General control line discussion => Open Forum => Topic started by: GonzoBonzo on November 19, 2013, 06:24:17 PM
...of this months AMA publication Model Aviation? Some sort of OT stunt. Nice looking.
TIA
Gonzo
I was wondering the same, nice looking design. y1
If it is the November issue, it is the Legacy 40, a Brodak kit.
Thanks Allen. I was kind of thinking Legacy but I thought the wing looked like it had too much taper. The canopy threw me a little too.
Hmm, I've got a NIB Legacy .40 short kit, maybe I should get to building it... ;D
Yes Allen, the blue, and white one. What threw me off was the apparent thin wing, and sharp leading edge. I guess pictures can be deceiving. I should have known better, as I have the kit too, and it is in que to be built shortly.
The plans show more flap than elevator, is this correct? Or, should I swap the elevator, with the bellcrank pushrod on the flap linkage which would give it 1 to 1?
Gonzo
Sharp leading edge is due to builder's choice and the thin wing is a camera perspective. If you look at the plans, I believe you will find a very modern airfoil. I am tempted to build one with landing gear in the wing and a piped .40 PA for power. This is a 565 square inch wing and Jim Aaron had a 575 wing with a PA .65 in it. I think it would be an excellent PAMPA bird of prey.
Allen
I was wrong on both the areas of the wings and corrected that. Thanks Steve, old timer's disease is setting in quick.
Allen
Sounds like a winner to me.
