  • July 20, 2025, 10:55:01 AM
Author Topic: OS .80 engine, why so popular?  (Read 1986 times)
« on: December 11, 2011, 03:52:12 PM »
I have a couple of these engines NIB. I was told they have the energy of a good .40.
If this is the case, why this? Seems popular to me.
http://www.ebay.com/itm/150713225490?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
CB
Offline Chris Wilson
Re: OS .80 engine, why so popular?
« Reply #1 on: December 11, 2011, 06:25:22 PM »
Why what Charles?
Its a 1967 engine that broke ground in its day and made more power than 40's of the same type and from the same time period.
It just seems like a big friendly lump to me! ;D
MAAA AUS 73427
Online Dennis Adamisin
« Reply #2 on: December 11, 2011, 06:30:05 PM »
The were the biggest & baddest of their kind in their era.  Probably ran the same RPM on a 9x6 as on a 14x6...
« Reply #3 on: December 11, 2011, 06:49:43 PM »
Could they work in CL?
I hope so, I have one in this CL model. Not sure any more if I should use it. Ther are better choices.
CB
Offline Mike Greb
« Reply #4 on: December 11, 2011, 07:27:47 PM »
I have seen two os 80's run, one in an rc biplane and one in a cl scale plane, both seemed rather lacking in power for their size.
« Reply #5 on: December 11, 2011, 08:14:10 PM »
One has to wonder if it was the airframes ........... or the power plant at fault here.
Honestly, I can't think of a reason why an OS 80H couldn't be pushed into successful stunt service as sheer power is not high on most fliers agendas.
MAAA AUS 73427
Offline Brian Hampton
« Reply #6 on: December 11, 2011, 08:41:05 PM »
Many years ago I built an RC model for my son based on my CL stunter (same wing and tailplane) which he powered with a new OS 80H and it performed brilliantly with a 14x6 prop and 80/20 fuel. Power was WAY more than any 40. Eventually he swapped it out for an Enya 80X which had noticeably more power but those engines are brutes anyway :).
Two rather neat features are that the carb can be turned through 180 degrees for inverted running which gives a choice of either high or low mounted tank or a simple venturi could be attached to the mount flange. The other neat feature is that the drum valve has an extra slot marked with an R for reverse running.
« Reply #7 on: December 11, 2011, 09:21:50 PM »
Back in the 70's early 80's they were used a lot in large R/C scale planes. I remember a guy from Lincoln Nebraska that had one in a heavy Sterling Stearman, and it flew it pretty well. Also had a friend with a large scale Cub that had one in it. They did turn a 14-6 prop very well. I doubt that there are many 40's that will do that.
Online Trostle
« Reply #8 on: December 12, 2011, 02:24:13 AM »
Did you not like the responses your received on the other thread that you started in the 4-Cycle section?
http://stunthanger.com/smf/index.php?topic=23909.msg229970#msg229970
« Reply #9 on: December 12, 2011, 12:57:08 PM »
Different subjects.
Got anything to share about this engine's performance?  ;D
CB
