  • June 28, 2025, 06:14:14 AM
Author Topic: What year Fox?  (Read 4062 times)
Offline Ara Dedekian
  • Ara Dedekian
What year Fox?
« on: March 01, 2021, 08:58:44 AM »
       Dug this Fox engine out of some forgotten stuff. It appeared to be in good condition so I cleaned it up and ran it, as is, on a prime. Looking at the front housing I assumed (hoped) it had roller bearings but its bushed with a rather thin bronze bearing. Would this be an econo 35 Combat engine from the late sixties?
       Ara
« Last Edit: March 01, 2021, 06:02:55 PM by Ara Dedekian »
Offline Tom Luciano
Re: What year Fox?
« Reply #1 on: March 01, 2021, 09:20:25 AM »
I think that's a 63/64 35x combat engine with a sport 36(early 70's) head on it.
Tom
AMA 13001
Offline Dwayne Donnelly
Re: What year Fox?
« Reply #2 on: March 01, 2021, 10:09:43 AM »
Early 60's Fox Rocket 35 with a 36 head.
Offline Steve Lotz
Re: What year Fox?
« Reply #3 on: March 01, 2021, 12:03:22 PM »
It probably has the roller bearings but they would be in the rear.
  • Ara Dedekian
Re: What year Fox?
« Reply #4 on: March 01, 2021, 12:42:32 PM »
       Thanks for all the replies.
       I didn't take it apart so I couldn't see what was behind the crank flange. I'll look again.
       Ara
Online GERALD WIMMER
    • Auckland Free Flight Club
Re: What year Fox?
« Reply #5 on: March 01, 2021, 07:14:28 PM »
Hello I have a Fox 36 the other way round a 36 Sport/slow combat engine with 35X head for raised compression, runs well on a vintage combat plane.
Regards Gerald
Offline BOB ALLAN
  • Ara Dedekian
Re: What year Fox?
« Reply #7 on: March 02, 2021, 03:12:46 PM »
https://www.rcgroups.com/forums/showthread.php?1402733-Vintage-Glow-Engines/page47#post18176405
      I ended up tearing it down after receiving all the above info. Steve was right, my engine has a single rear bearing. So the selectively plated crank, the single rear roller bearing and the front stiffening webs show it's a 1962/1963 Fox 35x sport/combat motor, version II as per the P.G.F. Chinn review. I found a couple of stock heads whose combustion chamber measurements and shape matched the Fox 36 head.
      Ara
Online C.T. Schaefer
Re: What year Fox?
« Reply #8 on: March 03, 2021, 06:00:30 AM »
Mystery solved!
  • Ara Dedekian
Re: What year Fox?
« Reply #9 on: March 04, 2021, 07:04:12 AM »
      A follow up:
      I went back into the box of rusted, dismembered and discarded engines and was able to build a working (test stand) example of the early version of the 35X Blue Ribbon Special. This is the one illustrated in the above Fox magazine ad with two roller bearings and no stiffening webs. Also found was a partial model of the predecessor of the 35X, the split case Fox Rocket 35.
     Ara
Re: What year Fox?
« Reply #10 on: March 04, 2021, 08:40:04 AM »
Anyone know the difference between the split case Rocket 35 and the 35X? Other than the obvious...lol
Offline BOB ALLAN
Re: What year Fox?
« Reply #11 on: March 05, 2021, 06:23:07 PM »
I think the engine you are referring to is known officially as the FOX 35 Series III Combat Special. These first appeared in 1960, and again in 1961 with both these sporting the Rocket emblem on the bypass, and both had detachable front housings. The last (1962) Series III CS was the final one in that series with bolt-on front end, but did not have the Rocket emblem. The first FOX engine to have both the detachable front as well as the Rocket emblem was the 1960 29X. There were 3 FOX Rocket 35's (1959 - 1960) but all of these were plain bearing with non-detachable front housings, and all 3 had red heads. The first variant of the 35X "Blue Ribbon" followed on from the last of the Series III CS's.
http://sceptreflight.com/Model%20Engine%20Tests/Fox%2035%20Combat%20Special.html
Re: What year Fox?
« Reply #12 on: March 06, 2021, 05:20:55 AM »
This is a fun thread. These Fox motors are part of our own history and they are still kickin'.  The '61 CS as well as many Fox motors had a sensitive crankshaft when pressed hard with the nitro.
PS   Don't forget the Rocket .40
PPS   I need a crank for a 1956  .29R  AKA  'The Bathtub'   TS
Offline BOB ALLAN
Re: What year Fox?
« Reply #13 on: March 06, 2021, 05:37:18 PM »
  • Ara Dedekian
Re: What year Fox?
« Reply #14 on: March 06, 2021, 06:34:27 PM »
       Now that I know more about the lineage of early Fox engines I went through my refurbished stuff to see what else was there. I couldn't believe what I found! (Us old guys get forgetful)
       Two more split case 35's; one on the Nemesis II with the Rocket logo and the other against the leading edge. From right to left, three more 35 Blue Ribbons, early and late versions, two 35x RC's, and a bushed .29 RC. Except for the two obvious ones, all work. The Nemesis/35 was flown this past Fall.
       Ara
Offline BOB ALLAN
Re: What year Fox?
« Reply #15 on: March 06, 2021, 09:10:17 PM »
Interesting engine on the L.H. end - the raised head and the capacity numbers machined off, signify it's a 40. The American Model Engine Encyclopedia does not list any FOX 40 with the 4A triple jet carb - possibly a 40 sized "Special" made on either the 1965 36X BB, the 1970 36X R/C or the 1971 36X Profile Carrier Special ?  Only the last 2 are listed as being available with the 4A carb. Does it have a divider (or web) in the exhaust stack ? If not, it's probably the '65 36X BB blown out to 40 size.
  • Ara Dedekian
Re: What year Fox?
« Reply #16 on: March 06, 2021, 11:24:20 PM »
      Bob
        Here's some photos. The case is actually spotfaced with a '29' stamped in. I measured TDC and BDC from the cylinder top. Not sure if that's how it's done for computing volume. The cylinder flange is ~.150" thick. The crank is sleeved in the front, haven't checked the rear. This engine was in a Goldberg Buster with the throttle wired open when I received it.
        Hope this helps.
       Ara
  • Ara Dedekian
Re: What year Fox?
« Reply #17 on: March 06, 2021, 11:29:35 PM »
   More photos
Re: What year Fox?
« Reply #18 on: March 07, 2021, 03:12:57 AM »
Hello
I believe the 29X RC is really a 36XRC as the bore is to large for a 29 and they share the same stroke. It is normally possible to look in the exhaust and tell a 29 from a 35 or 36 by the much thicker cylinder liner.
Regards Gerald
Re: What year Fox?
« Reply #19 on: March 07, 2021, 05:30:32 AM »
That sure looks like a .40 sleeve.  Expect anything with a Fox!  Lots of interchangeability.
  • Ara Dedekian
Re: What year Fox?
« Reply #20 on: March 07, 2021, 09:25:16 AM »
       C.T., Bob, Gerald
              Your eagle eyed observations were correct. I remeasured and the volume computes to .39762 cu in. IT'S A .40! But it seems to be a modification with parts that don't fit; the bottom end of the rod rubs against the case. Hard to imagine it came from the factory with those parts. But, the engine seems to have a good amount of run time on it, the sleeve shows a lot of caked on residue. It'll have to go back on the test stand to see what's going on.
     Ara
Offline pmackenzie
  • Pat MacKenzie
Re: What year Fox?
« Reply #21 on: March 07, 2021, 09:43:57 AM »
       C.T., Bob, Gerald
     Ara
That rod looks like it is in backwards to me.
MAAC 8177
  • Ara Dedekian
Re: What year Fox?
« Reply #22 on: March 07, 2021, 12:11:57 PM »
      I also noticed that but there's a step on the crank pin that mates into a recess on the back side of the rod, so it's in correctly.
      The connecting rod was stuck to the side of the wrist pin from dried oil and couldn't center itself which might have caused the galling.
      I freed everything up, reassembled it as I found it and gave it a quick run up on the test stand. It worked! But the mystery of what this is, 40 innards in a 29 marked case, remains.
      Ara
Offline BOB ALLAN
Re: What year Fox?
« Reply #23 on: March 07, 2021, 02:27:14 PM »
Well, it might be a 40 now, but at least the "29" stamped on the spotface tells us that the engine started out as a 1970 29X R/C, which did come with the triple jet 4A carb.
