  • July 12, 2025, 12:21:16 AM
Author Topic: Which is Which...40FP's  (Read 1658 times)
Offline Alan Hayes
« on: September 02, 2006, 07:39:23 PM »
I have two 40FP's that were reworked quiet a few years back and I cannot remember which is which.  One was done by Randy Smith and the other by Tom Dixon.  The only visual difference is the muffler....one has the stinger cut off flush with the muffler can.  Help?
AMA 7064
"The measure of who we are is what we do with what we have" ~ Vince Lombardi
Re: Which is Which...40FP's
« Reply #1 on: September 02, 2006, 08:04:49 PM »
Hi Alan,
I am not sure you can tell from the outside.  Don't know if Rany did any markings to his, IIRC, Tom never has.
They do run a good bit differently, though.
Bill <><
Offline wmiii
« Reply #2 on: September 02, 2006, 08:19:36 PM »
 Randy cuts a couple of cooling grooves on the out side of the head,
he also machines a  glow plug , for lack of a better term, heat sink on top of the head.
 Walter
walter menges
Offline peabody
« Reply #3 on: September 02, 2006, 08:29:19 PM »
The Hi-Zoot Randy motors are abc...look for the brass sleeve.....
« Reply #4 on: September 02, 2006, 11:51:23 PM »
 Walter
Hi Walter,
Thanks for reminding me of that!   I am so used to seeing Randy's engines that I had forgot the two grooves and milling around the glow plug.  Those grooves are so common around here that I don't even notice them anymore.  ;D
Bill <><
Offline Alan Hayes
« Reply #5 on: September 03, 2006, 07:41:03 AM »
Thank you for the info...mystery solved.
Walter, you were dead on about the rings on the head and the machining around the plug.
Alan
AMA 7064
Offline Ward Van Duzer
« Reply #6 on: September 06, 2006, 08:51:50 AM »
Unless this is a really old rework, Randy normally signs his engines, and reworks with "Randy", and a number on the bottom of the crankcase. Each brand/size engine has it's own series of numbers.  This is good to know if you ever have one lost or stolen.
signed: Randy's old helper!
