  • July 17, 2025, 05:32:55 PM
Author Topic: Where are the world beaters ?  (Read 7733 times)
Offline scott bolton
« on: August 04, 2009, 08:03:35 PM »
 HI fellas, I had a chance to read the article in the april issue of CLW and have been thinking about the idea of having a 40 size stunt plane with a tamed down 60 size engine. I would love to know if there are some guys who have taken this concept and have run with it. Also if anyone has done this how about some thoughts and inputs on the results. The article i'm talking about is the one Brad walker did titled "low tech world beater"  If anyone has some results or inputs on this idea please respond. I personally think it's a pretty cool therory and hope to see it work. THANKS , SCOTT
keep em tight !
Re: Where are the world beaters ?
« Reply #1 on: August 04, 2009, 09:43:03 PM »
   Pretty much every West Coast design since the end of the 4-2 break era is a "40-sized" airplane with a 40, 60, or in Dave's case, a 75. Actually, if you want to be picky, they are really ST46-size airplanes with piped 40's 60's or 75s. David's airplane, in particular, virtually identical in most major dimensions to the Imitation - an ST46 airplane from 1978!
   It works a lot better with low pitch/high rev engines than it does with 4-2 break motors. Before piped engines came along, a lot of people tried putting "schneurle-of-the-month" engines and ST60s in their 46 airplanes. It might have been better than normal when you got the engine running *just perfectly* but usually you did better with an airplane sized for the engine. Piped engines don't care nearly as much what you hang them on - witness Jim Aron's Vector 40 with a PA65 (two-port) , and soon, his Systrema with a PA65. And of course David won the W/C and NATs with the dinky Thunder Gazer and a PA75, which is about as crazy of proportion.
   The trick in any case is the detuning of the engine to run *very softly* in the corners. That's what usually killed the ST60 Imitation derivatives, it was difficult to get it soft enough in the corners without just making it as gutless as a 46. It's pretty easy to get piped engines to run however you want.
steven yampolsky
« Reply #2 on: August 05, 2009, 12:28:29 AM »
Jimmy Casale talked about his NATS winning designs as 46 sized airframes with 60-sized motors. As early as July 1980 issue of FM, Mr. Casale talked about 46(ST46) size airframes with 10/15 moments and 56-60in wingspan flying better than any other size airframe, only when powered by a very strong motor. He did not consider ST46 a powerful motor and abandoned it very quickly. He won 4 NATS(1983,1985,1988 and 1989) with his Spectrum design before retiring from the sport. All wins were with a 46-sized airframe powered by ST60!
Offline Bradley Walker
    • The Urban Rifleman
« Reply #3 on: August 05, 2009, 05:35:35 AM »
Yes, we did it...
Mike Scott and I built a plane using Vector 40  ARF components with a new fuselage exactly as described in the article.  It has a PA 65 on restricted header muffler.  I use a smaller exhaust diverter and the engine is much quieter and much more "locked in" than normal.
As far as I am concerned it is the best thing I have seen off the board in years.  The engine performs exactly as I predicted.  It is so tame because the engine is seeing no load at any point in the pattern from the airplane so it shows no signs of trying to accelerate (or decelerate for that matter).  It just penetrates like a missile.  The engine just groans around without ever changing note (unless you use a huge prop).  I have not seen a plane more "stuck out there" since I brought out my first Saito 72 powered plane.  The lines are dead straight even when flying little circles right overhead.
All of the West cost planes are much larger than the Vector 40.  It is like 575 sq in.  Nearly all of the old West coast designs are closer to 650 sq in plus with big, fat wings.  The Imitation is a little smaller (I think it is the best of the bunch).  Fitz's new design is 630, and is considered the smallest.  The "old" 1980's era 40 sized planes are today's 60 sized and even 75 sized planes (I explained that in the article).
I think you will find that Randy Smith designed the original Vector before any of these West coast designs anyway.  It was closer to the modern Staris/Shrike etc. Randy also told me that I am not the first person to advocate a 60 in a Vector 40.
It is by means perfect yet, but this is really the right track.  The second version will most likely have 9.5 nose and 18 tail moments, using all of the stock ARF flying surface components.  The first one is 10/17.5 and is little nose heavy without adding weight (by 1/2" or so in fact).   It weighs about 46 oz on Monokote and painted fuselage.
We are flying it on .015 braided lines 62 to 64 foot lines.
-George Bernard Shaw
« Reply #4 on: August 05, 2009, 06:03:02 AM »
Liking that plugged boost port huh?
By the way, we are not running a 4-2 break.  No break.  Anywhere.  Deep, wet 4 cycle.
It is not the pipe, it is the run...  We have run the piped and non piped PA 65 back to back, if the pipe is doing any "braking" it is marginal.  Mostly what does the braking is the behavior of the engine itself.  Does the engine back off when overspeeded or not?  Pipe engines don't just perfectly back off in the wind "plug and play", and to say they are "more forgiving" is just laughable.  If that were true then everyone in the country would have that perfect pipe run that never speeds up...which they absolutely DO NOT HAVE.  I think I can count on two hands the guys who have exceptional pipe runs that show no signs of overspeeding in the wind.  One of them flies with me.  He is using my old motor...flying a combination invented one fall by Bob G. with me at the hold.  You guys are using a similar type run (also explained in the article).  All of the ideas for the "gorilla balls" run really came from Billy Werwage.  The rest of the pipers that do reasonably well are running basically a 2-2, which cannot overspeed, pipe or not...  Bill Wilson uses a 2-2 setup that is as good as anything I have ever seen in the wind.  HE can do the same thing with or without a pipe.
The pipe adds power.  It is just that simple.  There is no way I could my PA 65 to burn 8 oz of fuel without a pipe.  Without a pipe the engine is not as powerful.  The megaphone from the pipe is a power booster and helps draw large amounts of fuel to burn.  Especially with a large venturi.
Of course, at 575 sq in of plane, you do not need 8 oz of fuel type power... that was the WHOLE POINT.  We are burning 4-5 oz of fuel with 15%-20% nitro without the pipe, getting the same deep 4 cycle that David is getting on half the fuel.
I would not recommend a 4-2 break for wind performance...ever (I am still waiting to try Brian Eather's setup which I would dare say is equal to anyone's---he abandoned the pipe years ago and I think Brian knows a few things).  For the PA, I would advocate either a deep 4-4 or a 2-2 for windy days (or you can go to a flat prop and wind the engine up until it won't go any faster and it still 4 cycles like Doug does).  That was also covered in the article...
Nothing has really changed in the world of stunt since the ST 46/ST 60 40 FSR/45 FSR days except the fits and materials the engines are far superior.  The best stunt engine I have ever seen is a McCoy 40.
I have a friend (who will remain nameless) who said that his old SV-11 with a Big Jim ST 60 was as good as anything he is flying now... and if it were more politically correct, he might go back to it.  It was very consistent, especially in the wind.
« Last Edit: August 05, 2009, 06:29:40 AM by Bradley Walker »
« Reply #5 on: August 05, 2009, 06:24:11 AM »
This is the Evo 52.  It burns 1 oz a minute.
[youtube=425,350]<object width="640" height="505"><param name="movie" value="http://www.youtube.com/v/-B-aVJ5-hm4&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/-B-aVJ5-hm4&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>[/youtube]
Notice how the engine has to "kick" in the corners.  The plane weighs 72 oz.  If the plane weighed say, 50 oz, it would never ever even know it was in a corner...  It would just go bllllllaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhh for the whole pattern.
Another thing I noticed.  It is easier for the prop to "brake" a smaller, lighter plane.  The smaller wing also whips up less, period.  A large light plane is not the same thing a small light plane.  There needs to be adequate wing loading for the plane to perform.
Offline Mike Ferguson
« Reply #6 on: August 05, 2009, 07:50:20 AM »
If you also look at the airplanes Jimmy was flying before he left the hobby, he was also heading in the "smaller plane" direction.  He'd gotten away from the bigger Avanti-based Spectrum/Columbia series of planes.  Most of the later ones were either a "stretched" Genesis 35 or a variant of Arden Zhang's WC plane, which were in the low 600 sq. in range (i.e., the "40-sized plane") and either powered by ST60 or the 40 piped motors of the time.  One unpublished plane called the "Discovery" was probably the best thing that I've ever seen him fly.
I think Jimmy would love the Thunder Gazer.  The concept is *exactly* what he was aiming for towards the end of his stunt career.
Online Matt Colan
« Reply #7 on: August 05, 2009, 08:12:09 AM »
Grandpa has a Mustang that was powered by an ST 46.  The plane has around a 56 inch wingspan, so it is a midsized stunter.  He is refinishing (I call it restoring) it, and for the past couple of days, has been retrofitting his PA 51 into it.  I tell him that the plane is going to be a killer with that motor in it.  We'll find out next year, since it is definitely not going to be flying.
For an Oriental Plus, I'm going to power it with a PA 40UL, and would a 2-2 or a 4-4 engine run would be good.  We've been actually using a 4-2-4 engine run on grandpa's F-14, but that plane is a pig when it gets warm out (70 ounces on a chipmunk airfoil), so he isn't flying it now.  We don't have very many high zoot motors, two PA 40s, one PA 51, two OPS 40s, and 1 PA 40UL.  I am starting to believe in the big motor in a smaller airplane, after everything I've been reading, it sounds like the way to go.
By the way, why did Jimmy Casale drop out?
steven yampolsky
« Reply #8 on: August 05, 2009, 08:37:20 AM »
It's been tough to get info on this. Different people say different things and none has been able to find Jimmy. Here's what I gathered so far:
He had a nasty prop injury that took a very long time to heal. Being a musician by trade, he decided to leave the hobby in order to keep his job.
After the injury has healed to the point where he could fly again, he found the state of stunt very different from when he left it last. He was a strong believer in big displacement, high torque, low RPM kind of of power. At the beginning of the 90's, almost everyone moved to high RPM, low torque, constant 2, piped setups. Disappointed, he did not come back.
Please understand, this is second and third hand knowledge and some/most/all of it may be false. Regardless of why Jimmy Casale has left, his foresight and superb understanding of what stunt is ought to be, was indeed far ahead of his time. Truly, Mr. Casale was a visionary.
« Reply #9 on: August 05, 2009, 08:45:29 AM »
Jimmy left the hobby for a variety of reasons.  His mom was ill at the time and required care.  He got his hand caught in a carbon fiber four blade the year before he left, which was a nasty accident, and also affected his job (he was a saxophone player in a band).
From a competitive standpoint, the tuned pipe "revolution" was also a factor - at the time, the pipe wasn't the turnkey plug-and-play set-up it is today, and he realized he was going to have to put a lot of time and money into developing a competitive system.  He realized that the ST60 wasn't going to cut it in competition.
His last Nats - the 1992 Nats - was a horror show worthy of a country-western song.  He lost his job the week of the Nats, his wallet got stolen while he was there, it turned out that there was a warp in the wing of the plane he was flying ... just really bad stuff.  My dad Keith was his coach, and I think they spent a bit of time talking that week about his frustrations with the hobby, and about other things.  Jimmy knew that if he wanted to win the Nats again, he needed to put in even more time and effort than he had before.  He didn't have the time, and based on a lot of the negative things that happened, he was kind of burned out.
Jimmy was an all-or-nothing kind of guy.  He wouldn't be happy going to the Nats with the expectation of "just" making the Top 20, or the Top 5.  He was there to win the Walker Cup, and if he knew the stuff he had wasn't good enough to win, he wasn't going to compete.  What you got out of him was nothing less than his best efforts to win.
I think he originally left the hobby with the expectations of coming back in a few years, but that's almost 20 years ago at this point.
Still, I hope he comes back at some point.  He's still one of the best flyers - if not the best - I've ever watched fly.
-Mike
BTW, it was *not*, as some have stated elsewhere on the Internet, because of anything to do with "East Coast/West Coast" judging, feuds, or any other nonsense like that.  Jimmy took his win at the Pasco WA Nats in 1989 - in front of mostly West Coast judges - as validation that such things were a myth.
Online Matt Colan
« Reply #10 on: August 05, 2009, 08:53:57 AM »
I've seen Jimmy fly on video, and he looked like a great stunt flyer, bottoms were all there on the one flight I saw him fly (on  video) and that plane cornered.  I believe it was the 1992 Nats that I saw him fly in.  That plane did have a pipe on it if I'm not mistaken.
« Reply #11 on: August 05, 2009, 09:02:47 AM »
Yep - that was one of the later Arden Zhang "Skywriter" variants with a piped OS Max 40 VF.
In particular, from watching Ted Fancher and Paul Walker's piped airplanes at the 1992 Nats, it became pretty evident that Jimmy's pipe "program" was going to need a serious overhaul.
« Reply #12 on: August 05, 2009, 09:29:58 AM »
EXACTLY!!!!
Brian Eather told me he has one of the "Dong 60's".  It will not 2 cycle.  Ran sidewinder with inboard tank (sound familiar?).
« Reply #13 on: August 05, 2009, 07:58:55 PM »
   Or just never cutting the port into the sleeve.
    I agree - if you can get it to run the way it needs to - strong but soft in the corners - that's the key. The Retro being a good example. It's like having an ST60 that ran the way it was claimed to run, but never did. It's not that surprising - they kept on that track and had access to the necessary machine shop to work out the details.
   OOOOH! So close! Still missing the effects of the prop.
Walter Hicks
« Reply #14 on: August 06, 2009, 12:49:26 AM »
What is being discussed is what I am looking for at least in engine performance. presently using a RO Jett .67 RE , Custom Scott Dinger RE muffler,launch RPM is usually 7300,7600 RPM ,presently using Yatsenko  prop 13.4 x 5.9.
My question is what will an exhaust deflector do to the run? Brad you mentioned that you use them. Is it to restrict the muffler? If so does it run hot or is it so rich that is runs very cool? Or is it for fuel economy?  I use 6 oz of fuel.
So far I really like the run characteristics of the rich run but the RO Jett still breaks some in the pattern . It appears that it does not wind up in the wind however. My airframe is larger than described, 677 sq 57 oz.
I am thinking of an Imitation wing , or KA 10 , @ 640 sq. And keep the weight down to low 50s .
« Reply #15 on: August 06, 2009, 07:23:57 AM »
On the PA 75, for testing purposes, I used a perfectly fitted plywood plug in the boost port.  It worked wonderfully, and I did not have to bother Randy....  I just told him later.
Then some other people tried it.
A plywood plug is much easier.
« Reply #16 on: August 06, 2009, 07:27:44 AM »
The smaller exhaust deflector is like running a small venturi but better (the effect is good up to a point of course).  Many engines like very restricted exhaust flow to behave....and freak out without it frankly.  THAT IS WHY PEOPLE RUN THE PIPE.
This a way to tame the engine down for the smaller plane.
To stop the 4-2 reduce the load of the prop...or raise the nitro....  but then watch out!!!!
Online Steve Fitton
« Reply #17 on: August 06, 2009, 10:33:38 AM »
For the purpose of discussion, lets say I took my DS 60, essentially a lightweight ST 60 clone, and tried to put it into a plane of Vector 40 size and wing configuration.  Under normal circumstances, I employ that engine in a 650 square inch Time Machine of 61.5 oz weight, with the thick Patternmaster derived wing.  Until quite recently, I had always used modified TF Powerpoint props of a nominal 12.5" dia 5.9 to 6.0 pitch for a package that was adequate enough for all the East Coast contests.
  For the much smaller and lighter Vector, where could you go to prop it?  Could one drop down to say, an 11x4 three blade Bolly?  a two blade 11.5 4.25?  Would a small prop "fool" the engine as well as suit the plane, or would you run the same prop as you ran on the "big" plane, and the small mass and drag of the Vector 40 would make the engine fall off into a constant deep 4 stroke?  I keep thinking a 12.5 x5.9 would run in a four stroke just fine, but result in unlimited wind up in the wind, even if 8 or 16 stroking.  I'm guessing you would have to drop back to a pipe prop to control the rig, but wondering what other opinions there might be.
« Reply #18 on: August 06, 2009, 10:51:59 AM »
I have a question....
If the low pitch prop is just superior to the high pitch prop, then why don't the electric guys use them?  How come you don't see the electric guys running 3.5 pitch like Doug runs on his stunt plane with the PA and pipe?  They should be able to run any speed they want right?  If the low pitch is so much better in every case (no matter the powerplant design) how come the electric guys do not seem to need, or want low pitch?
From what little I know about electrics everyone seems to be going the other way...  I think 6 plus pitch is the norm.  Am I wrong?
Or is this idea that a low pitch prop is *always* superior to a high pitch prop simply a result of the engines *you* choose to run them on?  I do know other top guys who share this belief that there is *NO WAY* a high pitch prop can compete with a low pitch prop in the wind on any powerplant...yet invariably, these same people are running engines that were designed or set up to run in the RPM range of the low pitch prop.
No, I think the prop needs to suit the powerplant design.  Low pitch, high RPM, and a pipe is no magic bullet...  As a system, it does work well (with a typical level of fiddling), but like I said I have seen McCoys work *just* as well.
« Reply #19 on: August 06, 2009, 10:59:20 AM »
You could either run a much larger diameter propeller than you could ever run before (or more blades or more undercamber), due to the reduced need for speed compensation (Mike was running the 14-6 TF in a deep low 4 cycle at 6800 RPM).
...or you can run the same prop in a much deeper 4 cycle by simply opening the needle
...or you can use a smaller venturi or exhaust opening to better meter the speed at the same prop (you can also raise the head for smoother 4 cycle).
Or you could jack the power even more (say with nitro) and drop the pitch at the same diameter and use a higher RPM.
The thing is this.  You have a lot of options now you did not have before.  It is really pretty cool.  Instead of looking for power, you are looking for a nicer run.  You can do what *you* want to do.
Offline Bill Morell
« Reply #20 on: August 06, 2009, 05:49:57 PM »
Interesting post. If the ST 60 is no longer viable as a good stunt engine then why does Tom Lay continue to modify them? It would seem that the run that it produces is no longer desirable.
Bill Morell
Vietnam 72-73
Online Steve Fitton
« Reply #21 on: August 06, 2009, 09:36:05 PM »
Arguably, the run produced by the ST 60 is indeed no longer desirable, at least at the Nats/Worlds level.  Its been 13 years since the ST-60 scored its final Open victory.  That having been said, plenty of people still use ST-60s and fly in loads of local contests and have fun doing so.  I'm sure Tom will see demand for Tigres untill the supply dries up completely.
Online Matt Colan
« Reply #22 on: August 07, 2009, 06:45:45 AM »
I just checked PAMPA's website, and the last time an ST 60 won the Worlds was 2002, when Xinping Han won for the last time.  Grandpa likes the ST 60, the way it growls around and through the pattern.
« Reply #23 on: August 07, 2009, 07:54:17 AM »
Arguably, that ST 60 might have been one of the best running engines to fly at the Nats since...  except for maybe Billy Werwage flying his ST 40 powered Vulcan that never even seemed to breath hard (that can't work).
I wonder if Les McDonald, at his prime would have been viable using his less than desirable equipment?  Or Jimmy Casale?
I wonder if we associate great performances with equipment instead of great stunt flyers.
« Reply #24 on: August 07, 2009, 08:08:18 AM »
It takes all of it to make a Champion.   The worlds greatest trimmed out plane/engine in my hands would not do the trick.  One of my planes in the hands of the worlds greatest pilot probably wouldn't do the trick either without a lot  of work trimming.  Just ask the World Champion or even NATS Champion how they got there.  DOC Holliday
Online Martin Quartim
    • StuntHobby
« Reply #25 on: August 07, 2009, 08:35:51 AM »
I don't know who copy who but the Enya 60III, still in production,  has the same PistonxStroke and same sleeve cuts of the ST-60, and looking at the crank of both engines the timings seems to be the same.
I have never ran or seen an Enya 60III in action but I have to think it will serve well to apply what Brad says.
This is a picture of an Enya 60III sleeve and of a ST 60.
Martin
« Reply #26 on: August 07, 2009, 11:19:43 AM »
Just to be clear, here is the original article:
The Low Tech World Beater
There Are Only Two Ways-Get Used To It
To be ultimately competitive, you have to be able to go through the pattern at constant speed, without speed up, no matter how bad the conditions.  In my opinion, there are only two ways to run a 2 cycle engine if you want to be competitive at the highest levels of stunt.
One way to successfully run the 2 stroke stunt engine is by using the “cool mode” run.  This is what I call the “stompin 4 cycle”.  Bob Gieseke calls this run “gorilla balls” (he will say this holding his partially clenched hand out in front of him while making a cupping motion) and this type of run has been the standard of his competitive career.  This type of run is achieved when the engine power is set to allow the needle to be set in a very rich and deep 4 cycle.  In this mode the engine will barely change through the pattern, using a growling low 4 cycle to do all of the maneuvers.  If needed, the engine will “8 cycle” if pushed in the wind.  If the engine “8 cycles”, it means it is going to the “cool mode” misfire and further away from the “hot mode” 2 cycle.  The engine is so far into the “cool cycle” that it makes no attempt whatsoever to go leaner.  When the airplane gets pushed by the wind engine just “lays down” and basically sputters rich trying to back off.  Many of the best flyers use this type of engine run.  Some notable flyers include David Fitzgerald, Bob Gieseke, Doug Moon, Brett Buck, Mike Scott, and Frank Williams.
Some typical basic components of this method are high nitro, high compression, a big venturi, and a small diameter or thin propeller with a light load.  All of these things are done to keep the engine in the “cool mode” (this means running in a rich “4 cycle” mode).   While many will argue that their “stompin” engine is making “huge power” chugging along in a 4 cycle, it really *isn’t* compared to the same engine in a full 2 cycle.  This is why it is very common to see “stompers” using small planes or big engines.  This need to run a smaller or lighter plane is due to the fact that an engine running in a deep “4 cycle” is using very little power potential of the engine.  Most of the competitors who use this setup use lighter or smaller airplanes.  It is very common to see a 61/65/75 in traditional .46 sized airplanes right around 650 sq inches or smaller, or lightweight high aspect ratio planes that are low drag.  David Fitzgerald is currently using a PA 75 on a pipe and has just recently reduced his airplane size from 650-660 sq in to 630 sq in an effort to open the performance window and gain penetration in the wind.  Brett Buck’s PA 61 powered “Infinity” uses the wing from Ted Fancher’s “Imitation” that was originally designed for the ST 46.
Another aspect of this setup is that you really need a large fuel tank.  All of the “stompers” mentioned use right around 8 oz of fuel to do a pattern using their Randy Smith PA 61/65/75 engines (all on tuned pipes) while burning 10% to 20% nitro fuel depending on the conditions.  One other downside to this method besides the huge fuel consumption requirement:  if you choose to use this type setup, make sure that you don’t get any trash in your fuel or suck a bug into the venturi.  If you do, the engine will go full lean…if this happens…HANG ON!!!
The other way to successfully run the 2 stroke stunt engine is by using the “hot mode” run.  This is what I call the “east coast run”.  This mode uses the full power of the engine somewhere in the pattern.  For the engine to work in bad conditions the power of the engine has to be limited.  Some typical basic components of this method are low nitro, low compression, a small venturi, or a larger propeller that forces the engine to be nearly fully loaded.  All of these things are done to keep the 2 cycle “hot mode” of the engine controlled.
In this mode the engine will switch rapidly from “4 cycle” to “2 cycle” mode throughout the pattern, even switching rapidly in level flight from upwind to down wind.  This type of run has lots of 2 cycle switching across the tops of maneuvers, even using as much as 10 o’clock to 2 o’clock of 2 cycle across the top of a round loop (or even solid 2 cycle throughout the loops).  Typically, this type of run will have a vertical eight maneuver where the top loop of the eight is completed with the engine in a “full tilt” 2 cycle mode.  If flying in really bad weather, the engine will need to be loaded even more or the power reduced allowing the engine to use even more 2 cycle mode.  At some point the engine simply cannot go any faster no matter how much it is pushed by the wind.  In this sense the engine will need to go *further* into the “hot  mode” to be successful in bad conditions, even up to the point that the engine can be run in 2-2 mode (using a soft 2 cycle into a hard 2 cycle with no 4 cycle mode at all).  My friend Bill Wilson runs many of his engines in a high 4-2 and even a 2-2 mode (soft 2 cycle to hard 2 cycle switching) and he flies his planes in the most horrible conditions.  In fact, many of the best flyers use this type of engine run.  Some notable flyers include Randy Smith, Bill Rich, Curt Contrada, and Derek Berry.  One can also include just about anyone who was a follower of Big Jim Greenaway.
What are some up sides to this method?  Well, for one, it burns substantially less fuel than the “stompin” method.  One other advantage is that the top end is “clipped”.  If the engine sucks up a bug, or runs away during the pattern, the top end is “clipped” so the flyer should be able to complete the pattern albeit at a slightly faster lap time.
What are some down sides of this method?  Well, first of all, the sound…  I know it sucks to say it, but many people simply do not like stunt planes flying around sounding more like combat planes.  Secondly, since there are two distinct “modes” to this run, the user is constantly tweaking both simultaneously.  There is the top end to “2 cycle” mode and there is a bottom end component to the “4 cycle” mode, and both need to be right to work to perform in bad conditions.  With the “stompin” method, the user can always go *deeper* into the 4 cycle mode when things get scary as long as there is adequate power to pull the engine through the pattern.
Finally, I hate to say it, but most everyone else is somewhere in between, which is the last place you want to be.  Unless you have an absolutely *superb* stunt engine that just “knows” when to compensate in the wind, or an inboard mounted tank, you *will* wind up without using one of these methods.
Take the “stompin” mode and get it too lean or get the engine too loaded…ballistic missile.  Take the “east coast” method and make too much top end power…zoomy-zoom-zoom.  It is just that simple.  Both methods fail when the engine simply cannot make enough juice to pull the airplane through bad conditions.
Flipping the Paradigm
The “small plane that looks and performs like a big plane” idea is not a new idea.  Bob Hunt talked about this “small plane” idea in his original Saturn article many years ago.  Randy Smith has been designing these “stealth” smaller planes for years.  Randy’s Staris, Shrike, etc are all based on this larger fuselage/small wing idea, and I think these planes are some of his best examples out there.  Heck, even Dave Fitz is on the band wagon with his latest smaller plane.
The difference here is that I intend to flip the paradigm….and with the new rules change concerning line sizes which start in 2009, I think it is completely appropriate.  Let me explain.
When the tuned pipe came out, Bob Hunt was telling everyone that if they ditched their baffle type ST 60’s and went to the powerful schnuerle 40 coupled to the tuned pipe, they could build a 60 sized plane (supposedly much preferred by judges) and pull it around with a powerful 40.  With the new setup, the pipe would control the windup in the wind.  This tuned pipe was needed due to the fact these original engines had no propensity to “back off” in the wind by design like the older stunt engines.  One of the main advantages that Bob talked about at that time was the rule that allowed those who use engines under .40 cu in. displacement to use .015” cabled lines as opposed to the .018” cabled lines that were required for engines larger than .40 cu in displacement.  Bob touted this as a huge advantage, and I have to somewhat agree.
Small planes lose a tremendous amount of “feel” at the handle with big lines, and they certainly do not penetrate nearly as well in the wind.  For me, the bigger the lines, the more airplane weight and engine power is required to offset the line bow in the lines when the wind starts to blow.  With smaller the lines, less airplane weight and engine power is required at the plane to get the “solid feel” and penetration back (read that “line tension”).  Small lines coupled to a light plane create a much more “big plane” feel.  Many people, including myself, who use .018” cabled lines, tend to use shorter lines even with big planes to control the line drag and bow.  Others use .015” solids to get more solid line tension with their large planes.  While I agree that they are superior, I hate solids.  I am barely able to keep a good set of cables, and I but them in quantity from Tom Morris!
Now, in 2009, that .40 cu in displacement cutoff for line size is out the window!  The new line size rules that will be used in 2009 are based exclusively on weight.
2009 Pull Test and Line Size Requirements
As you can see, .015” cables are allowed for airplanes from 40+ oz to 64 oz (a huge range of 24 oz!).
As you can also see, .018” cables are allowed for airplanes ranging from 64+ oz to 75 oz (a range of 11 oz?  Hmmmm… that’s weird… FYI:  Paul Walker flew his 100+ oz bomber for several years at the highest levels of competition using .018” cables without incident).
With the new rule, pretty much anything from a heavy Ringmaster to an average SV-11 with a PA 75 can be flown on relatively small .015” cabled lines.  Wow!  While I would not want to be a flyer that prefers the Patternmaster and all of its many derivatives, the Strega, or Cardinal due to the restrictive cutoff for line size (even though people have been flying these planes safely for three decades at weights over 75 oz) it is great time to build you’re the low tech “Low Tech World Beater” that will be explained herein.  It is important that this design stay well under 64 oz “ready to fly” for the LIFE of the plane.  Everyone must understand that airplanes will gain weight over time with heavy use, so if a design is close to the cutoff weight, which is bad.
My First Exposure to the Low Tech World Beater
My friend Doug Moon built a plane called the Bear 46.  Basically, it is Bob Geiseke’s oversized high tech Nobler, the “Bear 65” built with the two center ribs removed.  After the modification, the airplane comes out to be about 620 sq inches (I see it as about the size of the bigger Skylark).  It was originally designed for the LA 46, but since it has the full sized Bear fuselage (an important component of the total package) it still looks like a Bear 65.  As built, it came out terribly tail heavy with the lightweight LA 46 because Doug had built the nose like a full sized Bear 65, complete with the short 9” nose and the original tail moment.  On a lark, I gave Doug one of my Big Jim style ST 60’s and restrictive tube muffler to put in the plane.  I had been testing this combination on bigger planes and loved the run but it had only adequate power for a 70 oz plane.  I thought it would be perfect for the smaller plane.
Big Jim Greenaway followers would use the low compression ST engines using unrestricted (and loud) mufflers to get the “big power” needed to pull the very large Patternmasters, Stregas, Cardinals, Spitfires, etc.  Conversely, many of the tube mufflers on the market were developed for the HIGH compression ST 60 engines produced by Randy Smith and Big Art.  Many of these mufflers were also being used for schnuerle engines like the PA, or OS 45 SFR and 46 SF which really like to be restricted on the exhaust side.  These more restrictive tube mufflers have an exit hole closer to .25”, where Big Jim approved tube muffler would have an exit hole from 3/8” to ½”.  This was necessary to make the low compression engine flow the fuel and make the big power.  This Big Jim style low compression head and muffler with the large exit hole has been used in the Northwest for nearly three decades and was also used by Bob Baron to win the 1996 Nats.
With the combination of the low compression head coupled to a restrictive muffler we had a VERY *mild* package that would run very quiet at low RPM (7800 RPM), with a near PERFECT 4-2 break with no real propensity to wind up.  Interestingly, it would complete the entire pattern on 4 ½ oz of fuel.  Imagine the *BEST* ST 46 you ever saw (in your life) that used less fuel than a ST 46.  Once this engine and muffler was placed in the plane we had a plane that “appeared” to be a full sized plane from the side (which is all the judges see) with the airplane/wing drag of a 40-46 sized plane.
Well, in a nutshell, this is one of the BEST “low tech” combinations I have ever, ever, seen…ever.  The judges see a full sized fuselage, the wing is small (so it builds light) and the engine is basically LOAFING to pull the whole package….and oh, the sound was… well… magical.
All total, I think the whole plane is 48-50 oz trimmed with a ST 60 and tube muffler?  That is crazy.
The Time Machine
My friend Steve Fitton flies the Time Machine 60 powered by a Double Star 60 engine.  The Time Machine 60 is basically a 95% Big Jim Greenaway Patternmaster designed by Tom Dixon for Bob Baron.  These airplanes are right around 650 sq inches and typically build between 60 oz and 70 oz (as opposed to the full size Patternmaster that typically builds between 70 oz and 80 oz).  The Double Star 60 engine is a European version of the ST 60 with an ABC piston and sleeve, it has a low compression hemi head based on the Big Jim ST 60, and relatively restrictive muffler (sound familiar?).  This engine was at one time imported by Tom Dixon and was manufactured by the same factory that makes the Brodak 40. Steve has been using this airplane/engine combination for many years, and his setup is based on the setup recommended by Tom Dixon.  This is truly a “low tech” setup and Steve has it mastered.  He can actually hand flip his engine with his finger (like the good old days) without any fear it will rip off his finger.  He even has little marks on the exit hole of the needle valve that looks like a little clock.  After years of constant use, he sets the needle based on this little clock, and he can tell where the needle should be set for any given run or condition.  He can even tell how worn the plug is based on where the needle is set on the clock.  Now that is consistency.
Over the years, Steve has used both of the two modes described previously.  For many years he ran the “stompin 4 cycle” run and recently switched the “east coast run”.  His comments about both were that the “stompin” run was superior for consistency and was  superior in the wind, but lacked the “drive” at the top of the pattern of the hard breaking run.  As explained before, this is due to the fact that the “stompin” run uses only about 2/3 of the total output of the engine in an attempt to keep the engine running very rich.  Keeping the engine running very rich makes it behave in the wind.  Some of this power loss can be made up by using more nitro or reducing the size of the propeller, but only so much can be done before the “sweet” run characteristic of the engine is lost.
Later, Steve switched to a lower compression 4-2 run more indicative of the “east coast run” in an attempt to get more drive.  Ultimately the “hot mode” of any engine is going to produce more peak power than the “cool mode” even when the engine is limited with a drop in compression, smaller venturi, etc.  Steve expressed the wish to look at the Stalker 76 or Double Star 75 (if it ever comes out) for the Time Machine, as these are the closest to the original “classic” baffled stunt engines.  I suggested a completely different route, one similar to the original Time Machine/DS 60 concept developed by Tom Dixon, only more extreme.
Just Crazy Enough to Work
Here is the idea:  Take the smaller plane power to weight ratio to the extreme.  Now that weight is the only factor used for determining line size, we are primed to use large, extremely mild, low tech and (dare I say it) *lower power* engines in even smaller planes than previously thought practical.  It is the next inevitable step in the Tom Dixon Time Machine idea, and is the *flip* of the Bob Hunt sales pitch for the “high tech” tuned pipe of nearly 20 years ago.
Step #1:  Since the goal is to have an engine that can easily function deep in the “cool cycle” if we want it, we will acknowledge that we will need a little extra engine.   We will use a mild .60 sized engine with a muffler.  Consider the PA 61/65, ST 60, Double Star 60, Double Star 60 RE, or the Stalker 61/66 etc.
Step #2:  The engine will not be tuned for big power.  I know… you just did a double take.  Let me explain.  Stunt engines typically run with some kind of limiting factor within the engine.  Something has to “clip” the power of the engine to make it suitable the for relatively low speed use of stunt flying.  Typical limiting factors are the venturi, exhaust back pressure, head compression, internal port timing, port sizes, crank shaft internal diameter, etc.  Most of the best stunt engines use one or more of these factors to “clip” the power.  Use too many of these power limiters at one time and the power is “clipped” too much and the engine is considered a “wimp”.  Consider the Bear 46 example.  We actually took the ST 60 that had been heavily decompressed (originally designed to be used with a wide open muffler) and coupled it to a restrictive muffler.  Now, in its “wimpy” state it would be completely inappropriate for most large .60 sized planes.  However, it is completely appropriate for a .40/.46 sized plane and it runs “prettier” with a great deal more drive than the .40/.46, and would probably last indefinitely.  Note:  One other thing…”wimps” are consistent and typically indifferent to atmospheric conditions compared to their “gorilla balls” brethren.
Step #3:  Fuel consumption will be low relative to the size of the engine.  A low output .60 actually burns less fuel than a smaller engine running at max power, even when running in a “stompin” mode.  The hemi head ST 60 with the restrictive muffler used on the Bear 46 burns 4.5 oz of fuel to complete the pattern using the “east coast run”.  My PA 65 (sans pipe) burns 4 to 4.5 oz of fuel, even on a “stompin” 20% nitro run and appears to run even more indifferent to conditions the more exhaust is restricted at the outlet.  The Double Star 60 as delivered by Tom Dixon burns right at 5 oz of fuel, as does the Stalker 61/66.  Most people do not realize that many of the “classic modern” stunt planes that came out of the 1980’s and 1990’s were designed around the size of the fuel tank.  Most top stunt flyers were using metal stunt tanks of the standard dimensions that held 1 oz per inch.  Many of the top ST 46 ships were designed to carry 7” long metal tanks.  That meant that the nose would need to be 10.5” to 11” long to accommodate the tank and the engine.  Conversely, the tail moment would have to be long enough to turn it.  With the fuel tank limited to 5 oz (or 6 oz for the case of the RC clunk tank) the nose can be limited to 9.5”.
Step #4:  If you have a mild .60 stunt engine and you are only going to use 2/3’s of the power of the engine, then the math goes something like this:  .60 cu in x 2/3 = .40 cu in.  So, the experiment requires a plane that was designed to be used with a typical .40 stunt engine.  There are really few truly modern .40 sized designs out there.  Most true .40 sized designs are classic designs.  In my opinion, the standard for the modern .40 sized design is the Vector 40 by Randy Smith.  The Vector 40 was originally designed to be used with the relatively mild OS Max 40 FP.
Step #5:  Small planes are easier to build light.  If you read my “T-Rex” article in Control Line World a few issues back, you understand that the smaller plane is easier to build “light”.  In other words, the larger the plane, the *harder* it becomes to build the plane the correct weight.  This is due to the fact that surface area is not a linear function. I have a Brodak Vector .40 ARF myself.  My Vector 40 ARF with the obligatory LA 46 with the 5 oz tank weighs in at 44 oz complete ready to fly and these ARF airplanes have not a stick of ultra light contest wood in them.  Again, in my opinion, the *best* flying Vector 40’s are actually a little heavier at 48 oz to 52 oz, and that is in Texas air.  So if we could build a Vector 40 at 52 oz we would be OK.
Step #6:  Low tech is light.  If you add up all of the components used for the typical high tech, three-bladed pipe .65/.75 setup, basically you are looking at a 22 oz drive train (spinner, prop, engine, pipe, coupler, header, zip ties, 8 oz fuel tank).  Now take that and add the 8 oz of fuel consumed to complete the pattern, you have at least 30 oz of weight that you need to haul around before you ever glue two sticks together.  Even if you are light builder, that is lot of stuff to include in your next airplane.  Now compare that to the low tech 60 setup with a 2 blade propeller (spinner, prop, engine, muffler, 6 oz fuel tank) the total is closer to 22 oz fully fueled.  That is a weight loss of 8 oz.  A bushed .60 would be even lighter.
Step #7:  If we retrofit a ST .60/PA 61/65 in the place of the LA .46, we are only going to add a few more ounces than normal to the small airframe.  So, let’s compare the weight gain for substituting the mild ST 60 for an LA 46 in a Vector 40.  I will round up the weights…
The ST 60 is a weight gain of 2 oz over the LA 46.
The larger tube muffler is a weight gain of 1 oz.
The tank is a wash.
The nose of a Vector would not be appropriate for a .60 engine.  The nose moment would need to be extended ½” to accommodate the longer ST 60 type engine and the fuselage width would need to be changed to accommodate the wider engine.  I suggest using ½” x ½” maple beams with the large engine instead of the 3/8” x ½” beams normally used for smaller planes.  This is a weight gain of 1.5 oz.
The tail moment of the Vector 40 would be too short.  To balance the bigger, heavier engine, the tail moment would need extended to 17” or 17.5”.  This is an extension of about 3” and would result in a weight gain of ½ oz.
The stab/elevator *might* be too small.  For the sake of discussion, we will assume it is and add ½ oz to extend the span of the stab elevator 1” on both sides.
To make sure the plane “looks” like a big plane, we will add 1 oz for taller fuselage sides.  ½” of height added to the top and bottom of the fuselage sides will make a huge difference in the appearance of the size of the fuselage.  The tail moment will add quite a bit to the larger look.
Just to be fair we will assume we will use a larger propeller and spinner.  So, we will add one more ounce just to be sure.
So, the total is 7.5 oz…I think that is about it.
So, using my Vector 40 ARF as an example, we will total the weight gain.  My ARF Vector weighs in a 44 oz all up “ready to fly”.  Adding all of the things listed, we have a finished weight of a little less than 52 oz.  Is this too heavy?  Hmmmm?
It is in fact, *not* too heavy.  This equates to wing loading of 13 oz per sq foot.  If you compare wing loadings of larger “world beaters”, most of the 650 sq in airplane crowd build that have wing loading somewhere in the neighborhood of 13-14 oz per sq foot.   This equates to the typical SV-11, Legacy, Trivial Pirsuit, Time Machine, Saturn, etc in the range of 58 oz to 64 oz.  This is a completely normal wing loading for the most successful stunt planes.  In fact, most weigh more, and I think this is going to be apparent when everyone starts weighing their planes before every contest next year.
Let’s say you are stickler for “old school” wing loadings, or worse yet, you want to *paint* your Vector .40/.60.  Oh, no… now it is too heavy.  Well, then do this…change the rib spacing on the Vector approximately .25” to add 2” to each wing bay.  This will result in a increase in wing area of about 40 sq in and will allow 4 more oz to be added for paint, all without any real additional construction weight.
Did I mention we are talking about an ARF, and not a contest wood plane?  I contest wood plane could be built even lighter…think about it.
