General control line discussion => Open Forum => Topic started by: RandySmith on December 11, 2006, 11:44:18 AM
Title: What CL Stunt Judges should look for
Post by: RandySmith on December 11, 2006, 11:44:18 AM
Greetings all
The desription below (from our AMA rulebook) in addition to the Judges training guide used at our US NATs. is the only ones that should be  used by any judge working an AMA contest in CL Precision Aerobatics.
Unless there is a pre annouced differant system being used.
It is  VERY important to try and  keep a "universal" set of  guidelines that can be  used  all over the US. and  NOT  to have lapses  back into regional or  state interpretations of the rules. This  is  NOT directed  at  any one  person so please take this post as it was, and is  intended to help us  all keep the  rules the same  for  everyone.
There has  been  thousands of hours put in by  many many people  trying to help us  get and  keep  Cl Stunt judging  consistant from  state to state.
Regards
Randy Smith
13.1. Takeoff. A correct takeoff consists of
the model rolling smoothly along the ground for a
distance of not less than 4.5 meters (14.8 feet), but
not greater than one quarter of a lap. The model then
rises smoothly into the air with a gradual climb and a
smooth level-off to normal flight level over the point
at which the model commenced its ground roll. The
model continues on for two (2) smooth laps of
normal level flight to point of original level-off.
Maximum 40 points. Minimum 10 points.
Errors: The model bounces or becomes airborne too
soon, or too late. Takeoff, climb or level-off is not
gradual and is smooth. Level-off occurs too soon, or
too late. Level-off and normal flight level are not
CLA-6
within a height of 1.2—1.8 meters (3.9—5.9 feet).
13.2. Reverse Wingovers (One Required).
Correct reverse wingovers are judged when the
model starts from normal flight level, makes a
vertical climb and dive, passing directly over the
flier’s head, cutting the ground circle in half, and
recovers in an inverted position at normal flight level.
The model continues for half a lap inverted, to the
starting point, then makes a vertical climb and dive
over the center of the circle from inverted flight,
recovers at normal flight level. All turns to and from
normal level flights shall be of approximately 1.5
meters (4.9 feet) radius.
Errors: First half: The model starts at other than
normal flight level, wobbles when going into climb
or turn exceeds 2.1 meters (6.9 feet) radius. The
model does not cross directly over the flier’s head.
The model does not cross the circle in a straight line.
The model wobbles or recovers at other than normal
flight level in an inverted position or turn exceeds 2.1
meters (6.9 feet) radius. The model does not cut the
circle in the same position and direction in the second
part of the maneuver. Second half: Scored same as
first half, reversing the entry and recovery positions.
13.3. Consecutive Inside Loops (Three (3)
Required). Correct loops are judged when the model
starts from normal flight level and makes a series of
three (3) smooth, round loops, all in the same place
with the bottoms of the loops at normal flight level
and the tops of the loops with the line(s) at 45
degrees elevation. The model then continues for
another half loop, recovering inverted and descending
to normal flight level, flying two (2) laps before
being judged for inverted flight. Maximum 40
Errors: Loops are rough and irregular (i.e., egg -
shaped, hexagonal, etc.). Bottoms of loops are not at
1.2–1.8 meters (3.9–5.9 feet) height. Tops of loops
vary more than 0.6 meter (2 feet), plus or minus, of
the 45 degrees elevation point. Second and third
loops vary more than 0.6 meter (2 feet) from the path
of the first loop.
13.4. Inverted Flight (Two (2) Laps).
Correct inverted flight is judged when the model
makes two (2) smooth, stable laps at normal flight
level.
Errors: Height is not 1.2—1.8 meters (3.9—
5.9 feet). Height varies more than 0.6 meter (2 feet).
13.5. Consecutive Outside Loops (Three
(3) required). Correct loops are judged when the
model starts from inverted position at normal flight
level and makes a series of three (3) smooth, round
loops, all in the same place, with the bottoms of the
loops at normal flight level and the tops of the loops
with the line(s) at 45 degrees elevation. The model
CLA-7
then continues for another half loop, recovering at
Errors: Loops are rough and irregular (i.e., eggshaped,
hexagonal, etc.) Bottoms are not at 1.2—1.8
meter (3.9—5.9 feet) height. Tops of loops vary more
than 0.6 meter (2 feet), plus or minus, of the 45
degrees elevation point. Second and third loops vary
more than 0.6 meter (2 feet) from the path of the first
loop.
13.6. Consecutive Inside Square Loops
(Two (2) required). Consecutive inside square loops
are judged correct when the model starts from normal
flight level and flies a square course consisting of
two (2) loops, each with four (4) inside turns of
approximately 1.5 meters (4.9 feet) radius and
straight sized segments with bottom segments at
normal flight level and top segments as inverted level
flight at 45 degrees elevation. The two (2) bottom
corners are equal and so are the two (2) top corners.
The maneuver begins and ends with the model in
level flight at the point of start of the first turn.
Errors: Model wobbles on turns. Lower height is not
between 1.2—1.8 meters (3.9—5.9 feet). Upper
height is not within 0.6 meter (2 feet) of the 45
degrees elevation point. Turns are not precise and
exceed 2.1 meters (6.9 feet) radius. Sides of loops are
not equal. Second loop is not in the same flight path
as the first loop.
13.7. Consecutive Outside Square Loops
(Two (2) required). Consecutive outside square loops
are judged correct when the model starts from level
flight at 45 degrees elevation and flies a square
course (starting with a vertical dive) consisting of
two (2) loops, each with four (4) outside turns of
straight equal sized segments with bottom segments
inverted at normal flight level and top segments as
level flight at 45 degrees elevation. The two (2)
bottom corners are equal and so are the two (2) top
corners. The maneuver begins and ends with the
model in level flight at the point of start of the first
turn. The model recovers into normal level flight.
within 1.2—1.8 meters (3.9—5.9 feet). Upper height
is not within 0.6 meter (2 feet) of the 45 degrees
elevation point. Turns are not precise and exceed 2.1
meters (6.9 feet) radius. Sides of loops are not equal.
Second loop is not in the same flight path as the first
loop.
13.8. Consecutive Inside Triangular
Loops
(Two (2) required). Correct triangular loops are
judged when the model starts from normal level
flight and flies a triangular course, starting at the base
turn. The three (3) sides of equal length and the three
(3) corner angles of equal size. The top corner must
be placed at 45 degree elevation. The second
triangular loop must be flown in the same flight path
as the first one. All corners must be smooth, precise
and of approximately 1.5 meters (4.9 feet) radius.
CLA-8
Errors: Model starts at a height other than between
1.2—1.8 meters (3.9—5.9 feet). Turns are rough and
wobbly or exceed 2.1 meters (6.9 feet) radius. Peak
of second turns is not within 0.6 meter (2 feet) of the
45 degrees elevation point. Sides are wobbly and not
equal in length. Second loop is not in the same flight
path of the first loop.
13.9. Horizontal Eights (Two (2) required).
Horizontal eights are to be entered and completed at
the intersection point of the circles and exit at the
same point. The inside loop must be flown first.
Correct eights are judged when the model makes two
(2) eights, each consisting of two (2) round circles or
loops of the same size, tangent to each other, and in
a horizontal line. The model must enter the eight
from normal flight level and be vertical at the
intersection point of tangency of the circles. The
eights must be symmetrical. At the top of each circle
the model must be at the 45 degrees elevation point;
the bottoms of circles must be at normal flight level.
Errors: Model is not vertical at entry. Model at top
of circles is not within 0.6 meter (2 feet) of 45
degrees elevation point. Bottoms of circles are not
within 1.2—1.8 meters (3.9—5.9 feet) height. Loops
are not round and equal in size. Point of intersection
varies. Second eight is not in the same position as
the first.
13.10. Square Horizontal Eights (Two (2)
required). The eight is to be entered in the direction
of the climbing sides of the loops, and after
completion of two (2) eights the exit is made in the
same direction. The inside loop must be flown first.
Correct eights are judged when the model starts a
vertical climb and makes a modified inside square
loop followed by a modified outside square loop
ending with a vertical climb at the same point. The
loops are modified so their climbing sides are
vertical, and the loops are tangent to each other along
these sides, and the turns starting and ending the
climbs are 90 degrees. The top sides are slightly
shorter than the remaining sides which are of equal
length. The maneuver is repeated to form two (2)
eights. Tops of loops must be at 45 degrees elevation,
bottom of loops must be at normal flight level, and all
turns must be smooth, precise, and of approximately
Errors: Corners exceed 2.1 meters (6.9 feet) radius.
Sides are not straight. Vertical sides and bottom sides
are not equal in length. Loops are not equal in size.
Top and bottom sides are not horizontal. Turns
starting and ending the climbs are not 90 degrees.
Tops of loops are not within 0.6 meter (2 feet) of 45
degrees elevation. Bottom of loops are not within
1.2—1.8 meters (3.9—5.9 feet) in height. The
position of the climbing side varies. Second eight is
not in the same position as the first one.
13.11. Vertical Eights (Two (2) required).
CLA-9
Vertical eights are to be started at the point of 45
degrees elevation and finished at the same point in
inverted flight. The inside loop must be flown first.
a vertical line. The model must be horizontal at the
eights must be symmetrical, the top of the eights at a
point 90 degrees over the flier’s head, and the bottom
of the eights at normal flight level. Maximum 40
Errors: Model is not horizontal at entry. Entry is not
within 0.6 meter (2 feet) of the 45 degrees elevation
point. Tops of eights are not within 0.6 meters (2
feet) of the 90 degree point. Bottoms of eights are not
at a height between 1.2—1.8 meters (3.9—5.9 feet).
Loops are not round and equal in size. Point of
intersection varies. Second eight is not in the same
position as the first.
13.12. Hourglass Figure (One (1) required).
The correct hourglass figure is judged when the
model starts from normal flight level and flies an
hourglass course starting with an abrupt turn
followed by an inverted climb, turns into a wingover
path across the circle center for a distance equal to
half the total climb, turns into an inverted dive, and
recovers at normal flight level. The flight paths of the
climb and the dive cross at 45 degrees elevation. The
four rounded corners of the figure shall have a radius
of approximately 1.5 meters (4.9 feet) and the flight
path forms two (2) equilateral triangles of equal size,
turned peak to peak, and one (1) in vertical line above
the other.
Errors: Maneuver starts at other than the normal
flight level of 1.2—1.8 meters (3.9—5.9 feet). Turns
are rough and wobbly or exceed 2.1 meters (6.9 feet)
radius. Top of figure is not within 0.6 meter (2 feet)
of the 90 degrees position over the pilot’s head.
Triangle segments are not of equal length. The
maneuver is not symmetrical around the vertical line
through the crossing point at 45 degrees elevation.
Recovery is not at normal flight level of 1.2—1.8
13.13. Overhead Figure Eights (Two (2)
required). Overhead eights are to be entered and
completed at the intersection point of the circles,
directly over the flier’s head, and exit from the same
point. The inside loop must be flown first. Correct
overhead eights are judged when the model makes
two (2) eights, each consisting of two (2) round
circles of the same size, with the intersection or point
of tangency directly over the flier’s head. The model
must enter the eights with a vertical climb through
the center of the circle, and must always point in this
direction at the center of the eights. The eights must
be symmetrical and the model at the lowest point of
each circle must be at a point of 45 degrees elevation.
CLA-10
Errors: Model is not vertically overhead at entry.
Low point of circles is not within 0.6 meter (2 feet)
of the 45 degrees elevation point. Loops are not
round and equal in size. Point of intersection varies.
Second eight is not in the same position as the first.
13.14. Four Leaf Clover (One (1)
required). The maneuver is entered from level flight
at approximately 42 degrees elevation, and consists
of one (1) full inside loop, level flight, three-fourths
(3/4) of an outside loop, vertical climb, three-fourths
(3/4) of an outside loop, level inverted flight, threefourths
(3/4) of an inside loop, and a vertical climb.
The right loops are tangent to the left loops along a
vertical plane of symmetry through the center of the
clover leaf, and the bottom loops are tangent to the
top loops. The loops are of equal size and they are
connected by horizontal and vertical flight paths. The
bottom points of the maneuver shall be at 1.5 meters
(4.9 feet) height, and the top shall be tangent to the
vertical plane through the circle center. When the last
loop is performed, the maneuver is made complete
by a vertical climb through the center of the four leaf
clover. Maximum 40 points. Minimum 10 points.
Errors: Entry is not within 0.6 meter (2 feet) of 42
degrees elevation point. Loops are rough or not of
equal size. Paths connecting loops are not properly
horizontal or vertical according to the maneuver
sketch. Bottoms of lower loops are not at a height
between 1.2—1.8 meters (3.9—5.9 feet). Tops of
upper loops are not within 1.2 meters (3.9 feet) of the
vertical plane through the circle center. Loops are not
properly tangential to form a square pattern. Model
recovers before it has flown vertically through the
clover pattern.
13.15. Landing. A correct landing is judged
when the model descends smoothly to land with no
bounce or unusual roughness, and without any part of
the model other than the landing gear having touched
the ground. Main wheel(s) or three-point landings are
permissible. The duration of the flight ends when the
model rolls to a stop. Maximum 40 points. Minimum
0 points. Note: Illustrations are for anticlockwise
flight and are reversed for clockwise flying.
Errors: An error is committed whenever the model
bounces or when any part of the model other than the
landing gear touches the ground. A crash, or a flip
over, a belly or upside down landing receives no
marks. An error occurs each time the model deviates
from a smooth descent. Any unusual circumstances,
outside the pilot’s control, which may have caused
one of the above mentioned errors will be taken into
consideration by the judges. Note: It is permissible to
extend (by whipping) the descent, to achieve the
minimum two (2) laps between maneuvers, to
maintain eligibility for pattern points.
14. Judging Procedures.
14.1. Purpose. This Judges’ Instructions
document is an aid to judging and marking Control
Line Precision Aerobatics competitions. It should be
used both for the training of potential judges, and for
maintaining the proficiency of judges who are
already practicing. This document forms part of
Section 4 of the FAI Sporting Code applicable to
Class F2B Aerobatics.
14.2. AMA Rules and Maneuver Rules
Knowledge. The primary requirements for fair,
accurate, and consistent judging are:
14.2.1. A clear understanding of all of the
applicable regulations and definitions within the
complete AMA rules;
14.2.2. An in-depth and fully detailed
knowledge of all of the current Precision Aerobatics
maneuver Rules;
14.2.3. A fully detailed knowledge of this
complete Judging Instructions document.
Self-study of all of the above points is a
must, as is regular detailed group training at both
classroom
42◦ Elev
CLA-11
and flight venues in the practical application of all of
the above points to the judging of high quality
Precision Aerobatics competition flights. It is
stressed that individual “interpretation” of the intent
and/or meaning of the AMA rules is strongly
discouraged —the purpose of these Judging
Instructions is to eliminate any need for such
“interpretation” by individuals.
14.3. Terminology.
14.3.1. In all of the following maneuver
marking instructions, the descriptions have been
written from the viewing point of the pilot and not of
the judges; and all the following descriptions use
“two-dimensional” terms on the basis that while it is
known that model aircraft actually fly hemispherical
arcs, the real judging task is to mark maneuvers such
as Square Loops (for example) on the basis of what
can be most easily and clearly described in writing as
“straight line” flight paths. Rather than using terms
which are geometrically accurate but which may
create confusion, all the maneuver descriptions in this
document therefore use terms which express the
meaning of the AMA Rules and explain the judges’
marking tasks as clearly and as simply as possible.
14.3.2. The following “everyday English”
terms appear but are used throughout this document
in a specific way:
Term: Definition:
Maneuver Means the full total of figures and segments necessary to complete the marked “flying
exercise” listed in the Rulebook under a single Rule number. Examples: the Take-off
(Rule 13.1.); the Three Consecutive Inside Loops (Rule 13.3.); and the One Four-leaf
Clover (Rule 13.14.). These are all referred to in this document as a single maneuver.
Note that each maneuver listed in the Rulebook has a Rule number.
Figure Means a shape which makes up a separate, recognizable whole portion of a complete
maneuver. For example, the first loop of the Three Consecutive Inside Loops
(Rule13.3.) is referred to as a figure in this document; but the first loop which makes
the first half of the first complete figure eight in the Two Overhead Figure Eights
(Rule13.13.) is not referred to as a figure in this document.
Segment Means a specifically defined part of a figure (or a maneuver) during which the judge is
required to observe certain particular detail points. For example, the Two Consecutive
Inside Square Loops maneuver (Rule 13.6.). This document has divided that maneuver
into two separate figures (the first and second loops) and the first loop has also been
subdivided into four separate segments for judges to observe specific detail points.
Upright Means that the model aircraft is flying in its “normal” attitude (that is: with its main
landing gear wheels nearest to the ground).
Inverted Means that the model aircraft is in an attitude reversed from upright flight
(colloquially: the model aircraft is “flying on its back” or is “flying upside-down”).
Vertical Means at right angles (perpendicular) to the ground over which the flying takes place.
This word is marked with quotation marks throughout this document as a constant
reminder to judges that the requirement of the Rulebook is for model aircraft to fly at
right angles to the ground, even if that ground is not level and/or has a perceptible
slope.
CLA-12
Horizontal Means parallel to the ground over which the flying takes place. This word is marked
with quotation marks throughout this document as a constant reminder to judges that
the requirement of the Rulebook is for model aircraft to fly parallel to the ground, even
if that ground is not level and/or has a perceptible slope.
Straight Line Means the closest distance between two points when shown in two dimensions. These
words are marked with quotation marks throughout this document as a constant
reminder to judges that the judging requirement in all the Square and Triangular
maneuvers (for example) is to observe a number of turns (“corners”) which should be
joined by flight paths which appear to be straight lines when the judges are positioned
correctly and when the competitor positions the model aircraft as required in the
relevant maneuver Rules.
Momentarily or
Momentary
Used throughout this document in their original definition sense—that is: something
which lasts only for a very brief period of time. So (for example) the very short period
during which the model aircraft is required to be in a vertically banked “knife-edge”
attitude above the competitor’s head during the Two Overhead Figure Eights
maneuver (Rule 13.13.) is described in this text as “momentarily.”
Lateral
Reference
Means an imaginary line drawn upwards from the ground at right angles. The judges
should use this as the reference point when observing the size, positioning, symmetry,
and superimposing of figures and maneuvers being judged. As required by individual
maneuver Rules, the text may refer to a lateral reference, to a lateral reference line, or
to a lateral reference point. In this last case the text will also define the specific point
(height) on the imaginary line at which the lateral reference point is to be located.
Wingover Path Means the vertically banked (“knife-edge”) flight path segment defined as part of the
One Reverse Wingover maneuver Rule 13.2., see 14.24.4.
When words appear in quotation marks with italics script in the following text, this means that they have
been taken directly from the relevant maneuver Rule.
14.4. Judging focus. In order to get
complete picture of each maneuver, judges should
focus their attention on four major aspects:
14.4.1. Shape. This is the form or outline of
the entire maneuver, but shape also relates to the
position of each of the figures making up a complete
maneuver. In maneuvers consisting of repeated
multiple figures (for example: the Four Leaf Clover),
an important criteria is that the shape of each
individual figure is consistently the same for each
repetition. All maneuvers should be of the shape
defined in the various maneuver Rules—that is:
round loops should be round with no flat spots;
square maneuvers should have clearly defined
corners connected by “straight line” flight paths;
consecutive maneuvers should be performed with the
second and subsequent maneuvers all positioned in
exactly the same place as the first (superimposed).
● 14.4.2. Size. Maneuver sizes are defined
in the Rules by specifying line elevation angle
(specified in degrees of arc above the normal 1.5
meters (4.9 feet) upright level flight height). Judges
should watch for maneuvers being flown with their
tops above or below the specified 45 degrees, 42
degrees, and 90 degrees line elevation angles—and as
a result of such errors, judges should also watch for
complete figures which are either larger or smaller
than the line elevation angle specified in the relevant
Rule. All such errors should be downgraded in the
marks awarded by judges. The use of visible fixed
terrain reference points at each site to help judges
“fix into memory” both the 1.5 meters (4.9 feet)
normal upright and inverted level flight height, and
45 degrees lateral angle (1/8 lap) is recommended.
Contest organizers are also encouraged to erect
suitable markers at contest sites to assist judges,
particularly at sites where suitable natural fixed
features are limited. Judges should practice using the
available terrain features, plus any erected markers, at
each competition site during the calibration flight
CLA-13
sessions held before the start of each particular
competition (see also 14.15.).
14.4.3. Intersections. The judging (and
therefore the marking) of the intersections between
the various elements of complex maneuvers is also
made easier if judges use fixed terrain reference
marks to “fix into memory” the visual position of the
model aircraft when it passes an intersection point for
the first time in a maneuver, and then compare that
“locked-in” point with the position of the model
aircraft when it comes to the same intersection point
at later stages of the same maneuver. As in 14.4.2.
above, the erection of suitable markers is encouraged
to assist this practice, particularly at sites which lack
suitable fixed terrain reference points (see 14.15.).
● 14.4.4. Bottoms. Normal upright level
flight and inverted level flight is specified in the
maneuver Rules as being required to be flown at a
height 1.5 meters (4.9 feet), often with an allowed
tolerance of plus/minus 30 cm (1 foot). These
occasions are all clearly described in the following
descriptions and judges should mark accordingly,
as per 14.6., 14.9.2., and 14.9.3.
14.5. General comments regarding the
marking of maneuvers. Although model aircraft fly
on the surface of a hemisphere, from the pilot’s
perspective all maneuvers are flown in plane
geometry —because all points on the surface of a
hemisphere are at an equal distance from the pilot,
the pilot sees all maneuvers as if they were drawn on
a flat sheet of paper. From their position outside
the circle, judges are, firstly, not in the ideal position
to view maneuvers, and secondly, they also usually
view maneuvers from a point which is not directly
opposite the center line axis of each maneuver.
Therefore the judges’ marking tasks include a large
element of personal analysis and situational
awareness that should take their own (less than ideal)
viewing position into consideration when awarding
marks. There are however a number of precise
definitions within the maneuver Rules which judges
must assess accurately if they are to award fair and
consistent marks. These are:
●14.5.1. Recognition of level flight altitude
of
1.5
CLA-14
meters (4.9 feet), plus/minus 30 cm (1 foot).
14.5.2. Recognition of 45 degrees line
elevation height, plus/minus 30 cm (1 foot).
14.5.3. Recognition of 42 degrees line
elevation height, plus/minus 30 cm ( 1 foot).
14.5.4. Recognition of a position directly
overhead the center of the flight circle, plus/minus 60
cm (2 feet).
14.5.5. Recognition of “vertical” climbing
and diving flight paths.
14.5.6. Recognition of a “horizontal” flight
path..
● 14.5.7. Recognition of “maximum 2.1
meter (6.9 feet) radius” as an abrupt change of
direction with the resulting requirement for the
model aircraft to fly a very tight corner (see all
14.7).
14.5.8. Recognition of the correct “Start”
and “Stop” points specified in the Rule for each
maneuver (as highlighted within the description of
each maneuver in this document by means of
“Start judging at…” and “Stop judging at…”
sections).
14.5.9. Recognition of the fact that all the
above “dimensions” are specified as measured
from the pilot’s viewing point, with due allowance
to be made by judges for model aircraft flown on
different line lengths and for the difference
between the pilot’s position and the judges’ actual
viewing position/s.
14.6. Judging objective errors. Provided
that throughout all the judged laps the model aircraft
remains inside the tolerance defined in the rules and
provided that it tracks smoothly without any visible
height changes (that is, no “hunting”) throughout, no
downgraded mark should be awarded. A flight track
which slightly exceeds the stated tolerance (such as
flying 40 cm [1.3 feet] off the flight track where
plus/minus 30 cm [1 foot] is required) should be
considered as a “minor” error which would cause the
judge to award a mark downgraded by 1 point. Flying
off the defined flight track by as much as twice the
defined tolerance should be considered as a
“medium” error, resulting in the award of a mark
downgraded by 2 points. Errors of three times the
defined tolerance from the defined flight track should
be considered as “major” resulting in the award of
marks downgraded by 3 points. In order to use this
method successfully, judges must be trained to
recognize flight path deviations of 30 cm (1 foot) and
60 cm (2 feet) at a viewing distance of approximately
45 meters (140 feet), and this will require relevant
and repeated demonstrations to train judges to be
able to readily gauge such measurements. Such
training is highly recommended for all judges, and
such training should also emphasize the varying
tolerances defined in the Rule for each maneuver and
for each segment of each figure of each maneuver.
See also 14.9.2. and 14.9.3.
14.7. Judging subjective errors.
14.7.1. “Wobbles,” etc; A phrase such as
“the model aircraft wobbles during a turn” is
subjective, and the degree to which the model aircraft
wobbles cannot be measured. Similarly, Rules
statements such as “…the model aircraft makes two
smooth, stable laps…” are difficult to apply when
faced with the task of translating a certain lack of
smoothness into an actual mark to be awarded to a
competitor. As a basic guide, judges should consider
terms such as stability and smoothness to be
conditions defined by the absence of “wobbles,”
“jerks,” and/or “hunting.” Therefore “wobbles,”
“jerks,” and/or “hunting” are errors, and each judge
should decide on the extent of each such error seen
and should award a downgraded mark accordingly to
the severity of each of these errors that he/she has
observed. See also 14.9.2. and 14.9.3.
● 14.7.2. Turn radii; Similarly, judges
should recognize that the intent of the Rulebook
regarding corner radii in maneuvers such as Square
Loops, Square Eights, Triangles, etc. is that model
aircraft should turn as sharply (tightly) as possible.
Therefore, although it is not possible for judges to
accurately measure whether or not a model aircraft
has or has not made a turn of between 1.5 (4.9 feet)
and 2.1 meters (6.9 feet) radius, the intent of the
Sporting Code is clearly that model aircraft should
turn as tightly as possible when making such turns.
Therefore judges should award the highest marks to
model aircraft turning the tightest (sharpest) corners
(provided that the required line elevation angles
and/or the model aircraft’s pitch angles have also
been achieved) and they should award the lowest
marks to model aircraft making the largest (softest)
such turns.
14.8. Error interpretation; Each maneuver
Rule states which errors shall be considered as errors
but nothing is written about the relative importance
of those errors. The judges’ task is therefore twofold
in this respect—first, he/she has to count the total
number of errors committed,—second, he/she must
also decide on the extent to which each of those
errors has deviated from the standard specified in
each maneuver Rule. As a general principle it
therefore follows that a maneuver which is flown
with a large number of major errors should result in
judges awarding a lower mark than for a maneuver
which is flown with a very large number of errors,
although each of those errors may be individually
judged as being only a minor deviation from the
maneuver Rule, it could be quite correct to award a
lower score for that maneuver than for another
CLA-15
maneuver which is flown with only a few errors, but
where each of those errors is individually judged as
being a major deviation from the maneuver Rule.
This is precisely one of the skills that judges are
expected to develop and apply! Error interpretation
should be used as a guide and training tool for all
judging See also 14.9.2. and 14.9.3.
14.9. Awarding marks.
14.9.1. Segmented and multiple maneuvers;
Many maneuvers have been described in this
document as consisting of several figures, and in
many of those maneuvers those figures have in turn
been broken down into separate segments for judging
purposes. But all these segments and figures should
be combined to result in the award of only a single
mark for the complete maneuver. In addition, many
maneuvers detailed in the maneuver Rules consist of
multiple (repeated) figures. Once again judges should
award only a single mark for each such maneuver
(for example: the Three Consecutive Inside Loops;
the Two Horizontal Square Eights; etc.).
14.9.2. Principles of marking; Judges
should only score (mark) maneuvers between the
points “Start judging at…” and “Stop judging at…”
as set out in each of the maneuver descriptions in this
document. When the model aircraft reaches the “Start
judging at…” point for each maneuver, each judge
should assume that the maneuver will be flown
within all the “dimensions” and other requirements
defined in the relevant maneuver Rule. (This
maneuver would of course mean that the judge
should award the full maximum available 40 points if
he/she has seen no errors by the time the maneuver is
completed). But as the model aircraft proceeds
through the maneuver, each judge will (usually)
observe some deviation from the maneuver Rule
requirements, so he/she should then mentally deduct
point/s from the potential maximum of 40 points
whenever a deviation is seen. The number of points
to be deducted for each error by each judge will of
course depend on whether judgment as to whether
each of those deviations is a “minor” error, a
“medium” error, or a “major” error, as described in
14.6. above. So after the model aircraft has reached
the “Stop judging at…” point for each maneuver, the
judges’ task is then to total all the points which have
been mentally deducted during the maneuver, and the
final mark to be entered into the score sheet is simply
the maximum available 40 points, minus the total of
all the points mentally deducted by the judge while
the maneuver was being flown. This deduction
method, while not easy to learn, and while requiring a
considerable amount of instruction and practice, does
offer the advantage of coming very close to
producing repeatable results when using a consistent
marking bandwidth for weighting each error seen.
Judges’ Observations: Mark awarded:
Nil deviations from
Sporting Code
“dimensions”
=Mark 40 points
And requirements
seen:
Very few minor errors
seen:
=Marks range 39-
34(Note 1)
Few and/or
errors seen:
minor =Marks range 33-
26(Note 2)
More and/or medium
errors seen:
=Marks range 25-
18(Note 2)
Many and/or major
errors seen:
=Marks range 17-
10(Note 3)
14.9.3. Marking bandwidth. The following
scale of Marks is listed to provide judges with a
practical tool application to principles in 14.9.2.
above:
Notes for marking bandwidth table:
Note 1: The number of points actually
awarded for each maneuver will be dependant upon
the total number of errors seen by each judge and
whether or not each judge decides that these are all
minor errors only.
Note 2: The number of points actually
the total number of errors seen by each judge and the
extent to which each judge decides that each error is
either a minor or a medium or a major deviation from
the maneuver Rule.
Note 3: As per Note 2, but the mark 0 (zero)
points should be reserved for maneuvers which are
not attempted at all.
Judges should use the entire Marks
bandwidth available as above. This means awarding a
Mark of 40 points to any maneuver where the judge
does not observe any of the errors listed in the
maneuver Rules and/or in this Judging Instructions
document—such as an Inverted Flight maneuver
where the model aircraft remains truly stable and
without “hunting” inside the allowed height tolerance
of plus/minus 30 cm (1 foot) throughout all judged
CLA-16
laps. But as an example of the opposite extreme, the
Square Eights maneuver which is flown with line
elevation angles of over 60 degrees, with “soft”
corners, with angled sides, with slanted tops, with
pullouts which are both too high and too low, and
with intersections which are missed by several meters
(in other words, a maneuver which is barely
recognizable), should be awarded a mark of perhaps
10 to 15 points. Note once more the comments in
paragraph 14.8.
It should also be noted that since nothing
written anywhere in the Rulebook defines terms such
as general impression and flying style, accurate and
repeatable marking really depends “only” (!) upon
each judge deciding on the total number of errors
committed and the degree to which each error has
deviated from the flight track defined in each
maneuver Rule. This includes subjective elements,
where (apart from stability, which can be marked as
discussed in 14.7.), the reality is that each
competitor’s score should depend “simply” (!) and
solely upon the total number of all the errors
observed by each judge, coupled with each judges’
decision as to the degree of severity of each of those
errors.
14.10. Consideration of external factors.
With the exceptions mentioned in Landing (Rule
13.15.), “normal” external factors should not in any
way affect the marks awarded by judges. So it is not
permitted for judges’ marks to allow for the effects of
gusty winds in marking any phase of any maneuver,
except during the ground rollout phase of the
Landing maneuver—for example, if a sudden fierce
gust of wind coming from behind the model aircraft
causes it to flip over or tip onto its nose during the
last part of the ground rollout.
This therefore means that factors such as
wind, turbulence, gusts, and any other factors outside
the competitor’s control should not normally
influence the marks awarded by the judges. However,
some individual exceptions to this general
observation may occur occasionally—for example, a
safety-related exception should be imminent danger
of electrocution by thunderstorm. Exceptions should
also be made where a completely “accidental”
incident prevents the proper execution of a maneuver
or forces a competitor to abandon a maneuver or a
flight altogether (for example), an animal wandering
into the flight circle). In cases where the head judge
feels that such external factors have influenced the
result of a competition flight, he should use his
discretion and authority to recommend that the
Contest Director grant a reflight.
14.11. Judging a maneuver missed by a
judge. If a judge misses the observation of a
maneuver for any
reason, he or she should not mark an estimated
“typical” mark for the missed maneuver. Instead the
judge who missed the maneuver should clearly write
an “X” symbol on his/her score sheet in the space for
the mark for the maneuver which has been missed.
This symbol should then alert the scores tabulating
team to use a procedure which calculates the average
of the marks for the maneuver as awarded by all the
other judges. This calculated average mark should
then be entered into the missing mark “X” area by the
scores tabulating team before they proceed with
further processing of all the remaining marks from
that flight.
14.12. Results awareness. In order to
prevent influence of any kind, no judge shall look at
tabulated results scores and/or at competitors
placings until after the completion of a competition.
Neither should judges discuss individual official
flights, the execution of maneuvers, and/or the marks
awarded (and/or the tabulated results and scores),
with anyone at all during the whole competition,
including other judges, competitors, or team
managers. The head judge should ensure that all
members of the Judges’ Panel observe these
requirements throughout the competition.
14.13. Judges’ preparations to be made at
Competition Sites. Well before the start of official
competition flights, the head judge should meet the
competition organizer and Event Director to define
and/or verify:
14.13.1. Head judge in charge.
14.13.2. Classification procedures.
14.13.3. Score calculation procedures.
14.13.4. Competitors’ flying order.
14.13.5. Competitor call-up procedure.
14.13.6. Nominated official timekeeper;
how times will be communicated to Judges’ Panel.
14.13.7. Duration of rounds.
14.13.8. Meal and break times; seating
arrangements; sunshades; umbrellas; etc.
14.13.9. Availability of score recorders.
14.13.10. Score sheet transportation.
14.13.11. Competitors’ pull-test procedure.
14.13.12. The availability of fixed terrain
reference points, and/or erected markers (refer
14.4.2. and 14.4.3.).
14.14. Judges’ calibration (“warm-up”)
flights. A minimum of two warm-up flights, to be
flown immediately prior to the beginning of official
competition flights, should be flown per each round
(or per each day) of the contest by volunteer pilots
selected by random draw from among all registered
competitors. After each warm-up flight the judges
should not discuss the individual scores they have
awarded to each flight. Instead they should go
through a maneuver-by-maneuver discussion,
CLA-17
comparing and discussing their individual
assessments of each error (including the severity of
those errors) that they have seen during every
segment of every figure and every maneuver flown.
In order to avoid the definitely undesirable “leveling”
of marks awarded by each judge, the actual marks
(scores) awarded by each judge should not be
discussed—rather, the discussions should focus upon
the number, extent, and degree of severity of each
error seen. The content of all such judges’ warm-up
flight discussions should not be made public.
14.15. Sighting devices and terrain
reference points. Hand-held sighting devices
should not be used. Whenever possible, fixed terrain
reference points should be used to define
intersections, “verticals,” line elevation angles, and
1/8 lap (45 degrees laterally) bottom maneuver
lengths and/or lap segments. As per 14.4.2. and
14.4.3., contest organizers are also encouraged to
erect suitable markers (for example, for the 45
degrees lateral dimension specified in the relevant
maneuver Rules), especially when a particular contest
site lacks natural fixed reference points. It is
recommended that such reference points and/or
markers be recalibrated for each individual
competition site on the occasion of each competition
held at that site, and that these should be discussed
privately between the judges prior to the start of
warm-up flights. Final agreement on useable natural
reference points and/or erected markers should be
reached between all members of the Judges’ Panel
before the start of official competition flights.
14.16. Time-keeping. It is common practice
to assign official time-keeping duties to the Stunt
Circle Marshall. Before starting official competition
flights, judges should confirm that this is indeed the
case. Judges should also define the method(s) by
which the results of this timekeeping will be signaled
to the Judges’ Panel. The times recorded by the
defined official timekeeper are binding, but as a cross
reference it is recommended that the head judge runs
his/her own stopwatch in parallel to the official
timekeeper (see also 14.37.9.).
14.17. Judges’ position. The panel of
judges should be placed in a position defined by each
competitor prior to starting his/her official flight. If
no change to the judges’ position for the previous
official flight is requested by the pilot of the next
official flight, then the position of the panel of judges
at the time of starting the next official flight is
assumed to be correct. Judges may however, at their
own discretion, move from the positions originally
taken at the start of an official flight by up to plus or
minus 1/8 of a lap during an official flight.
14.18. Contest supervision. Judges should
closely observe the running of the contest in general,
and the proceedings on the Stunt flight circle in
particular. Where not defined by the organizer, the
panel of judges shall name a head judge as its speaker
for addressing the Contest Director. The head judge
shall intervene in the running of the contest if the
goal of fairness appears to be in danger, and the head
judge may at all times take safety-related decisions
and order suitable remedial action.
14.19. Consistency. Judges should use a
consistent scale of awarding marks throughout all the
rounds of a competition. This scale should be a
personal instrument based upon the number of errors
seen, plus the severity of each error. This personal
scale should have been arrived at by careful study of
the current rules, study of this Judging Instructions
document, and as a result of practical judging
experience. Once the official flights of a competition
have started, each judge’s personal scale should
remain firm and fixed and should not (for example)
become influenced by factors such as discussions
with others (including other judges), by the weather,
by model aircraft speed, by model aircraft type or
engine sound, or by an awareness of the reputation or
results previously achieved by any particular pilot
being judged. In this respect it should be noted that in
the following maneuver descriptions the words model
aircraft and competitor (and not pilot) have been
used!
14.20. Definition of an Attempt (Rule 7.).
14.20.1. “... called to the circle”; means that
an official calls the competitor to enter the circle.
14.20.2. “... within three minutes of the
starting signal”; means that the model aircraft does
not become airborne within three minutes of giving
the starting signal. This leads to a critical point:
judges are advised to watch for the competitor (or an
official) calling for an attempt if the model aircraft
does not become airborne within three minutes from
14.21 Execution of Maneuvers (Rule 11.1.
and 11.2.).
14.21.1. Judging “... a minimum of 2 laps.”;
competitors may choose to fly more than, but may
not fly less than, two nominal intervening laps
between each maneuver.
14.21.2. Judging the height of intervening
laps: the height of the laps flown between maneuvers
is not specified in the Rulebook and should therefore
not be judged or marked.
14.21.3. Judging incomplete maneuvers:
every maneuver which is started but not completed
by the competitor should be awarded 10 (ten) points.
14.21.4. Judging omitted maneuvers; every
maneuver omitted from the List of Flight Maneuvers
(Rule 13.) should be awarded a mark of 0 (zero)
points.
CLA-18
14.21.5. Judging maneuvers flown with an
incorrect number of multiple figures (for example:
the Three Consecutive Inside Loops maneuver
required [Rule 13.3]; but the maneuver is actually
flown with 2 or 4 loops): All maneuvers flown in
such ways are incorrect and should be awarded a
mark of 10 (ten) points.
14.21.6. Attempted maneuver(s); if a
competitor makes more than one attempt at any one
maneuver during one official flight the judges should
mark the first attempt in accordance with the
instructions listed in this paragraph and the relevant
following maneuver description paragraph. Any
further attempt(s) at the same maneuver during the
same official flight should not be marked at all.
14.22. Duration of Flight (Rule 8.).
14.22.1. Start of timing; the timekeeper
and/or judge(s) should start timing when the
competitor gives a hand signal indicating that he/she
is ready to start the motor(s).
14.23. Take-off (Rule 13.1.).
14.23.1. Start judging at: the beginning of
the Take-off ground roll.
14.23.2. Judging the ground roll and lift-off
segment; from the beginning of the Take-off ground
roll to the point of lift-off.
Lift-off should not occur before 4.5 meters
(14.8 feet) from start of ground roll, nor later than 1/4
of a lap. “Smoothly” means without a “sudden jump”
into the air.
● 14.23.3. Judging the climb out and
leveling-off segment; from lift-off, up to and
including leveling- off. Leveling-off should occur at
a height of 1.5 meters (4.9 feet), plus/minus 30 cm (1
foot), and should occur exactly overhead the point of
the beginning of the Take-off ground roll. “Gradual”
means that the rate of climb should be constant
throughout the climb from lift-off until leveling-off
into normal upright level flight. “Smooth” means a
“jerk-free” transition from climbing flight to level
flight.
● 14.23.4. Judging the level flight segment;
two laps, from the end of leveling-off to the end of
lap three. “Smooth laps of normal level flight” means
that the model aircraft does not deviate from a height
of 1.5 meters (4.9 feet) plus/minus 30 cm (1 foot).
14.23.5. Stop judging: at the end of lap
three, exactly overhead the point of the beginning of
● 14.23.6. Critical points: are take-off
ground roll shorter than 4.5 meters (14.8 feet) or
longer than 1/4 lap; Model aircraft “jumping” into the
air. Reaching level flight altitude too quickly. Climb
rate not gradual (for example: too shallow at first and
then too steep later). Leveling-off before or after
passing exactly overhead the point of the beginning
of the Take-off ground roll. Not maintaining a level
flight height of 1.5 meters (4.9 feet), plus/minus 30
cm(1 foot) throughout upright level flight, lap
numbers two and three.
14.24. One Reverse Wingover (Rule 13.2.).
● 14.24.1. Entry; from normal upright level
flight at a height of 1.5 meters (4.9 feet), plus/minus
30 cm (1 foot).
14.24.2. Start judging; at the beginning of
the first turn into a “vertical” climb.
● 14.24.3. Judging turn radii; all turns
should be of 1.5 meters (4.9 feet) radius, maximum
2.1 meters(6.9 feet) radius.
14.24.4. Judging the first “vertical” climb
and dive segment; from the beginning of the first turn
into a “vertical” climb, over the competitor’s head,
into a “vertical” dive, until the end of the second turn
(recovering from the “vertical” dive into inverted
level flight). “Passing directly over the flier’s head”
means that the model aircraft should pass through an
imaginary line projected at right angles upwards
from the center of the ground circle. “Cutting the
ground circle in half” means that the judges should
“mentally project” the start and finish points of the
complete line of “vertical” flight downward onto the
ground, with the result that these two points are
exactly opposite each other on the ground circle if the
first “vertical” climb and “vertical” dive segment has
been correctly flown.
● 14.24.5. Judging the inverted “horizontal”
level flight segment; after recovery from the first
“vertical” dive, until the start of the second turn into
the second “vertical” climb. The inverted level flight
segment should be flown at a height of 1.5 meters
(4.9 feet), plus/minus 30 cm (1 foot). The length of
the inverted flight segment, including turns, should
be exactly 1/2 a lap.
● 14.24.6. Judging the second “vertical”
climb and dive segment; the point at which the model
aircraft first reaches a “vertical” attitude in this
second “vertical” climb should be exactly the same as
the point at which the model aircraft first reached a
“vertical” attitude at the start of the first “vertical”
climb. “Over the center of the circle” means that the
model aircraft should pass through an imaginary line
projected upward at right angles from the center of
the ground circle. The point where the model aircraft
starts its recovery to normal upright level flight at the
end of the whole maneuver should be exactly
opposite the point where the model aircraft first
reached “vertical” flight attitude at the start of the
whole maneuver. Recovery should bring the model
aircraft to normal upright level flight at a height of
14.24.7. Stop judging; at the end of the
fourth turn (recovery to normal upright level flight).
CLA-19
● 14.24.8. Critical points are; first climb not
“vertical.” Model aircraft not passing through the
right angled line projected upwards from the center
of the flight circle. “Vertical” climb and/or dive
segments being curved (meaning not “straight line”)
flight path(s). Recovery(ies) to inverted level flight
and/or to normal upright level flight not at a height of
1.5 meters (4.9 feet), plus/minus 30 cm (1 foot). Not
maintaining a height of 1.5 meters (4.9 feet),
plus/minus 30 cm (1 foot) during inverted level
flight. The “turning points” defined above not being
exactly opposite each other. Turn radii not equal in
all four turns and/or exceed 2.1 meters (6.9 feet).
14.25. Three Consecutive Inside Loops
(Rule 13.3.).
● 14.25.1. Entry; from normal upright level
30cm (1 foot).
14.25.2. Start judging; at the start of the first
loop (as the model aircraft departs its normal upright
level flight path).
14.25.3. Judging the first loop; from normal
upright level flight the model aircraft should fly
upwards along a circular flight path to a height
specified in the Sporting Code as a line elevation
angle of 45 degrees, at which point it should be
inverted. The model aircraft should continue, without
interruption, its circular flight path downwards until
reaching its first normal upright level flight height, at
which point it should be upright. “Round” means no
visible deviations from a circular flight path.
“Smooth” means without flat spots or “jerks.” When
the model aircraft reaches a “vertical” attitude for the
first time this has defined the lateral reference for the
whole maneuver.
14.25.4. Judging the second and third loops;
the model aircraft should follow a flight path exactly
as described above. The second and third loops
should be flown in exactly the same position
(meaning that the second loop should be
superimposed exactly on top of the first loop, and the
third exactly on top of the second), and all three
should be of exactly the same size.
14.25.5. Stop judging; at the end of the third
loop as the model aircraft completes recovery into
14.25.6. Exit procedure; should be flown as
recommended by this rule but should not be judged
or marked.
● 14.25.7. Critical points are; line elevation
angle(s) above 45 degrees (loop too big). Line
elevation angle(s) less than 45 degrees (loop too
small). Bottom(s) of loops not all at a height of 1.5
meters (4.9 feet), plus/minus 30 cm (1 foot). Tops
and/or bottoms of loops are not all at the same
heights. Shapes are not truly circular. Flight path is
not steady (examples: uneven rate of turn;
“wobbling” flight). Flat spots on any of the loops.
Second and third loops are not exactly the same size
as the first. Second and third loops are not in exactly
the same position (not superimposed upon) the first
loop.
14.26. Two Laps Inverted Flight (Rule
13.4.).
● 14.26.1 Entry; from inverted level flight at
a height of 1.5 meters (4.9 feet) plus or minus 30 cm
(1foot).
14.26.2. Start judging; at the beginning of
lap three (as counted from the exit point of the Three
Consecutive Inside Loops maneuver - Rule 13.3.).
● 14.26.3. Judging inverted flight height;
should be at 1.5 meters (4.9 feet). “Stable” means
that the model aircraft does not deviate by more than
plus/minus 30 cm (1 foot) from 1.5 meters (4.9 feet).
“Smooth” means the absence of visible height
deviations.
14.26.4. Stop judging; at the end of lap four
(as counted from the exit point of the Consecutive
● 14.26.5. Critical points are; the first
inverted flight height at the beginning of lap three is
not 1.5 meters (4.9 feet), plus/minus 30 cm (1 foot).
Model aircraft deviates more than plus/minus 30 cm
(1 foot) from a height of 1.5 meters (4.9 feet) during
the two judged laps. The model aircraft shows visible
height corrections.
14.27. Three Consecutive Outside Loops
(Rule 13.5.).
● 14.27.1. Entry: from level inverted flight
at a height of 1.5 meters (4.9 feet), plus/minus 30 cm
(1
foot).
14.27.2. Start judging; at the beginning of
the first loop (as the model aircraft departs its level
inverted flight path).
14.27.3. Judging the first loop; from level
inverted flight the model aircraft should fly upwards
along a circular flight path to a height specified in the
Sporting Code as a line elevation angle of 45 degrees,
at which point it should be upright. The model
aircraft should continue, without interruption, its
circular flight path downward until reaching its first
inverted flight height, at which point it should be
inverted. “Round” means no visible deviations from
a circular flight path. “Smooth” means without flat
spots or “jerks.” When the model aircraft reaches a
“vertical” attitude for the first time this has defined
the lateral reference for the whole maneuver.
14.27.4. Judging the second and third loops;
the model aircraft should fly a flight path exactly as
set out in the individual segments above. The second
and third loops should be flown in exactly the same
CLA-20
position (meaning that the second loop should be
superimposed exactly on top of the first loop and the
third loop onto the second) and all three should be of
● 14.27.5. Stop judging; at the end of the
third loop, when the model aircraft passes the 1.5
meters (4.9 feet) normal flight level in inverted flight.
14.27.6. Exit procedure; should be flown as
or marked.
● 14.27.7. Critical points are; line elevation
angle(s) above 45 degrees (loop(s) too big). Line
small). Bottom of loop(s) not at a height of 1.5
and/or bottoms of loop(s) are not all at the same
heights. Shapes are not circular. Flight path is not
steady (example: “wobbling” or “jerky” flight). Flat
spots on any of the loops. Second and third loops are
not exactly the same size as the first. Second and
third loops are not in exactly the same position (not
superimposed upon) the first loop.
14.28. Two Consecutive Inside Square
Loops
(Rule 13.6.).
● 14.28.1. Entry; from normal upright level
flight at a height of 1.5 meters (4.9 feet) plus/minus
30 cm (1 foot).
14.28.2. Start judging; from the point in
normal upright level flight where the model aircraft
begins its first turn into a “vertical” climb.
● 14.28.3. Judging turn radii; all turns
14.28.4. Judging the first turn plus “vertical”
climbing segment: the model aircraft should reach
and maintain a flight path which is at right angles to
the ground.
14.28.5. Judging the second turn plus top
“horizontal” segment; the model aircraft should turn
into inverted level flight to reach a height of 45
degrees line angle elevation as it becomes inverted.
The top segment should be flown in inverted level
flight with the flight path parallel to the ground.
14.28.6. Judging the third turn plus
“vertical” diving segment; the model aircraft should
reach and maintain a flight path which is at right
angles to the ground.
Title: Re: What CL Stunt Judges should look for
Post by: RandySmith on December 11, 2006, 11:55:24 AM
This is the  rest of  the above thread......   Randy
● 14.28.7. Judging the fourth turn plus
bottom “horizontal” segment; the model aircraft
should recover to normal upright level flight at a
height of 1.5 meters (4.9 feet) plus/minus 30 cm (1
foot). The length of the bottom segment, including
both turns, should be exactly 1/8 of a lap.
14.28.8. Judging the complete second loop;
loop should be flown in exactly the same position
superimposed exactly onto the first loop) and should
be of exactly the same size as the first loop.
14.28.9. Stop judging; in normal upright
level flight, at exactly the point where the model
aircraft started its first turn into a “vertical” climb at
the beginning of the complete maneuver.
● 14.28.10. Critical points are; line elevation
angle(s) above 45 degrees (loop too big; top
segment flown too high). Line elevation angle(s)
less than 45 degrees (loop too small; top
segment flown too low). Turn radii are not equal,
and/or exceed 2.1 meters (6.9 feet) radius. Climb
and/or dive segments not “vertical.” Top segment(s)
not level (not parallel to the ground and/or not
“straight line” flight throughout). Bottom segment(s)
not at a height of 1.5 meters (4.9 feet), plus/minus 30
cm (1 foot). Length of bottom segment(s) greater
than/less than 1/8 of a lap. Loop(s) are either wider
than their height(s) and/or higher than their width(s).
Sides are not “straight line” flight. Flight path is not
steady (example: “wobbling” flight). Second loop is
not exactly the same size as the first. Second loop is
not in exactly the same position (meaning not
superimposed exactly upon) the first loop.
14.29. Two Consecutive Outside Square
Loops
(Rule 13.7.).
14.29.1. Entry; from upright level flight at a
height of 45 degrees line angle elevation.
14.29.2. Start judging; from the point in
starts its first turn downwards into a “vertical” dive.
● 14.29.3. Judging turn radii; all turns
14.29.4. Judging the first turn plus “vertical”
dive segment; the model aircraft should reach and
maintain a flight path which is at right angles to the
ground.
● 14.29.5. Judging the second turn plus
should recover from diving flight to inverted level
30 cm (1 foot). The bottom segment should be flown
with the flight path parallel to the ground. The length
of the bottom segment, including both turns, should
be 1/8 of a lap.
14.29.6. Judging the third turn and “vertical”
climbing segment; the model aircraft should reach
the ground.
14.29.7. Judging the fourth turn and top
CLA-21
recover into upright level flight at a height of 45
degrees line angle elevation. The top segment should
be flown in level upright flight with the flight path
14.29.8. Judging the complete second loop;
The model aircraft should fly exactly as set out in the
individual segments above. The second loop should
be flown in exactly the same position (meaning that
the second loop should be superimposed exactly on
top of the first loop) and should be of exactly the
14.29.9. Stop judging; in level flight, at
exactly the point where the model aircraft started its
first turn into a “vertical” dive at the beginning of the
complete maneuver.
14.29.10. Exit procedure; should be flown as
or marked.
● 14.29.11. Critical points are; maneuver
entry height not within the plus/minus 30 cm (1 foot)
tolerance. Model aircraft not in level flight when
starting first turn. Line elevation angle(s) above 45
degrees (loop too big; top segment flown too
high). Line elevation angle(s) less than 45 degrees
(loop too small; top segment flown too low).
Turn radii are not equal, and/or exceed 2.1 meters
(6.9 feet) radius. Climb and/or dive segments not
“vertical.” Top segment(s) too high and/or too low
(not at 45 degrees line angle elevation). Top
segment(s) not level (parallel to the ground; not
not at a height of 1.5 meters (4.9 feet) plus/minus 30
not in exactly the same position (not superimposed
14.30. Two Consecutive Inside Triangular
Loops (Rule 13.8.).
● 14.30.1. Entry: from normal upright level
30 cm (1 foot).
14.30.2. Start judging: from a point in
normal, level flight where the model aircraft starts its
first turn into an inverted climb.
14.30.3. Judging turn radii: all turns should
be of 1.5 meters (4.9 feet) radius, maximum 2.1
14.30.4. Judging the first (climbing) turn
plus inverted climb segment: the model aircraft
should reach and maintain a “straight line” inverted
climb flight path at approximately 30 degrees past
right angles to the ground.
14.30.5. Judging the second (diving) turn
segment; the model aircraft should turn through
approximately 60 degrees, reaching and maintaining
a “straight line” inverted dive flight path at
approximately 30 degrees less than a right angle to
the ground. The maximum height reached during this
turn should not exceed a line elevation angle of 45
degrees.
● 14.30.6. Judging the third turn plus bottom
“horizontal” segment: the model aircraft should
recover to normal upright level flight at a height of
1.5 meters (4.9 feet) plus/minus 30 cm (1 foot). The
length of the bottom segment, including both turns,
should be equal to the length of both the climbing
and the diving flight segments including their
respective turns.
14.30.7. Judging the complete second loop:
the model aircraft should fly exactly as set out in the
the second loop should be superimposed on top of
the first loop) and should be of exactly the same size
as the first loop.
14.30.8. Stop judging: with the model
aircraft in normal level upright flight, at exactly the
same point as the model aircraft started its first turn
at the start of the complete maneuver.
● 14.30.9. Critical points are: line elevation
small). Turn radii are not equal, and/or exceed 2.1
meters (6.9 feet). Climbing and or diving flight
segment( s) not “straight line” flight path(s) and/or
flight path(s) not at approximately 60 degrees to the
ground. Bottom segment(s) not “straight line” flight,
and/or not parallel to the ground, and/or not at a
foot). Length of individual segments (meaning sides
of triangles) not equal. Tops and/or bottoms of loops
are not all at the same heights. Second loop is not
exactly the same size as the first. Second loop is not
14.31. Two Horizontal Eights (Rule 13.9.).
● 14.31.1. Entry: from normal upright level
30 cm (1 foot).
14.31.2. Start judging: when the model
aircraft passes the intersection point for the first time.
14.31.3. Locating the intersection: when the
model aircraft reaches a “vertical” climbing attitude
for the first time this has defined the intersection
point for the whole maneuver (i.e. after 1/4 of a full
loop has been flown).
● 14.31.4. Judging the first inside loop: from
normal upright level flight the model aircraft should
CLA-22
fly upwards along a circular flight path to a height
specified in the Rulebook as a line elevation angle of
45 degrees, at which point it should be inverted. The
model aircraft should continue, without interruption,
its circular flight path downwards until reaching its
first normal upright level flight height, at which point
it should be upright. The model aircraft should then,
without interruption, continue its circular flight path
for a further 1/4 of a loop until reaching the
intersection point, at which point it should be
momentarily “vertical.” This is exactly the same as
described for the Inside Loops maneuver (Rule
13.3.), and “Round” means no visible deviations
from a circular flight path. “Smooth” means without
flat spots or “jerks.” The height of the bottom of the
first inside loop should be 1.5 meters (4.9 feet)
14.31.5. Judging passage through the
intersection point and transition into the first outside
loop: the intersection point first defined by the model
aircraft at the beginning of the maneuver (14.31.3.
above) should be maintained throughout the complete
maneuver. At the time of passing through the
intersection point and transitioning to the first outside
loop the model aircraft should be momentarily in a
“vertical” nose-up attitude but should not visibly
travel in a “straight line” and/or along a “vertical”
climbing flight path.
● 14.31.6. Judging the first outside loop
(actually one complete loop from the intersection
point): after passing through the intersection point the
to fly a complete outside loop as defined for the
Outside Loops maneuver (Rule 13.5). This means
that the model aircraft should fly upward along a
Rulebook as a line elevation angle of 45 degrees, at
which point it should be upright. The model aircraft
should continue its circular flight path downwards
until reaching the inverted flight height of 1.5 meters
(4.9 feet) plus/minus 30 cm (1 foot), at which point it
should be inverted. “Round” means no visible
deviations from circular. “Smooth” means without
flat spots or “jerks.” The model aircraft should then,
14.31.7. Judging the second complete figure
eight: the model aircraft should follow a flight path
exactly as set out in the individual segments above.
The second figure eight should be flown in exactly
the same position (meaning that the second eight
should be superimposed exactly on top of the first
eight) and should be of exactly the same size as the
first eight.
14.31.8. Stop judging: as the model aircraft
completes the second figure eight, when passing the
intersection point in a “vertical” climb for the fifth
and last time.
14.31.9. Exit procedure: should be flown as
or marked.
● 14.31.10. Critical points are: line elevation
angle(s) above 45 degrees (eight too big). Line
elevation angle(s) less than 45 degrees (eight too
small). Bottom(s) of eight(s) not at a height of 1.5
meters (4.9 feet), plus/minus 30 cm (1 foot). Top(s)
and/or bottom(s) of eight(s) are not all at the same
height. Shapes are not circular. Model aircraft not
“vertical” when passing through the intersection
point. Flat spot(s) on any of the eight(s). Model
aircraft flies a “straight line” segment when passing
through the intersection point. The intersection varies
from the point first defined by the model aircraft.
Inside and outside loop(s) are too far apart (resulting
in an “X-shaped” flight path at the intersection
point). The second eight is not exactly the same size
as the first. The second eight is not in exactly the
eight.
14.32. Two Square Horizontal Eights
(Rule
13.10.).
● 14.32.1. Entry: from normal upright level
30 cm (1foot).
14.32.2. Start judging; with the model
aircraft in upright level flight, from the point flight
where the model aircraft starts its first turn upward
into a “vertical” climb for the first time.
● 14.32.3. Judging turn radii; all turns
2.1 meters radius (6.9 feet).
14.32.4. Locating the intersection line; when
first time this has defined the intersection line for the
whole maneuver.
• 14.32.5. Judging the first climbing turn and
“vertical” climbing segment of the first (inside)
square loop of the first figure eight; the model aircraft
should turn into a “vertical” climb, reaching and
maintaining a flight path which is at right angles to
the ground.
14.32.6. Judging the second turn and top
“horizontal” segment of the first (inside) square loop
of the first figure eight; the model aircraft should turn
The top segment should be flown with the flight path
CLA-23
14.32.7. Judging the third turn and “vertical”
dive segment of the first (inside) square loop of the
first figure eight; the model aircraft should turn into a
“vertical” dive, reaching and maintaining a flight
path which is at right angles to the ground.
● 14.32.8. Judging the fourth turn and
bottom “horizontal” segment of the first (inside)
14.32.9. Judging the first climbing turn and
“vertical” climb segment of the second (outside)
square loop of the first figure eight: at the end of the
previous segment (14.32.8.), the model aircraft
the ground. This flight path should be in exactly the
same position as defined by the model aircraft at the
beginning of the maneuver (14.32.4.).
14.32.10. Judging the second turn and top
“horizontal” segment of the second (outside) square
should turn into upright level flight to reach a height
of 45 degrees line angle elevation as it becomes
level. The top segment should be flown with the
14.32.11. Judging the third turn “vertical”
dive segment of the second (outside) square loop of
into a “vertical” dive, reaching and maintaining a
flight path which is at right angles to the ground.
● 14.32.12. Judging the fourth turn and
bottom “horizontal” segment of the second (outside)
should recover to inverted level flight at a height of
14.32.13. Judging the complete second
figure eight; the model aircraft should follow a flight
path exactly as set out in the individual segments
above. The second figure eight should be flown in
exactly the same position (meaning that the second
eight should be superimposed exactly on top of the
first eight) and should be of exactly the same size as
the first eight.
14.32.14. Judging the last turn and “vertical”
climb exit from the maneuver; at the end of the
second bottom “horizontal” segment of the fourth
loop the model aircraft should turn into a “vertical”
climb, reaching and maintaining a flight path which
is at right angles to the ground. This flight path
should be in exactly the same position as defined by
the model aircraft at the beginning of the maneuver
(14.32.4.).
14.32.15. Stop judging; as the model aircraft
completes the second figure eight, when passing a
height of 45 degrees line elevation in a “vertical"
climb for the last time.
14.32.16. Exit procedure; should be flown as
or marked.
● 14.32.17. Critical points are; line elevation
small). Bottom of eight(s) not at a height of 1.5
meters (4.9 feet) plus/minus 30 cm (1 foot). Tops of
eight(s) are not all at the same heights. Turn radii are
not equal, and/or exceed 2.1 meters (6.9 feet) radius.
Bottom
segment(s) are not equal, and/or are longer or shorter
than 1/8 lap. Bottom segment(s) are not flown
parallel to the ground, and/or are not flown at a
foot). “Vertical” climb and/or dive segment(s) are
not flown at right angles to the ground. Figure(s) are
wider than their height(s). Figure(s) are higher than
their width(s). Side(s) of figures are not “straight
line” flight path(s), and/or the model aircraft
“wobbles.” The intersection line first defined by the
model aircraft varies in subsequent segments of the
maneuver. The second eight is not exactly the same
size as the first. The second eight is not in exactly the
eight.
14.33. Two Vertical Eights (Rule 13.11.).
14.33.1. Entry; from normal upright level
flight the model aircraft should fly upward along a
circular flight path to a height specified as a line
elevation angle of 45 degrees, at which point it
should be inverted.
14.33.2. Start judging at; after the model
aircraft has flown the first half of an inside loop as it
passes through the intersection point for the first
time.
14.33.3. Locating the intersection; the
intersection of the whole maneuver is defined when
the model aircraft passes through inverted level flight
at a height of 45 degrees line elevation angle for the
first time.
● 14.33.4. Judging the first segment (inside
loop): as the model aircraft passes through the
intersection point for the first time it should continue
to fly a complete round inside loop. The bottom of
this loop should be at a height 1.5 meters (4.9 feet)
plus/minus 30 cm (1 foot). The loop should be
completed by the model aircraft returning to the
inverted position at a height of 45 degrees line
CLA-24
elevation angle. “Round” means no visible
14.33.5. Judging the model aircraft’s
passage through the intersection point and transition
to the second (outside) loop; the flight path should
touch the intersection point and this point should be
maintained throughout the entire maneuver. At the
time of passing through the intersection point and
transitioning into the second (outside) loop, the
model aircraft should momentarily be in a level
inverted flight attitude but should not visibly follow a
“straight line” flight path. Also, the model aircraft
should neither climb nor dive during this momentary
period of inverted flight.
14.33.6. Judging the second segment
(outside loop); as it passes through the intersection
point the model aircraft should continue without
interruption, flying a complete outside round loop.
The bottom of this second loop should be at a height
of 45 degrees line elevation angle and the top should
be at 90 degree line elevation. “Round” means no
14.33.7. Locating the “vertical” axis; the
centers of both loops should be positioned on an
imaginary line drawn upward from the ground at
right angles.
14.33.8. Judging the complete second figure
eight; the model aircraft should follow a flight path
first eight.
14.33.9. Stop judging; as the model aircraft
completes the second figure eight, at the moment
when it reaches inverted level flight at a height of 45
degrees line elevation angle.
14.33.10. Exit procedure; should be flown as
or marked.
● 14.33.11. Critical points are; the lower
(inside) loop(s) are too big with line elevation
angle(s) exceeding 45 degrees. The upper (outside)
loop(s) are too big/too small with line elevation
angle(s) not reaching or exceeding 1.2 meters (4 feet)
from 90 degrees line elevation. Bottom(s) of lower
loop(s) not at a height of 1.5 meters (4.9 feet)
plus/minus 30 cm (1 foot). The intersection point is
not at a height of 45 degrees line elevation angle,
plus/minus 30 cm (1 foot). All loops are not of the
same size. The loops are not round. The loops show
flat spots. The model aircraft is not momentarily
parallel to the ground when passing through the
intersection point. The model aircraft follows a
climbing and/or diving flight path when passing
through the intersection point. Loops overlap. The
intersection flight path is “S”-shaped. The loops are
too far apart. The intersection point flight path is
“X”-shaped. The intersection point varies from the
position first defined by the model aircraft during the
first inside loop. Loops are not all positioned on the
“vertical” axis (13.33.3.). The second eight is not
exactly the same size as the first. The second eight is
upon) the first eight.
14.34. One Hourglass Figure (Rule 13.12.).
● 14.34.1. Entry; from normal upright level
30 cm (1 foot).
14.34.2. Start judging; with the model
aircraft in upright level flight, from the point where
the model aircraft starts its first turn into a climb for
the first time.
● 14.34.3. Judging turn radii; all turns
14.34.4. Judging the first turn and inverted
climb segment; the model aircraft should reach and
maintain an inverted climb with a “straight line”
flight path angled at approximately 30 degrees past
right angles to the ground. That climb should be
continued until terminated with an outside turn which
should result in the model aircraft following a
wingover path. That wingover path should be located
at 90 degrees to the center line axis of the whole
maneuver.
14.34.5. Judging the “overhead” segment
and third turn; this segment should be flown in
“straight line” flight and the length of this segment,
including its two turns, should be slightly more than
1/8 lap. This segment should be finished by an
outside turn through approximately 60 degrees into
an inverted dive.
14.34.6. Judging the inverted dive segment;
the model aircraft should reach and maintain an
inverted dive with a “straight line” flight path angled
at approximately 60 degrees to the ground.
14.34.7. Judging the intersection; the
intersection of the two climbing/diving segments
should be at a height of 45 degrees line elevation
angle.
14.34.8. Judging the maneuver’s symmetry;
the figure should be flown symmetrically in relation
to its “vertical” center axis.
● 14.34.9. Judging the fourth turn and
bottom level flight segment; the model aircraft should
length of this segment should be slightly more than
1/8 of a lap.
CLA-25
14.34.10. Stop judging; with the model
● 14.34.11. Critical points are; corner angles
are significantly different from 60 degrees. Turn radii
are not equal and/or exceed 2.1 meters (6.9 feet).
Climb and/or dive segments are not “straight line”
flight path(s.) When passing the overhead point, the
line elevation angle does not reach (or it exceeds) 90
degrees within 60 cm. The top and bottom segments
are twisted in relation to each other. The height of the
bottom segment is not at 1.5 meters (4.9 feet)
plus/minus 30 cm (1 foot). The bottom segment is
not flown parallel to the ground throughout. The
intersection point is not at a height of 45 degrees line
elevation angle. Climbing and/or diving segment
flight path angles are not the same and/or produce an
asymmetric maneuver.
14.35. Two Overhead Figure Eights (Rule
13.13.).
14.35.1. Entry; from normal upright level
flight the model aircraft should climb to the overhead
point.
14.35.2. Start judging; as the model aircraft
passes through the overhead point for the first time.
14.35.3. Locating the overhead/intersection
point: the overhead point and the intersection point
should be in exactly the same position—that is; at the
point where the top of the flying hemisphere meets
an imaginary line projected upward at right angles
14.35.4. Judging the first segment (complete
inside loop): from the overhead position, the model
aircraft should fly a complete round inside loop,
returning to the overhead/intersection point. The
bottom of this loop should be at a height of 45
degrees line elevation angle plus/minus 30 cm (1
foot). “Round” means with no visible deviation from
a circular flight path. This loop should be flown
symmetrically to an imaginary line on the face of the
flying hemisphere drawn upward at 90 degrees to the
axis of the model aircraft’s climb to the intersection
point.
14.35.5. Judging passage through the
intersection point and transition into the second
(outside) loop segment; the intersection point should
be maintained throughout the entire figure eight. At
the time of passing through the intersection/overhead
point, the model aircraft should smoothly transition
into the second (outside) loop without visibly
following either a “straight line” and/or a curved
flight path. As it flies overhead the center of the
ground circle, the model aircraft should be
momentarily in a “knife edge” position with a line
elevation angle of 90 degrees.
14.35.6. Judging the second segment
(complete outside loop); from the overhead position,
the model aircraft should transition smoothly into the
second round (outside) loop, returning to the
overhead/ intersection point. The bottom of this loop
angle plus/minus 30 cm (1 foot). “Round” means no
visible deviation from a circular flight path. This loop
should also be flown symmetrically to an imaginary
line on the surface of the flying hemisphere drawn
upwards at 90 degrees to the axis of the model
aircraft’s climb to the intersection point (14.35.4.).
14.35.7. Judging the second figure eight; the
individual segments above. The second eight should
the second eight should be superimposed on top of
the first eight) and should be of exactly the same size
as the first eight.
14.35.8. Stop judging; at the end of the
second (outside) loop as the model aircraft passes
14.35.9. Exit procedure; should be flown as
or marked.
14.35.10. Critical points are; model aircraft
is not vertically overhead (90 degrees line angle) at
the time of entry into the maneuver. Loops are too
big with bottoms reaching down below 45 degrees
line elevation angle. Maneuver shows left/right 45
degrees line elevation angle asymmetry. Maneuver
shows front/rear asymmetry. Maneuver orientation is
“twisted” in relation the “vertical” entry center line
axis. Loop(s) are not same size. Loops are not round.
Model aircraft is not 90 degrees overhead when
passing through the intersection point. Model aircraft
curves left/right when passing through the
intersection point. The intersection point varies from
its initial position as defined by the entry point. The
second eight is not superimposed exactly on top of
the first.
14.36. One Four-leaf Clover (Rule 13.14.).
14.36.1. Entry; “... level flight at
approximately 42 degrees elevation” means that the
model aircraft should be in upright level flight at a
height of 42 degrees line elevation height before
starting the first (inside) loop.
14.36.2. Start judging; with the model
aircraft in upright level flight at a height of 42
degrees line elevation angle, just before the point of
entry into the first (inside) loop.
14.36.3. Judging the complete first (inside)
full loop figure; “full inside loop” means a full 360-
degree circle which is positioned tangentially to an
imaginary “vertical” line drawn upward at right
angles from the ground. The lateral position of this
CLA-26
line is determined when the model aircraft reaches a
“vertical” attitude for the first time and this
imaginary line then becomes the lateral reference for
the whole maneuver. The top of the first loop should
be tangential to the wingover path located at 90
degrees to the center line axis of the whole maneuver.
The model aircraft should recover into upright level
flight at a height of 42 degrees line elevation angle
plus/minus 30 cm (1 foot). “Round” means with no
14.36.4. Judging upright level flight at 42
degrees line elevation angle; at 42 degrees line
elevation angle the model aircraft should follow a
“straight line” flight path parallel to the ground in
upright level flight. The length of this segment
should be equal to the diameter of the first (inside)
loop.
● 14.36.5. Judging the second (outside) 3/4-
loop segment; “... three-fourths of an outside loop”
means an arc measuring 270 degrees. The 270
degrees of this loop should be flown as a true circular
arc without visible deviations from a circular
flight path. The bottom of this loop should be at a
foot) and this loop should end with the model aircraft
entering “vertical” climb whose flight path is the
same as the great circle line resulting from flying the
first loop.
14.36.6. Judging the first “vertical” climb
segment; the model aircraft should climb vertically
(at right angles to ground) and the length of this
segment should be equal to the diameter of the first
inside loop.
14.36.7. Judging the third (outside) 3/4-loop
segment; “ ... three-fourths of an outside loop”
height of 42 degrees line elevation. The loop should
end with the model aircraft recovering to inverted
level flight at a height of 42 degrees line elevation
14.36.8. Judging inverted level flight at 42
inverted level flight. The length of this segment
loop.
● 14.36.9. Judging the fourth (inside) 3/4-
loop segment; “... three fourths of an inside loop”
arc without visible deviations from a circular flight
path. The bottom of this loop should be at a height of
1.5 meters (4.9 feet) plus/minus 30 cm (1 foot) and
this loop should end with the model aircraft entering
“vertical” climb whose flight path is the same as the
great circle line resulting from flying the first loop
(14.36.3.).
14.36.10. Judging the second “vertical”
climb segment; the model aircraft should climb
vertically (at right angles to ground) and the length of
this segment should be such that the model aircraft
flies through the complete clover leaf figure.
14.36.11. Stop judging; at the end of the last
“vertical” climb as the model aircraft passes through
a point exactly at right angles to the center of the
ground circle.
14.36.12. Exit procedure; should be flown as
or marked.
● 14.36.13. Critical points are; model
aircraft is not flying level at a height of 42 degrees
line elevation angle plus/minus 30 cm (1 foot) at the
time of entering the figure. The top of the first inside
loop does not meet tangentially, or overshoots the
wingover path. The model aircraft recovers at a
height other than 42 degrees of line angle elevation.
The model aircraft climbs or descends during any
level flight segments. The 42 degrees angle of line
elevation level flight segments are too short or too
long. The bottom of the second (outside) loop is not
at a height of 1.5 meters (4.9 feet) plus/minus 30 cm
(1 foot). The first “vertical” climb is not at a right
angle to the ground. The first “vertical” climb is not
tangential to the imaginary “vertical” line defined by
the first loop. The top of the third (outside) loop does
not meet tangentially, or overshoots the wingover
path. The model aircraft recovers into inverted level
flight at height other than 42 degrees of line angle
elevation. The bottom of the fourth (inside) loop is
not at the same height as the bottom of the second
(outside) loop. The “horizontal” and “vertical” flight
segments are not superimposed one on top of the
other. Loops are not of the same size. Loops are not
round. The figure is not symmetrical in both axis.
The final “vertical” climb is not at right angles to the
ground.
14.37. Landing (Rule 13.15.).
14.37.1. Entry: when model starts descent
from level flight.
14.37.2. Start judging; when the model
aircraft leaves the descent entry height at the
beginning of its engine-out landing approach (glide).
14.37.3. Judging the descent segment; “...
descends smoothly” means that during the glide the
rate of descent should remain constant.
14.37.4. Judging the touchdown segment;
“... with no bounce or unusual roughness” means
that the model aircraft gently touches down once only
CLA-27
and then remains with all its main wheel(s) in contact
with the ground throughout the entire ground rollout.
14.37.5. Judging the ground rollout segment;
The model aircraft should come to a stop within one
lap of the touchdown point.
14.37.6. Additional factors for judges
consideration; “Unusual circumstances outside of the
pilot’s control” are either ground-surface conditions
or obstacles which suddenly appear to be apparently
in the approach and landing path. The appearance of
such obstacles could lead to the competitor making
sudden, unplanned, and/or unspecified maneuvers
for safety reasons and should therefore not be
penalized by the judges. Similarly, a rough ground
surface could cause a model aircraft to bounce on
landing without the competitor being able to control
the bounce so again rough ground at a contest site
should not be penalized by the judges. But with the
exception of safety hazards such as an impending
thunderstorm, weather conditions generally, and wind
conditions especially, should not to be considered as
“unusual circumstances outside of the pilot’s
control.” Wind and weather should not therefore be
considered by judges when awarding marks for the
Landing, except during the last phase when, as stated
at 14.10. as an example, a sudden gust of wind
coming from behind the model aircraft could cause it
to flip over or tip onto its nose during the ground
rollout, but with the competitor powerless to prevent
the resulting “crash landing.”
14.37.7. Stop judging when the model
aircraft ceases the ground roll which is clearly in a
forward direction and in line with its normal flight
path.
14.37.8. Stop timing when the model aircraft
has come to a complete stop at the end of its ground
rollout.
14.37.9.Awarding marks for “irregular”
landings; the Mark 0 (zero) points should be awarded
for the complete landing maneuver if the model
aircraft crashes; if it lands on its belly; or if it lands
upside-down. The Mark 0 (zero) points should also
be awarded if the model aircraft flips over, but this
example is subject to the notes at 14.37.6. The Mark
0 (zero) points should also be awarded for the
complete Landing maneuver if the official
timekeeper confirms that the model aircraft has come
to a stop after the total time allowed has elapsed
(Rule 8.).
14.37.10. Critical points are; the model
aircraft does not fly level at the beginning of the final
descent. The rate of descent in the gliding approach
is not steady. The model aircraft touches down on its
tail or nose wheel(s) before the main wheel(s) touch.
The touchdown is not gentle, and/or there are
multiple main wheel touchdowns. The ground rollout
is longer than one lap.
14.37.11. Additional remark; it is
recommended that one member of the Judges’ Panel
makes a note of the total elapsed time on the score
sheet of each competitor.
Post by: Jim Thomerson on December 11, 2006, 12:18:01 PM
Is this from the official AMA rules? I presume it is, but you should modify your post to give attribution.
Sorry, I missed the atribution.  Never Mind! :-[
Post by: Tom Perry on December 11, 2006, 12:57:33 PM
Jim,
He referenced it in the first post.
Randy,
A link would take up a lot less space.  AP^
Post by: PatRobinson on December 11, 2006, 07:14:08 PM
Randy,
As you know I have been judging in the southeast since the early 1970's and
early on I realized that in order for me to be consistent I had to take the rules
and get a clear vision in my head of what an ideal maneuver looks like and then
judge every flight against that distilled rulebook ideal.
I have judged with many, many other people in all those years and there were
some scores of other judges I didn't understand. After the contest was over I
would sometimes ask what that judge saw in a honest & friendly way.
What I usually found out was that the judge was:
1. Effected by a halo of a name flyer
2. The judge was judging flyers against each other which led to balooning or
     inconsistent scores because there was no rulebook standard to measure
     against.
I guess my point is that instilling a clear vision of what a correct maneuver looks
like is the first requirement and it seems to be the hardest to acheive.
Even if a judge has a flawed vision of what is "correct" their judging will be more
consistent that without that vision.
Another factor in judging is perception. A good baseball batter can perceive a fast
ball differently than a spectator and he can hit it. A stunt judge must develop the ability to "see" the pattern and judge it. I have sat and practiced judged with friends during regular flying sessions and I have found that some people don't "see" shape or size errors and others can't "see" intersection errors in round 8's and etc. With coaching their ability to "see" does improve.
All I'm saying is that these are basic concerns that need to be addressed before
more rigorous judging process can occur. Someone like me could refine my number assigning process within the context Randy envisions because I already
have the basic skills.
I am loathe to criticize other judges because these are almost always good guys who are willing to stand out in the prevailing weather and volunteer their time and effort to help the sport. Most of these guys take their judging duties seriously with a commitment to be fair and accurate. What is sometimes missing are the basic skills that I have listed that may impact their results.
                                            Well, thats my 2 cents based on my experience.
                                         respectfully , Pat Robinson
Post by: RandySmith on December 11, 2006, 09:38:38 PM
Hi Pat
Yes  very well  said. i especially agree with this statement from you.....
""I am loathe to criticize other judges because these are almost always good guys who are willing to stand out in the prevailing weather and volunteer their time and effort to help the sport. Most of these guys take their judging duties seriously with a commitment to be fair and accurate. What is sometimes missing are the basic skills that I have listed that may impact their results."""
You have to remember that most everyone that  gives up their time  to serve the event and flyers by working and judging  all  deserve  a  special   Thanks...
What is  needed is  to keep up communications with each other to help develop, and  keep  the rules  clear...and  universal  across  the  US
Regards
Post by: Ron King on December 12, 2006, 02:47:47 PM
The thing that upsets me the most is the "Bracket" judging I have seen from a few folks. They do not use the full scoring range as specified in the rules, but judge Beginners in one area (say 10 - 20 points), Intermediates in another (10 - 30), and so on.
I got into an interesting discussion with a judge once when he would not give me a straight answer to a simple question: "What score would a Beginner get if he made a perfect take off and level flight?" He started waffling and said he had never seen one, which was the wrong answer for me.
When I see something like this, I do not go back to that contest.
Take care,
Ron
Post by: PatRobinson on December 12, 2006, 07:24:30 PM
Well Randy, on thinking a little further there is another attribute that I use and have seen used by good judges which I have never seen discussed anywhere before now and it fits in with the theme discussed so far.
Judges are not number-crunching atomotons, we are people and our attitude impacts on how we process our experiences. The message that I am hearing is that the GOAL is that every flight will be a "blank slate" without any preconceived limited expectations of a flyer based on history of previous scores, flying class, quality of airplane, personal relationships good or not so good or anything else other than flight performance.
If a judge is to bring his "A-game" he must develop the habit of bringing his enthusiasm for stunt to the circle. I am not sure how I came to do it but with every pilot I am now cheering and rooting for them to "WOW-ME" with a perfect rulebook flight. The advantage is that it clears the judges mind and creates the desired "blank slate" which let's the judge focus just on the flight in front of him.
When you start out enthusiastically expecting a perfect rulebook flight then you notice the dissapointment of each error more clearly which is in line with Randy's
error deduction process.
If a flyer blows the takeoff and the wingover and you still maintain a positive expectation and he then nails a 38 point loop you are better prepared to score it correctly than if you had lowered expectations.
If you are hot, tired and your feet are hurting it is your enthusiasm that will keep you focused on the flight you are judging. So attitude also helps consistency.
As I said before, every really good judge I have seen has found a way to develop and to make a habit of this attitude. It has been apart of my judging process for so long I take it for granted so I almost forgot to share it here.
I guess what I am saying is that developing good attitude habits may be as important to good judging as good scoring skills.  Enthusiasm and positive judging attitude is the motive force that propels good judging.
This is an area that has been pretty much ignored,so I hope it is a helpful addition to the discussion.
        Happy Holidays Everyone,
        Pat Robinson
Post by: RandySmith on December 12, 2006, 08:00:04 PM
HI Pat
Again I agree with you, however  I do want to clarify  this statement from you...
""When you start out enthusiastically expecting a perfect rulebook flight then you notice the dissapointment of each error more clearly which is in line with Randy's
error deduction process.""""
The error deduction that the rules refer to are  not  my  deduction system,  these  are  the  rules and guidelines  right out of the  AMA  rule book  and  manouver  description guide
Regards
Post by: john e. holliday on December 13, 2006, 04:44:56 PM
Yep, nothing like putting in one of the best patterns you have ever done for the year just to find out it was downgraded because it took a half lap for the engine to get up to speed.  The second round was flown without any care for precision and score went up 50 points.  DOC Holliday
Post by: Trostle on December 14, 2006, 04:43:25 PM
(clip)
  DOC Holliday
What judge in his right mind would downgrade because the engine was not running up to some standard fixed in his mind?  The only thing to be judged in the takeoff  maneuver  is the flight path from the point of release to the point where the plane has completed the third lap over the point of release.  Engine speed has nothing to do with that.
I think most judges are very conscientious with the job they do.   Unfortunately, some of them do not always understand the rules or for some reason have some strange ideas of what the rules say or do not say.
Keith Trostle
Post by: PatRobinson on December 14, 2006, 08:02:51 PM
Randy,
My apology for not communicating more clearly. It was not my intent to imply that
you were the source for the rules and judging process being discussed but only
that within the "context of this thread" you were the source that brought the focus and emphasis as to how this process should work within the rules. I should have said something like "judging process referenced by Randy". Again I apologize.
                                                            Respectfully,
                                                           Pat Robinson
