You don't. You can use nitrate UNDER Butyrate but NOT on top. Clear, with a small amount of tint, (thinned dope of the color you intend to finish with) can be used instead. Mainly primer is used to cover every thing so there is an even coat for the colors to go on. No grain or fillers show this way. Some primers also act as a filler. A white primer makes red and yellow brighter than a gray primer, which can make those colors slightly darker in tint.
I agree with Ty, light colors for the primer (I use Rustoleum Car paint primer,in a spray can, light grey, I get it at Wal-Mart, or Home Depot) make the top color brighter. I use mainly nitrate dope to fill the balsa grain, then the spray primer. I have a lot of nitrate sitting around, mainly because I like to build small free flight models. The nitrate does not shrink the structure as much as Butyrate, at least that's what I have been told! In other words, you do not have to use butyrate primer.
