  • July 25, 2025, 06:38:54 PM
Author Topic: Who sells Suprer Tigre knock off n.v.a.?  (Read 1489 times)
Offline frank mccune
« on: September 11, 2020, 02:19:32 PM »
       Hello All:
       A while ago, I spoke to a chap who was selling these nva for $11.95 each.  I think that he may live I Texas.  If you have any information about these, kindly contact me.
       Tia,
        Frank McCune
Re: Who sells Suprer Tigre knock off n.v.a.?
« Reply #1 on: September 11, 2020, 02:36:44 PM »
       Hello All:
       Tia,
        Frank McCune
RSM does  but  i think  they are  more  like  25  dollars  each
Online James Lee
« Reply #2 on: September 11, 2020, 02:39:55 PM »
RSM nva are $11, $ 16, $18 depending on size.
I carry them also
Jim
Lee Machine Shop
Offline Doug Moisuk
« Reply #3 on: September 11, 2020, 03:12:37 PM »
Randy Smith
Doug Moisuk
MAAC 3360L
Offline Craig Beswick
« Reply #4 on: September 11, 2020, 04:16:54 PM »
Hello Frank how are you?
I would be careful of an ebay or, "Off Site", ST
look-alike NVA!
I have had both Randy's  and Jim's and they are excellent.
Craig
AUS 87123
"The Ninja"
Offline Dwayne Donnelly
« Reply #5 on: September 11, 2020, 06:21:19 PM »
I carry them also
Jim
Lee Machine Shop
I have bought from Jim many times, great service,  first class all the way!! y1
« Reply #6 on: September 11, 2020, 11:07:04 PM »
One of the stunt pages in the A M A mag, spoke of drilling both outlet & through, 1.5 m.m. Dia. Passing bit by finger severally along axis to deburr .
Says it neddles better in the ST 46 .
I have had the little O S NVAs in G-15s , you unwind the neddle till it falls out, and theyre still to lean . Had someother do this too, centuries ago .
« Reply #7 on: September 12, 2020, 12:28:39 AM »
Jim is  correct, I have a new in pack one  that says  22.99  price,  IT maybe  an original ??  the  ones below  are off of
 RSM's  website  :
Replacement Needle for all Super Tigre Spray Bars. This needle is 2-1/8 " long so it fits properly through normal fuselages.
Part Number: STNV
RSM Price $3.99
ST 46 Assembly (fits OS40FP). The spray bar fits the ST .46 engine and is medium length. Use in medium sized engine such as the LA.46, or OS .40 FP.
Part Number: STNVA46
RSM Price $15.99
ST 51 Assembly (fits Fox 35). Spray bar fits ST .51 engines and is the shortest spray bar available. Use in smaller carnk cases such as the Fox .35.
Part Number: STNVA
RSM Price $10.99
ST 60 Assembly. The spray bar fits the ST .60 engine and is the longest. Use on larger engines with wide crank cases.
Part Number: STNVA60
RSM Price $17.99
« Reply #8 on: September 13, 2020, 09:38:10 PM »
I have bought and used some of the ST Clone NV/Spraybar units. I think I got them from Stuka Stunt Works, but always wondered who was the distributor/manufacturer of them. One I put in a Magnum XL .25, and I couldn't get it to peak out. I decided that the NV just wouldn't screw in far enough, so I pulled it out and put something else in the .25 and put that one in the .46LA....where it worked perfectly fine, since the .46 burned more fuel. I probably still have some of those, but once I "discovered" how SWEET the Randy Aero/Nelson NV Assy's are, I haven't used anything else. I've also used the K&B Veco units from RSM (in a .25LA with a .272" restrictor)....but really don't like the clicker spring nonsense. I'm sure some like that, but not me.
Was RSM the contractor that had the ST Clones made?    ???  Steve
