Uh, what Brett said. I tend to run longer lines than conventional wisdom dictates, perhaps because I tend to build heavy. It lets you go a bit faster for the same lap time, both cutting down on induced drag and giving you more centripetal acceleration. A 34-ounce Ringmaster S1with a 20FP flies nice on 62' handle-to-canopy lines. So, if you're desperate and if the engine power is there to sustain it, at least try going longer on the lines than your buddies think is wise.
So -- make sure the engines are running right and the things are trimmed. I would expect that any one of those should be fit to be at least coaxed through a full pattern, and maybe even be reasonably competitive.
Hunt down Paul Walker's trim articles, and at least go through his first two phases. Getting the right fore-aft CG, tip weight, and leadout position will do a world of good.
