  • August 05, 2025, 01:25:56 AM
Author Topic: Just When You Think You've Seen All The Different Ringmasters  (Read 3423 times)
Offline Robert Zambelli
« on: January 26, 2010, 09:12:33 AM »
OK, these will get your attention.
I built the "Pushmaster" in 1994.  Stock Ringmaster with a Como 40 mounted backwards driving a trailing edge mounted pusher prop. The drive shaft consisted of an aluminum tube supported in a rear mounted ball bearing. Had to launch it quickly because the engine would overheat - no prop blast to cool it. A bit nose heavy but flew well.
Then there's the "Jetmaster" - I don't claim any part of this - built by someone in the Philly Flyers - Banjock , maybe. Not sure if it ever flew.
Comments??????????????????????
Offline Ironbomb
Re: Just When You Think You've Seen All The Different Ringmasters
« Reply #1 on: January 26, 2010, 10:18:45 AM »
Bob, those are just too cool for words. The Jetmaster looks most excellent. I gotta get me one of those engines.
happy bulding, (i see you are)
 ~>  Greg
Beating the crap out of the ground, one airplane at a time
Greg Bossio
AMA 834382
Offline Russell Shaffer
« Reply #2 on: January 26, 2010, 11:43:48 AM »
From what I can see of the jet mounts, if that thing ever fired it would go forward and leave the plane behind.  Interesting concept, though.  I wonder if the glo engine could move it fast enough to start if you could fire the plug somehow.
Russell Shaffer
Klamath Falls, Oregon
Offline Mike Anderson
« Reply #3 on: January 26, 2010, 12:06:14 PM »
Plus, it doesn't look to have any landing gear - I AIN'T handlaunching that thing!   LL~
Mike@   AMA 10086
Central Iowa
Offline Larry Fulwider
« Reply #4 on: January 26, 2010, 12:58:18 PM »
 . . . I built the "Pushmaster" in 1994.  Stock Ringmaster with a Como 40 mounted backwards driving a trailing edge mounted pusher prop. The drive shaft consisted of an aluminum tube supported in a rear mounted ball bearing. . . .
Bob --
Did you ever talk to Banjock about his pusher Ringmaster? He said it was a real education in aerodynamics -- how much performance changes without propwash over the wing. Long take off rolls, for example.
Contrats on the drive shaft success. That is not a trivial engineering feat! For the rest of you, think about it.
       Larry Fulwider
Offline John Cralley
« Reply #5 on: January 26, 2010, 01:27:04 PM »
Bob,
You need to post those photos over on the Brotherhood of the Ring (www.brotherhoodofthering.info). You will definitely generate comments over there!!
John Cralley
AMA 52183
Central Illinois
« Reply #6 on: January 26, 2010, 02:09:22 PM »
Larry - that IS the pusher Ringmaster that Banjock had - I built it for him.   y1 y1
The first takeoff roll was hilarious - lasted 3 minutes! But it never took off.   LL~
I built the plane with a high tailwheel to clear the prop. I didn't think to notice that it sat at a slight NEGATIVE angle of attack. Since a symmetric airfoil needs a slight positive angle, even with full up, it could not rotate and lift off. So, it just ran around on the ground until it ran out of fuel. Lowering the tail and adding slightly larger front wheels cured the problem.
The real comedy was when it crashed. It went in a about 45 degrees, stuck into the ground and the engine just ran for around 20 seconds. Remember, the prop never hit the ground so there was nothing to stop it!  n~ n~
« Reply #8 on: January 27, 2010, 07:17:15 AM »
Hi, Guys - good comments.
Ty, you are correct - no matter what is done to a pig, it's still a pig!!!!!  LL~ LL~ LL~
Russell - that setup was temporary just to get some CG ideas. He had all the proper mounting hardware for the pulse jet. Also, there was a landing gear, not shown in the photo.
The plan was to start the Diesel engine and then fire up the jet. Since the engine would already be running and cooling the jet, startup time was not that critical.
Elwyn - yes, he would definitely have to shorten the rudder.
Oh well, all for fun!!!!!
Offline pat king
    • PDK LLC
« Reply #9 on: January 28, 2010, 07:59:37 AM »
One shouldn't be disparaging of Ringmasters. There are some of we intellectually challenged who think they are great.  y1 You shouldn't hurt our feelings. LL~
Pat
Pat King
Monee, IL
AMA 168941
« Reply #10 on: January 28, 2010, 09:43:11 AM »
Yeah: Some of my best friends fly Ringmasters. y1 LL~ My wife warned me about hanging out with guys that fly Ringmasters, but I didn't listen, and now I have 2 myself.
« Last Edit: January 28, 2010, 11:14:05 AM by Jim Kraft »
Offline Robert McHam
« Reply #11 on: January 28, 2010, 11:48:35 AM »
I think that there is something addictive about the Ringmaster design. Even to those who have not flown one yet. I really can't say what it is or put a finger on it. Personally I have not built one but several of the smaller Ringmasters are on mu "bucket list" including the Baby Ringmaster and Beginner's Ringmaster bipe or possibly a built up wing version like the Baby Ringmaster. I have one of the Estes/Sterling PT Ringmaster 049 kits and it urges me to finish it.
Robert, I just have to ask about the engine start procedure for the "Pushmaster"!.
Robert
Offline Bill Gruby
« Reply #12 on: January 28, 2010, 01:07:40 PM »
 UMMMM  Bob:
  Do you have any idea just how many Ringmaster Varients there are? At last count on the BOTR there were 34 and that was 6 months ago.  LOL  Let's see 207, 307, 546, 576, 547 Bipe, 715 Bipe, +P Foamie, RM 1000, SDR, Pulsemaster. RM Twin, and the Ducted Fan ( in development ) etc. There are more but I don't want ty to think I am in a rut.   LL~ LL~ LL~
  "Billy G"   S?P
Bill Gruby
AMA 94433
MECA 5393-10
« Reply #13 on: January 28, 2010, 01:17:45 PM »
Bill,
Hey, what about mine?   ;D
Offline Bill Gruby
« Reply #14 on: January 28, 2010, 01:23:19 PM »
Bill,
 Sorry Randy it plum slipped my mind. The Ringmaster Delux is georgeous. You can tell em what happened, I don't like to go there. It makes me cringe.  LOL
  "Billy G
Bill Gruby
AMA 94433
MECA 5393-10
Offline Bill Gruby
« Reply #15 on: January 28, 2010, 02:58:01 PM »
 Why you ole snake in the grass. You is a closet "Ringmasterer"  VD~ VD~ LL~ LL~ LL~ VD~ VD~
  "Billy G"   S?P S?P S?P
Bill Gruby
AMA 94433
MECA 5393-10
Offline Terry Bolin
  • Havin' the time of our lives!
« Reply #16 on: January 28, 2010, 08:09:44 PM »
Bill, Were  you building a special Ringmaster ( Maybe a bipe) a while back?
Offline Scott Hartford
« Reply #17 on: January 28, 2010, 09:23:17 PM »
He has a few "special" Ringmasters!  n~ Very special indeed......
Offline Bill Gruby
« Reply #18 on: January 29, 2010, 07:34:21 AM »
 Sure did Terry. It is waiting for the Trim Paint and will be done and flown this season. The big one will also be flown in the spring. The RM 1000 met with terra firma last July and a new one with some changes is underway. Thanks for asking.
  "Billy G"   H^^
Bill Gruby
AMA 94433
MECA 5393-10
