  • July 17, 2025, 09:06:18 AM
Author Topic: Who makes this engine?  (Read 3543 times)
Offline RogerGreene
« on: June 08, 2014, 07:25:46 PM »
I was give two of these engines and I do not know where they are from. I know that they are .25 displacement, and I can turn them over without a prop, so they are quite used up. So I'll use more castor oil in the fuel. But does anyone know who made these engines. The were on two old well used trainer R/C planes.
Thanks.
Roger
Sorry about that Windows 8.2 and firewalls .....
« Last Edit: June 08, 2014, 08:03:13 PM by RogerGreene »
Fly Stunt <><
AMA 435R
USAF Veteran 1962-66 SAC
Life is 10% what happens to you and 90% of how you react to it. FAA #FA3RFLPAN7
Re: Who makes this engine?
« Reply #1 on: June 08, 2014, 07:38:50 PM »
« Reply #2 on: June 08, 2014, 07:40:23 PM »
I thought I knew, but was wrong. IDK.  VD~ Steve
Offline Douglas Ames
« Reply #3 on: June 08, 2014, 07:40:49 PM »
A picture would help.
AMA 656546
Offline Gerald Arana
« Reply #4 on: June 08, 2014, 07:50:58 PM »
Well, I think they are worth a "Dollar-two-eighty"!  LL~ LL~ LL~ LL~
Jerry
Offline Bruce Hautamaki
« Reply #5 on: June 08, 2014, 08:23:30 PM »
It is an HB .25 by Hirtenburger. Might have miss spelled that but that is what it is. They are good running engines.
Offline Curare
« Reply #6 on: June 08, 2014, 08:34:39 PM »
Yep, it's a Hurtenburger knuckleshaver
Edit: no it's not. see below.
Greg Kowalski
AUS 36694
Offline Steve_Pollock
« Reply #7 on: June 08, 2014, 08:39:41 PM »
Roger, the engines are HB (Helmut Bernhardt) from Germany, not HP (Hirtenberger Patronenfabrik) from Austria.  MECOA owns the HB tools and parts, and they may still have some in stock.
Offline 55chevr
« Reply #8 on: June 08, 2014, 09:00:07 PM »
Is that a dykes ring motor?
Joe Daly
« Reply #9 on: June 08, 2014, 09:01:33 PM »
Winner, winner, chicken dinner! The picture was a big help, I bet. Unfair advantage!  y1 Steve
« Reply #10 on: June 08, 2014, 09:09:13 PM »
well of course pictures help,, expecially since it says HB on the case,, Heck I might have even figured that out with pictures LOL
« Reply #11 on: June 08, 2014, 09:10:43 PM »
Yes, the .25 is a Dykes-ring engine.
« Reply #12 on: June 08, 2014, 09:14:46 PM »
If it's a Dykes ringed engine, check with Frank Bowman in the Vendor's list of forums.  :! Steve
Offline RogerGreene
« Reply #13 on: June 08, 2014, 10:07:02 PM »
Thanks guys. So its a HP made in Germany I can see the HP in the logo. I took the muffler off and I don't see a ring on the piston.
Fly Stunt <><
AMA 435R
« Reply #14 on: June 08, 2014, 10:45:43 PM »
I would also mention that since it is a Dykes ring engine it will not exibit full compression when turned over by hand.  The dykes ring principle requires significant pressure from above the piston (as in combustion or being moved very fat against compression as in flipping a prop) to expand the ring into a tight fit with the cylinder and seal compression.  The purpose is to reduce ring friction on the up stroke below the cylinder ports and there by reducing wear and increasing efficiency.
The engines may need new rings but the defacto test of turning them over by hand proves nothing with a dykes ring piston!
« Reply #15 on: June 09, 2014, 12:51:23 AM »
    No, it's a HB engine. It does get confusing sometimes. As Randy C said, if the engine is dry, you may not feel any compression by turning it over. Put a prop on it and a few drops of oil in the exhaust and flip it through to get a feel for what kind of pop it has. And you are correct about adding some castor to the mix to help out the compression.
  Good luck with it,
Offline 55chevr
« Reply #16 on: June 09, 2014, 03:56:40 AM »
Dykes ringed engines are hard to hand start ....  best way I have found is an electric starter.
Joe Daly
Offline RogerGreene
« Reply #17 on: June 09, 2014, 06:27:00 AM »
Oops my boo, it's an HB engine. I put a few drops of Bostitch pneumatic tool lubricant and a prop and flipped the prop. It has a nice sound while flipping the prop. Now gotta put it in a plane when the weather gets better.
Thanks guys very much appreciated,
Roger  :) y1
Fly Stunt <><
AMA 435R
« Reply #18 on: June 09, 2014, 06:50:10 AM »
I had an HB .20BB years ago, and ran it with pen-bladders...that thing was wicked fast on 65' lines. I had it in a scratch built jet  I designed that had a 20" WS and was less than 20" long....that's about as fast as I've ever wanted to fly C/L.  ;D
« Reply #19 on: June 09, 2014, 09:32:15 AM »
Rodger,
Now with a picture, it is worth $30-40 on the Bay. I could only find two in the completed auctions. One didn't have a carb and the other one didn't have a muffler. Also the Dykes ring is at the very top of the piston and hard to see.  y1
Good luck, Jerry
Offline RogerGreene
« Reply #20 on: June 09, 2014, 10:17:09 AM »
Each have a muffler and the carb.
I wonder how good these engines are for stunt... I will have to make a venture or just use the carb full open.
Roger
Fly Stunt <><
AMA 435R
« Reply #21 on: June 09, 2014, 12:09:26 PM »
Roger
Not so good for stunt without very careful set up and probably not worth the effort.  There are a lot of good 25 size inexpensive engines that are much better for stunt and much lighter...
The HB engines are ported for a steep power curve and a relatively narrow power band...in other words...they make very good power at high rpm and not much below that.
This is rather contrary to what makes a good stunt engine.
« Reply #22 on: June 09, 2014, 03:21:21 PM »
Not so good for stunt The HB engines are ported for a steep power curve and a relatively narrow power band...in other words...they make very good power at high rpm .......
This is pretty much what I discovered about the .20; after my R/C buddy crashed my little jet, I put it on a Ringmaster Jr. and regular tank setup...it flew well, but not very stunt-worthy. I traded it off plane and all for a fox .35! H^^
