functions on the airplane.
