  • July 08, 2025, 11:32:20 PM
Author Topic: WHATS THE TRICK TO GETTING THE BI SLOB TO HANG STILL  (Read 6981 times)
Offline kevin king
« on: June 09, 2024, 04:36:52 PM »
So whats the secret to getting this Fox 35, 10x6 propped Bi Slob to hang out on the line's?
Offline kenneth cook
Re: WHATS THE TRICK TO GETTING THE BI SLOB TO HANG STILL
« Reply #1 on: June 09, 2024, 04:58:53 PM »
               I personally prefer a 10x5 APC on my Bi Slobs. I like to start off a bit rich to the point it struggles to leave the ground. After a few laps and the fuel load burns off a bit and things start to lean up, I offer full up elevator. The elevator acts like a brake and the nose immediately rolls vertical. I don't go into a loop, I offer down elevator and I can offer up and down elevator which makes the plane do a bit of a dance as if the elevator is sweeping like a broom. I usually offer neutral at this point and it will hang as it slowly begins to ascend upwards. If it climbs higher than I want it to, I can offer full up elevator. This will quickly loop on itself and it will sink rapidly back down. One thing that can happen at this point is that it can roll back into the circle. I generally use more tip weight than normal to assist it rolling back out.
Offline kevin king
« Reply #2 on: June 09, 2024, 08:31:45 PM »
Thanks for the tips Ken. I will see if i can dig up a 10*5 APC.
Offline Dan Berry
« Reply #3 on: June 09, 2024, 08:42:18 PM »
Or a 10-4. Needle valve setting is important
« Reply #4 on: June 10, 2024, 09:50:46 AM »
   Yes, try a flatter pitched prop and try several different brands if you have them. When the nose goes up, the engine leans out and should make more power. With a 6" pitch prop it's too much load and it won't break correctly and starts to sag. The flatter pitch lets the engine break and run more clean, and will stay that way in that attitude. Most guys I see usually have the needle set to where it just slightly climbs when "slobbing" and that helps with line tension. Jim Lee is very good with a Slob. We had a club member here in St. Louis, years ago, named Emile Kedro. Some of you old timers who used to fly here may remeber him. Big guy with a deep, gravely voice. Emile could write his name in the sky with a BiSlob!! But if he ever entered stunt, he flew beginner!! Emile just could not relate to flying the pattern as it is supposed to be. He was a genuine character and fun to have around, and I miss him a lot!!
    Maybe watching some YouTube videos may help you. I can't imagine that several have not been posted there.
Offline Fred DiMaria
« Reply #5 on: June 12, 2024, 09:10:39 PM »
A breeze helps and you have to hover down wind. Also I added a little tail weight, but do it very gradually. Also needle setting is important as previously mentioned- has to be fairly rich. I use a 10/5
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #6 on: June 13, 2024, 12:33:40 AM »
treat that thing at the back of the airplane as a speed brake.  I like to do a tight loop to scrub off speed, then point the noise up.  If it climbs, do another ill till it just barely climbs.
Dave Siegler
NE9N extra class
AMA 720731
Online Leonard Bourel
« Reply #7 on: June 13, 2024, 06:54:02 AM »
Hey Kevin go to youtube and type in the search bar Bi slobs at the bean field you may find some good demos there Once you learn to slob you will have a blast soon Len
Offline Brad LaPointe
« Reply #8 on: June 13, 2024, 11:32:21 AM »
I find that you can really try more extreme things with a borrowed Slob .
Brad
Offline kevin king
« Reply #9 on: June 13, 2024, 12:24:36 PM »
Brad
😂😄 Good one Brad! Thanks  everyone.
Offline Louis Rankin
« Reply #10 on: July 13, 2024, 05:39:53 AM »
APC 10.5X4.5, set for 4-2-4 break, practice.
Louis Rankin
Somerville Tennessee
AMA 10859
Offline Matt Curtis
« Reply #11 on: July 20, 2024, 01:57:19 PM »
Thanks for the tips.I think I will convert mine back to use the fox .35 as it is electric now and I can't hover it. It does say in the flying models article that anything but a fox .35 is heresy.
Offline Mike Hazel
« Reply #12 on: July 20, 2024, 06:06:31 PM »
I have a Bi-Slob which according to the last post would qualify as a heresy......  scaled up slightly and powered with Double Star 60.   Yahoo!
