  • July 14, 2025, 04:07:01 PM
Author Topic: WHERE TO BUY GOOD BALSA  (Read 3494 times)
Online doug coursey
« on: November 04, 2024, 07:40:32 AM »
IM LOOKING FOR SOME 1/8 X 4X 48  BALSA FOR FUSE SIDES IN 6 TO 7 LB RANGE,I WENT ON NATIONAL BALSA SITE AND THEY WANT $19.10 PER SHEET FOR THERE AERO LIGHT WOOD AND EXTRA 35% TO CHOOSE A POUND WEIGHT  BETWEEN 2 POUNDS..SO THATS GOING TO BE ALMOST $30 A SHEET...THAT WOULD BE ABOUT $70 FOR 2 SHEETS THAT MIGHT BE CLOSE TO THE SAME WEIGHT.
AMA 21449
Online Crist Rigotti
Re: WHERE TO BUY GOOD BALSA
« Reply #1 on: November 04, 2024, 08:07:23 AM »
No need to shout.
« Reply #2 on: November 04, 2024, 08:53:38 AM »
    Please to not post all caps.
     Get in touch with Elliot Scott (BYU on Stunthanger).
« Reply #3 on: November 04, 2024, 11:43:47 AM »
I don't know where you are but the Hobby Lobby's here in Dallas have consistently had 6-7lb 1/8" and 1/4" wood.  Anything else is a joke.
« Last Edit: November 04, 2024, 01:00:04 PM by Ken Culbertson »
« Reply #4 on: November 04, 2024, 11:55:32 AM »
  Good balsa is where you find it, and that's why you just have to keep looking and buy it when you find it.
Online doug coursey
« Reply #5 on: November 04, 2024, 01:07:25 PM »
BALSA USA has what they call soft,medium and hard balsa for 9.08 a sheet which is 42 inch long
AMA 21449
Online doug coursey
« Reply #6 on: November 04, 2024, 01:08:45 PM »
the one here only has 36" length and i need at least 42" for the fuse
AMA 21449
« Reply #7 on: November 04, 2024, 01:18:22 PM »
I have pretty good luck with Balsa USA.   I order the hand select soft and the majority is in the 5.5-6.5 range.   Length?   I splice as necessary,  usually up in the area where nose doublers are being used anyway,  between the wing and the spinner.
Online doug coursey
« Reply #8 on: November 04, 2024, 01:41:33 PM »
i thought about splicing but if i can the longer sheet it would be better so i dont have a joint to deal with,im going with balsa usa,i m going to get a few sheets of soft and a few of medium..
AMA 21449
Online doug coursey
« Reply #9 on: November 04, 2024, 01:43:12 PM »
i thought about splicing but if i can the longer sheet it would be better so i dont have a joint to deal with,im going with balsa usa,i m going to get a few sheets of soft and a few of medium..i just wasnt sure about their service
AMA 21449
« Reply #10 on: November 04, 2024, 04:24:37 PM »
Their service has been great as far as I'm concerned.  I can order on Monday and it gets to Kansas by Wednesday or Thursday.  BTW they also sell very good epoxy in either 12 minute or 30 minute.  I usually throw some into each order.
Online doug coursey
« Reply #11 on: November 05, 2024, 11:11:38 AM »
I ordered from them today maby out of 8 sheets i can get 2 that will work...4 soft and 4 medium, ill let you know what they are like
« Last Edit: November 06, 2024, 12:42:37 PM by doug coursey »
AMA 21449
« Reply #12 on: November 09, 2024, 05:44:40 AM »
Doug,
National Balsa has sales going on all the time, check out their website and facebook page.
Best,   DennisT
Online Robert Zambelli
« Reply #13 on: November 11, 2024, 03:28:45 PM »
Brodak has a good supply of balsa.
I'm not sure if they will select various weights for you nor do I know about pricing.
Offline Mike Griffin
« Reply #14 on: November 11, 2024, 04:16:20 PM »
Sent you a PM Brett.
Online doug coursey
« Reply #15 on: November 11, 2024, 07:43:13 PM »
got my 8 sheets of 1/8 x4 x 42 inch balsa from Balsa USA today  2 sheets were 4.9 lb ,2 were 5.08 lb,2 were 5.4 lb,1 was 6.7 lb and 1 was 7.1 lb it was all B grain  very nice wood...i ordered 4 sheets of soft and 4 sheets of medium
AMA 21449
Offline Gary Dowler
« Reply #16 on: November 12, 2024, 04:38:22 AM »
Estate sales where the guy flew, you can sometimes find such listings on Craigslist. I got a ton of glow plugs from a guy in exactly this manner once.   Dont write off  sources like Michaels or Hobby Lobby.  They sometimes have wood selections by the sheet as opposed to the packaged stuff, apparently it varies by location. I recently got a handful of 4x36 1/16 sheets at Hobby lobby that were 6.5-7lb stuff.  Just went through the stack a sheet at a time feeling for the "light" ones.
Gary
Online Paul Taylor
« Reply #17 on: November 21, 2024, 10:31:16 AM »
He miss ALL CAPS day. 🤣🤣🤣
https://nationaltoday.com/international-caps-lock-day/
« Reply #18 on: November 21, 2024, 11:27:50 AM »
My sources are Balsa USA and The Toledo RC Show every April.
When 80% of the buyers demand the lightest 5% of the crop, not everybody wins.
Most of the time there were three waves of pickers who went over the stock before you got there.
If your wood is heavy, it's also very strong. So alter the design to use less wood.
Offline Gerald Arana
« Reply #19 on: November 21, 2024, 01:01:35 PM »
Yes, this is true. Also heavy wood makes good (strong) spars and other parts where you need strength.
Good luck, Jerry
