  • July 10, 2025, 09:24:59 PM
Author Topic: What engine is this?  (Read 2684 times)
Online Robert Zambelli
« on: March 22, 2015, 01:30:13 PM »
Someone gave me this beast. New, never mounted or run.
Bore: .867, Stroke: .772, Displacement: .46, Weight: 13.9.
I'm pretty sure it's an Evolution but that's all I know.
What can you tell me about it?
Offline James C. Johnson
Re: What engine is this?
« Reply #1 on: March 22, 2015, 01:42:04 PM »
Must be an early Evolution TPS Alpha Trainer Engine ... they came with a special three bladed prop on the Alpha 40 Trainer ..
JJ
Offline Richard Imhoff
« Reply #2 on: March 22, 2015, 02:32:27 PM »
If I remember the ones with the "a" on the castings is a .45  not a .46 and has a different bore / stroke than a .46. If you look up parts they show two different cylinder/piston sets for the two different engines.
 It Was sold as a combo with different airplanes they sold.
Dick Imhoff  AMA 58502
Combat, Racing, Stunt, and big time fun flyer, and Maybe a bit of carrier.
Mike Griffin
« Reply #3 on: March 22, 2015, 03:42:31 PM »
Judging by the weight Bob, I would say it came out of 1957 Case Tractor.  ;D
Offline Douglas Ames
« Reply #4 on: March 22, 2015, 04:04:34 PM »
Somebody on here took an Evo .36 (similar) and machined all the fluff off.
Not a bad engine, really. "Quality" Chinese.
OS also made a trainer engine - OS .46 FXI
AMA 656546
Offline Garf
    • Hangar Flying
« Reply #5 on: March 22, 2015, 07:04:25 PM »
I have one. I converted it to C/L and have it in a Dreamer Bipe also converted to C/L. It has the power of a 60. It turns a MA 11-7 3 blade.
Offline Chris Wilson
« Reply #6 on: March 22, 2015, 07:46:38 PM »
JJ
Yep -
MAAA AUS 73427
« Reply #7 on: March 22, 2015, 08:47:03 PM »
I've always been curious about the trainer prop. - 3 blade and low pitch. Has anyone tried it for Stunt?
I've seen them at the LHS.
AMA 656546
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #8 on: March 23, 2015, 02:14:01 PM »
I think Joe Gilbert tried one flight on an airplane of De's with an OS 40 4S and the 3 blade Evo prop and it would barely do a wingover. Not sure what happened to the prop but if it's still around I am sure it can be had pretty cheap.
« Reply #9 on: March 23, 2015, 03:39:14 PM »
Lol, ok... I guess it was designed for the full throttle R/C crowd.
AMA 656546
« Reply #10 on: March 23, 2015, 06:35:54 PM »
Actually, from watching a plane fly with that prop(RC) it was designed to limit the top speed the prop could give.  For beginners in RC a plane get get pretty far away way faster than they can react.
Online wwwarbird
« Reply #11 on: March 23, 2015, 07:40:20 PM »
 There's a reason they gave it to you. ;)
« Reply #12 on: March 24, 2015, 12:50:05 PM »
Yes the supplied prop is for the beginners in RC.  It makes for a narrow speed range.  Need enough pitch to get air speed and will slow down for landings.  Some still don't believe that a prop at idle acts like an air brake.   It is also good for training on CL as the speed is not that great and the student doesn't get dizzy so fast.  It is made for beginners.   Remember the first time you flew a plane with a 10-6 prop and wondered was it was so fast unless you did it like I like to do,  set the needle rich just so the plane is fast enough to fly and also it doesn't fly as long.
Offline Garf
    • Hangar Flying
« Reply #13 on: March 26, 2015, 04:31:22 PM »
Evo 46 conversion.
Offline Larrys4227
« Reply #14 on: March 26, 2015, 04:57:07 PM »
That engine EVO/A also came on the early Hanger9 P-51 ARF's w/radio. I still have it .... hanging in the garage. It really came alive with a 2-blade and one of those canister Tower pipes.  Hundreds of flights on it .... excellent engine.
