  • June 25, 2025, 03:51:36 AM
Author Topic: Marietta Contest Results  (Read 1352 times)
Mike Griffin
« on: May 17, 2010, 06:14:50 AM »
Here are the pictures I took of the score board at Marietta
Offline Steve Fitton
Re: Marietta Contest Results
« Reply #1 on: May 17, 2010, 11:42:17 AM »
Note to self. ALWAYS test fly any plane that has been hanging on the wall 14 months. DUH.  Remove ALL Fox needle valves and replace with PA type.  They don't leak air and will hold a setting so the engine won't up and die in the loops.  LL~ LL~ LL~ H^^
??  I thought your Forerunner had an LA-46 in it?  How could it have a Fox NVA?
Offline andrew stokey
« Reply #2 on: May 17, 2010, 05:48:32 PM »
TY,
Pat J. has foam wings for the Forerunner at a reasonable price.  I gave him the dimensions a year or so ago.
Maybe you want to build another one ,as it is a good flyer. Mine has been going for about 6 yrs.
« Reply #3 on: May 17, 2010, 07:54:22 PM »
Ty,
That's too bad.  BUT I did give you the wrong info.  It's Crist that has the wings.
I have built 3 Forerunners and lost one to lines hooked up bassackwards.
If you need more info, call me.  I'm in the directory ( PAMPA).
Maybe I'll see you at Richard's.
