  • July 14, 2025, 04:27:30 PM
Author Topic: Who is Sid?  (Read 1370 times)
Offline Joe Gieseke
Who is Sid?
« on: April 30, 2020, 07:24:33 PM »
I remember times of my dad speaking of someone named Sid.
Can someone help jar my recollection as to who Sid is?
I found something that belongs to him.
Joe Gieseke
Re: Who is Sid?
« Reply #1 on: April 30, 2020, 07:49:30 PM »
Sid Axlerod?
Re: Who is Sid?
« Reply #2 on: April 30, 2020, 08:04:46 PM »
  Yes, Sid Axlerod owned Top Flite Models.  I met him at the '82 or '83 NATS at Lincoln, Nebraska. I was flying R/C sailplanes then. Sid loved R/C sailplane guys because we used acres of Monokote on our airplanes. He also loved stunt guys because they bought lots of Nobler kits, Flite Streak, Gieseke Nobler kits, and covered those with acres of Monokote!
Offline Joe Gieseke
Re: Who is Sid?
« Reply #3 on: April 30, 2020, 08:07:36 PM »
Yes, it was Sid Axlerod.
Anyone know how I might contact him?
Joe
Offline Joe Gieseke
Re: Who is Sid?
« Reply #4 on: April 30, 2020, 08:17:19 PM »
I see that Sid has already left us, so I will attempt to find a family member.
Thanks for your help.
Joe
Offline Joe Gieseke
Re: Who is Sid?
« Reply #5 on: May 01, 2020, 10:54:11 PM »
Hi Bob
All is well here.
 I've been cleaning up my shop and occasionally open a box of my dads modeling items. I believe I am probably the owner of the largest collection of Fox 35 pistons and sleeves in the country.
Offline James Holford
Re: Who is Sid?
« Reply #6 on: May 02, 2020, 02:49:53 PM »
Hi Bob
All is well here.
ABC sets or stock replacements?
 Those ABC sets are highly sought after.
Sent from my SM-G965U using Tapatalk
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Offline Joe Gieseke
Re: Who is Sid?
« Reply #7 on: May 02, 2020, 04:53:36 PM »
I'm not sure what an ABC set is.
I do know that Duke would hand pick some pistons and sleeves to send to my dad fairly regularly.
Re: Who is Sid?
« Reply #8 on: May 02, 2020, 04:55:28 PM »
Ohh in that case for sure you have some good ones!!
Jamie Holford
Lafayette, La
AMA #1126767
Re: Who is Sid?
« Reply #9 on: May 02, 2020, 05:00:17 PM »
   Given the era that Bear flew with them, it was *long* before there was an ABC set, and Duke had long passed on before those showed up.
Re: Who is Sid?
« Reply #10 on: May 02, 2020, 05:05:05 PM »
Oh ok. Thanks for the clarification Brett!
Jamie Holford
Lafayette, La
AMA #1126767
Re: Who is Sid?
« Reply #11 on: May 02, 2020, 05:40:32 PM »
  Aluminum piston, Brass liner with Chrome plating (to give a better wear surface than bare brass). Supposed advantages are that the aluminum piston is lighter than the cast iron (meehanite) piston, so it vibrates less, and it's more likely to survive modern fuel or hot runs because it doesn't want to seize up when overheated. The vibration is probably an improvement, but the existing cast iron piston and steel liner are plenty durable enough.
   They usually look like brass on the outside of the liner.
Re: Who is Sid?
« Reply #12 on: May 02, 2020, 07:29:01 PM »
   The folk lore surrounding Bob and his Fox.35's that I remember from back then was that Bob would make regular trips to Fort Smith, and Duke gave him the run of the plant to pick and choose the parts he wanted for his engines and then assemble them himself. I wouldn't mind tip toeing  through that box just to get some of his cast offs because they still might be better than what I got in my engines at home!!
   It would have been real cool to sit down and talk with Bob about flying, and just as cool to sit with him and talk about his engines and what he looked for and how he set them up. I would bet they were for the most part bone stock but had superior fit and some other small detailing for optimum performance. I would like to know his fuel, prop and plug preferences.
