  • July 14, 2025, 12:42:18 PM
Author Topic: Where to purchase glow plugs?  (Read 3247 times)
Offline frank mccune
« on: October 16, 2016, 06:34:15 AM »
       Hi all:
       Since we do not have any hobby shops in this area, I must resort to mail order for my glow plugs.  Where is good source of glow plugs?
       Have Thunderbolt plugs become a thing of the past?
        Tia,
        Frank McCune
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Dave Siegler
NE9N extra class
AMA 720731
Re: Where to purchase glow plugs?
« Reply #2 on: October 16, 2016, 07:51:53 AM »
I like Glo Devils from McDaniel RC/Sonic Tronics.
Offline pat king
    • PDK LLC
« Reply #3 on: October 16, 2016, 07:53:24 AM »
Merlin Glow plugs has a broad line of plugs.  http://www.merlinglowplugs.biz/main_page.html
Pat
Pat King
Monee, IL
AMA 168941
Dwayne
Offline Gary Mondry
« Reply #5 on: October 16, 2016, 09:16:54 AM »
I got my last batch of Thunderbolt R/C longs from Randy Smith.
AMA 10663
Offline Phil Spillman
« Reply #6 on: October 16, 2016, 02:00:44 PM »
Hi Frank, Brodak sells Sig 003 Rc idle bar Plugs like we all need! Buy them there! You may mail order or drive down to the store and buy them yourself! Take a bunch of the HAMS along and have yourselves a fine day of fun and Hobby Spending! And while you're there pick up a New Catalog for your file!
Phil Spillman
Phil Spillman
Offline Ken Burdick
« Reply #7 on: October 16, 2016, 02:23:49 PM »
I tried a few from the low end offering from Hobby King. They are under 3.00 and work pretty well on the tach compares to K&B readings. No blown seals under high compression and good filament life.
« Reply #8 on: October 16, 2016, 02:55:16 PM »
I have 100s  of plugs in stock at all times, however  T Bolt  RC longs are  out at the distributor, I have other T Bolts in stock like the  BiG Bore  and  I have  SIG, and  some  Glow devil in stock as well as the  McCoy hot plugs
Offline Russell
  • ACE
« Reply #9 on: October 18, 2016, 01:19:14 PM »
       Hi all:
        Tia,
        Frank McCune
OS Glow Plug Chart:
http://www.osengines.com/glowplugs/index.html
To buy OS Glow Plugs online:
http://www3.towerhobbies.com/cgi-bin/wti0097p?P=3&MANUFACTURER=OSM&FVSEARCH=glow+plug
Offline rustler
« Reply #10 on: October 18, 2016, 02:05:28 PM »
Don't know if this is hijacking, but does anyone make a full range of plugs these days, long, medium, short, and hot, medium, and cold?
Ian Russell.
« Reply #11 on: October 18, 2016, 02:27:00 PM »
Yes they do  I hAVE most of them instock
T Bolt  has a large range  as well  as  OS  and   Thunder Tiger   Merlin    etc
« Reply #12 on: October 18, 2016, 08:16:02 PM »
Can anybody produce a list of brands that are actually made by Ohlsson Corp.? I know K&B and Thunderbolt are. SIG? Sonic? McCoy? I think they make a fine product, and would like to have options...although I bought a "card" (a dozen) of the R/C and another of the 4-cycle. Have yet to run short or need more.  ;D Steve
Offline Skip Chernoff
« Reply #13 on: October 19, 2016, 05:21:51 AM »
Dave, which of the Glo Devils do you prefer for Stunt work? Sonic Tronics is local for me. Thanks,PhillySkip
Online SteveMoon
    • www.ultrahobbyproducts.com
« Reply #14 on: October 19, 2016, 07:45:33 AM »
Randy Smith at PA and Merlin Glow Plugs should have everything you'd ever need
as far as glow plugs are concerned.
« Reply #15 on: October 19, 2016, 08:09:27 AM »
I use the SOT 300 R/C Longs with the idle bar to help protect the element though the non-idle bar is OK too.
Offline Fredvon4
  • Central Texas
« Reply #16 on: October 19, 2016, 11:28:29 AM »
Don't forget to buy a whole card of the New OS #80  Gold Plated at only $10.99 each...a Medium plug that will surely add distinction and performance to your now obsolete *Fox .35 or Enya 35 5224 stunt engines
Or just replace either engine with a a OS LA 25, OS #3/7/8 plug and go burn up a lot of relatively cheap fuel
BTW I can still find KB 1L for about $5 on e-bay...these are for all my Fox .36 combat engins
I do use a lot of Nelson hot or standard plugs and wish more of my engines were made for that design...great plug for 5 bucks!
* not Fox 35 or Enya 35 bashing... have a plane or two with each....but once I went to the (still obsolete) more modern engines, I get to fly more with less fussing
Fred von Gortler IV
« Reply #17 on: October 20, 2016, 04:53:18 PM »
K&B glowplugs are available straight from MECOA.  Your $5 price may be good or not, depending on which model glowplug you order. Again, they're made by Ohlsson Corp.  H^^ Steve
http://www.mecoa.com/acc/glowplug/glowplug.htm
Offline Reptoid
« Reply #18 on: October 22, 2016, 02:40:16 PM »
       Hi all:
        Tia,
        Frank McCune
While you can probably get what you need from Randy at Aero, here's some more info:
Thunderbolt still makes and sells plugs, but the "R/C Long idle bar" and the "4-Stroke plug" are discontinued per their management and website.
Fox is out of the modeling business so whether you liked them or not, no more Fox plugs.
Merlin makes a full range of plugs but no "Idle bar" (if you're convinced you need it) we have found the Merlin #2003, #2003HD, and #2005 to work well in most engines used for stunt/sport including 2-4 break where you might need a hotter plug
Sig still sells the #003 idle bar R/C long plug and many think/thought it is/was the gold standard of R/C longs. They are also one of the only places that still sell Castor and Klotz and decent fuel for U/C.
Mecoa sells the full line of K&B plugs including the idle bar. Others may be correct about O&R making them but if so, they only make the body as I have watched the elements being installed at the Mecoa plant. Same spec and quality as the original K&B's.
Sonic Tronics still offer the #300 idle bar
McCoys are still avaiable but seems they discontinued the four stroke (gold stem), and the MC-55 hot??
While a lot of plugs are/were made by O&R (Ohlson) they are made to the ordered spec and are not all the same. The dia. & depth of the hole, diameter and length of the wire, addition of idle bar, and Finish, all effect the heat range of the plug.
       Don
       AMA # 3882
