  • July 16, 2025, 05:23:52 PM
Author Topic: What is this engine?  (Read 1611 times)
Offline Rick Bollinger
  • AMA 931589
« on: December 16, 2012, 02:13:16 PM »
Can someone tell me what I have here? I got it in a box of stuff several years ago and have no clue of size, make or intended use.
It has been ran, a little gummed up, but looks to be in fair shape. It weighs 7.2 Oz Thanks Rick
Rick Bollinger
AMA 931589
Offline Larry Lindburg
Re: What is this engine?
« Reply #1 on: December 16, 2012, 02:24:14 PM »
My guess is a Fox 25 BB or a Fox 19 BB.
AMA 95707
Offline dennis lipsett
« Reply #2 on: December 16, 2012, 02:32:59 PM »
Larry, your right. These are among the best engines that Duke ever made. I'm not talking stunt wise but they are potent and durable. The 19 was capable of keeping up with most of the 21's available in the early days of R/C Combat easily flying a 36 inch VooDoo type wing at over 86 mph on radar.
dennis
« Reply #3 on: December 16, 2012, 03:06:28 PM »
Yep, that looks just like he Fox .25 I am braking in.  It is going to power the Estes Stuntin Ringmaster I am finishing up.  Great little engine on the bench so far and starts very easily.
Offline Chris Wilson
« Reply #4 on: December 16, 2012, 04:21:36 PM »
Yep.
MAAA AUS 73427
ChrisSarnowski
« Reply #5 on: December 16, 2012, 04:36:24 PM »
More likely the 19bb and not 25bb, but to be sure you would have to measure bore/stroke.
The 25bb usually has 25BB stamped on the right mounting lug as you look at the engine from the front.
The 19bb has bore .650 stroke .600 while the 25bb has bore .680 stroke .680
I have the same old engine as you which I believe to be the 19bb. The gas passage in the crank is not as large as the 25bb.
I noticed this when I pulled the back plates off both my 19bb and 25bb.
-Chris
  • AMA 931589
« Reply #6 on: December 16, 2012, 06:06:30 PM »
Thanks everyone, Got out the dial indicator. I have no way to keep it completely stabilized but it is definitely closer to .600 than .680. So it must be a 19. Now just to decide what to put it on.
Rick Bollinger
AMA 931589
« Reply #7 on: December 16, 2012, 09:19:15 PM »
Chris
Haven't noticed this, Chris. I have 2 of each displacement and none of them are marked. In fact, I've never even seen one marked "19" or "25"..
« Reply #8 on: December 16, 2012, 11:57:53 PM »
It will fly a Ringmaster quite nicely.  Or anything in that size/weight range.
ChrisSarnowski
« Reply #9 on: December 17, 2012, 05:43:27 AM »
I don't think they ever marked the 19BB but at some point they started marking the 25BB.
See the attached picture, now you have seen one marked 25BB !!!! (sorry if it is a little blurry).
Measuring bore/stroke is the best way to determine the size of the unmarked engines.
-Chris
