The MACS Muffler, being a tuned pipe (1/4 wave, somebody says), won't appreciate the silicon angled extension at all. You can gently bend the stinger a bit, so maybe you can get a little more clearance, or get all the oil onto one side of the wing.
I had a MACS on my .46LA powered Humongus, and liked it a lot. It takes the right prop, to get the launch rpm into the right range, which will probably be 10k+. You'll need it to peak about 1,000 rpm over your launch rpm, or it will sag in the overheads. I'd expect a stock G.51 CL to want to launch in that 10k+ rpm range anyway, so it might work fine with the right prop. Maybe the 12.25 x 3.75 or 12-4 APC, or something of that sort. Don't be afraid to experiment. You WILL need a tachometer for this setup.
