General control line discussion => Open Forum => Topic started by: Andrew Tinsley on April 10, 2014, 07:47:29 AM
Trawling through some searches on Stunthanger, I came across Goop, which is some sort of glue / sealant. I have never heard of it this side of the pond and I assume it is local to the US. Can anyone describe it so that I can try to source something similar in the UK?
Andrew.
y1 y1 y1 y1
Goop, from what I remember it removes sticky stuff from surfaces.
Have a good day. #^ #^ #^
Gene
H^^ H^^
Goof Off is the removal product. Goop is an adhesive that stays flexible after curing. The first time I saw it was when someone had used it to repair some old boots. Heavy, thick, and strong.
It's clear, sticky, and has a strong chemical smell like contact adhesive (use in a well ventilated place).
I think Shoo Goo is the same stuff, which I'm sure is as much help as the name "Goop".
Shoe Goo is made by the same Co. that makes GOOP, Eclectic Products, Inc.
I've used the shoe repair glue, but model airplanes?
http://www.homedepot.com/b/Paint-Duct-Tape-Glues-Epoxy/Amazing-Goop/Glue-and-Epoxy/N-5yc1vZc5dkZ725Z1z0t5fs
It is big in the RC boating world. My hobby back in 1994. Seals better than silicone adhesives and does not out gas ammonia. Used to watertight the electronics. Silicone sealers tend to corrode the electronics Shoo Goo does not. It also works great on tennis shoe repair. It is found in sporting goods stores. I have some on hand but have never used it on a U-control aircraft.
Goop and Shoo Goo are also used to build battery packs with NiCad and Nickle Metal Hydride cells. Also used to repair cracks in plastic car bodies. Originally intended for repairing sneekers and running shoes. There is also a Goop that is a creamy type hand cleaner.
I use shoe goo to reattach head badges to re painted bicycles. Excellent metal to metal / metal to paint adhesion in low stress applications.
Jim
I use "Plumbers Goop" on my planes. It is thinner that the other Goops and works well gluing plywood to fiberglass such as a serve tray to a FG fuse. ( I know that's RC but what the heck)
And the best part is that it can be peeled off if necessary.
Bad news is- It won't sand. Don't even try! n1
Jerry
Thanks guys,
I looks as though there isn't an equivalent of Goop in the UK. Special thanks to Steven, who tells me that Home Depot do it. Next time I am in Boston (actually Cambridge), I shall do my usual visit to Home Depot and this time collect some Goop.
I was interested in the stuff as it has been recommended in past threads, for sealing leaky Cox reedies. Apparently it seals the leaks and doesn't attack the alloy like regular silicone. I am told that silicone glue is also good in this application, but I have not yet found it in the UK (just not looking in the right place!). I use a blue product called Hylomar for fixing pesky reedies, but I am always open to new ways of fixing the little critters!
Thanks again,
Andrew
I know that guys use Goop to fabricate canisters for holding balloons used for 1/2A fuel tanks.
BIG Bear
RNMM/AMM
Try searching for E-6000 adhesive. It is a very similar product to Goop and is manufactured by the same company. It shows up on Amazon UK. It uses a different solvent than Goop but has similar qualities. I have used it in thhe past and has a tenacious flexible bond. I hope this helps.
Thanks David,
I was hoping that someone could pinpoint a similar product that was available this side of the pond! I will give it a try!
Many Thanks,
Andrew.
I have fiixed several pairs of shoes and sneakers with it, and it seems to do the job very well. I wonder how it would work for sealing needle valve spray bars to the venture. Don't know if it is fuel proof or not but looks like it would be. Smells way better than silicone.
HINGES!!!
Take the control surfaces, chamfer the mating surfaces at 45 degrees, stabilize the surfaces and align them, apply goop to the inside of the chamfer and allow dry. Instant hinge! This is done very frequently on foam construction airplanes made from things like foam poster board and fan fold foam insulation.
The problem is there is resistance in the elasticity of the goop film, which is no problem for servos...
If you want to build a dirt cheap electric model foam poster board and/or thin extruded insulation might be the way to go instead of getting "expensive" depron and specialty foam materials.
Uhu-por (I think is how it is written) is supposed to be a similar product that is not readily available in the USA.
Phil
UHU Por is quite different from Goop.
Por is thinner and more of a contact adhesive that dries quite quickly.
Goop is slower but has better hold. Goop is better for building from EPP, Por from Depron. (I think Goop might melt Depron?)
Por can sometimes be found in Michael's craft stores as UHU Creativ for Foam
Google'ing "Goop adhesive in England" turned this up:
http://www.amazon.co.uk/Amazing-Household-Adhesive-Sealant-1-Ounce/dp/B000BQPIOQ
Hello Pat,
It seems that the Amazon supplier is out of stock, I was getting quite excited too!
Thanks for the link I will keep an eye on it.
Andrew.
I have used a blue gasket material (comes in a tube Permatex is the Mfg?) from the auto parts store to seal 1/2A tanks & back plates of larger engines. They also make a high temperature sealant that I have used with head gaskets.
Hello John,
That sounds suspiciously like Hylomar gasket material. It certainly is good stuff, maybe a replacement for Goop this side of the Pond?
Andrew.
Goop and its variants are fuelproof. I use it to seal tanks made from plastic bottles and film cans.
Also look at Zap products "Zap-a-dap-of-Goo", a thinner version that is actually easier to use. Tower and Global at least should carry it.
In addition, I coated the toes of an old pair of shoes with the Shoo Goo, and haven't worn through it in years of kneeling starting engines. y1
Yes, exactly, I have a pair here I repaired with it at least 20 years ago and still leak tight
I guess I need to take a picture, but while putting the big bottle of hand soap on the shelf, I found a can of GOOP Hand Cleaner. It is kind of like a gel that you rub all over your hands and then rinse off with water.
Come to think of it, I have some of that too.
