Had an oddity happen last Sunday, first round of Advanced at the Western Canada Stunt Champs. Got to the H8, and the engine sputtered a bit during the first 8, and quit cold, just about the bottom of the 2nd outside. The setting was just fine...not rich or lean...just right, as usual.
It continued around to the tangent point, but I could see that was going to end badly, and cranked on full up. It did 3/4 of an inside, cleared the ground (barely) and landed. The fuel tank was about 1/3 full...it's a clunk, on a provile (sic). Ok, it was about 2/3 empty, Schultz.
So, I went and judged a round of Expert, and decided that I really needed to "do something" to make sure the sucker didn't flame out on me again. But what to do? I checked the glowplug, and it seemed to glow ok, but replaced it with a new one of the same type, Thunderbolt R/C Long. Even threw the old one out. Pulled the fuel hose/filter, and blasted the filter out both directions, tho it seemed to be clear. I then filled the tank, hooked the plane onto my Tom Morris stooge, fired it up and let it run the tank out. Various folks walked by and inspected it, as it ran, while I sat in the shade, over under the trees. Seemed to run just fine. I got my second flight in ok, and ended up 2nd, against a talented new flier, Dave McCheyne. Ok, but my first flight was much better, as far as it got...dang!
It was very odd to have a flameout like this. It's never happened before, in about 3 years of flying the same plane and setup. It's rather bugging me that I don't really know the exact cause. I did look down the venturi, checking for honey bees...
