........but don't build that Ringmaster from a Sterling kit, otherwise all you're going to have is a winged tether car.
I don't know about that. We (my hot-shot buddies and I) used to think the same thing. But the triggering incident in the "small stock engine" experiment was a guy showing up at the old Napa field with a box-stock kit Ringmaster, complete with full opaque dope finish, powered by a 15FP. After getting the handle set to give about +-15 degrees elevator motion with full up and down wrist motion, it flew just fine. In fact it was so good that David and I both agreed it was the best-flying Ringmaster we had ever flown. Full patterns in decent wind were no problem, and the controllability was excellent. In fact, this was one of the few Ringmasters around here that David *hasn't* crashed at some point. It was miraculously better than any Fox 29/OS30/Fox 35 powered Ring I had flown up to that point. Far from perfect, but way better than average.
As far as I can tell, a modern pretty strong 15 is the prime choice for a Ringmaster. A Veco 19 or 20FP will work, but you have to continually fight the tendency to excess speed. With the 15, you just crank it up and let it go, and it will be brik but flyable, and can't run away because it's already pegged out. Making it lighter will certainly help but even a stocker can fly reasonably well with a strong 15. An LA is probably not enough to make it work, but the Norvel ought to be pretty strong.
