  • July 06, 2025, 03:28:39 AM
Author Topic: What brand of nylon or plastic 2" spinner fits up to nose ring like a?  (Read 3145 times)
Offline Charles Carter
  • Flying Control Line Stunt
What brand of nylon or plastic 2" spinner fits up to nose ring like a typical aluminum spinner. I don't like the extra flashing that a dubro spinner has. Please no "Great Planes" with the aluminum backplate.
Charles Carter
Re: What brand of nylon or plastic 2" spinner fits up to nose ring like a?
« Reply #1 on: December 26, 2020, 10:49:34 PM »
Charles Carter
  I don't know of any where the edge of the cone is lined up with the thrust washer - they are all offset, at least all of those I have seen.
Offline Craig Beswick
« Reply #2 on: December 26, 2020, 11:03:00 PM »
Charles,
Gemfan spinners have the nylon backplate you are after but I'm not sure I would use them.
Your choice. Google, "Banggood". Only a couple of bucks each but I fear you are paying for what you get.
All the best
Craig
AUS 87123
"The Ninja"
« Reply #3 on: December 26, 2020, 11:13:34 PM »
I have one already with no name on it.   I am just trying to obtain some more in different colors.
Charles Carter
« Reply #4 on: December 26, 2020, 11:28:02 PM »
Charles Carter
   The usual workaround is a plywood disc thick enough to make up the difference.
« Reply #5 on: December 27, 2020, 12:37:07 AM »
Are you referring to the Dubro spinner?
Charles
Offline jfv
Jim Vigani
Offline John Paris
« Reply #7 on: December 27, 2020, 07:17:00 AM »
 Sig carried plastic spinners with flush backplates.  It looks like they still do but nothing in the 2 inch size on their website.  Good luck on the search.
John Paris
269
« Reply #8 on: December 27, 2020, 07:31:28 AM »
Charles:
You might try one of these CF spinners.  They have a CF backplate.  Reasonable price.
https://www.ebay.com/itm/1PC-1-75-2-25-2-5-3-5-4-75-5-5-6-7inch-Carbon-Fiber-Spinner-For-Gas-RC-Airplane/253529315898?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Just a warning. ZYHOBBY have some good stuff, I have purchased from them in the past, but those carbon fibre spinners don't have an adapter with them. You have to find your own way of attaching the cone to the prop shaft!
Craig
AUS 87123
"The Ninja"
Offline bill bischoff
« Reply #9 on: December 27, 2020, 08:53:26 AM »
Airborne Models (airborne-models.com) has 2" spinners with flat backplates in assorted colors. However, it appears that they all come with black backplates.
« Reply #10 on: December 27, 2020, 10:11:26 AM »
Charles
  DuBro and Carl Goldberg, among others. Kavan, too, I think. All the plastic spinners I ever used had about the same thing, it had to be thin enough to fit on the shaft but thick enough somewhere to take the loads, so the drive washer is recessed.
« Reply #11 on: December 27, 2020, 11:57:58 AM »
Charles,
If you need to have the spinner edge be a certain dimension from the fuse ring one way with the Dubro snap togethers is to us a spacer washer between the engine drive washer and the spinner backplate. Make sure you rough up the washer surface so it doesn't slip. I like the electric plastic spinners with the bolt on flush backplate. These are ok if you don't use an electric starter. If you don't like the silver backplate ring just prime and paint the whole spinner/backplate.
Best,    DennisT
« Reply #12 on: December 27, 2020, 11:04:45 PM »
SIG. Danny Dirt used to use those on some of his Slight Freaks and Impax.   H^^ Steve
Offline BillP
« Reply #13 on: December 29, 2020, 08:33:43 PM »
I checked my stash of old spinners today and found a 2-1/2" Dubro with the flush backplate. It has two nuts recessed in the backplate for screws and is about 30 yrs old give or take. I don't know if they still sell this type but its definitely marked Dubro on the backplate.
Bill P.
« Reply #14 on: December 30, 2020, 10:25:06 PM »
Charles,
I might be able to print you one.  I printed some like this from ABS.  Some issues:
1. They are only for 3-blade props.
2. They fit snugly around the prop, so they'd be nicest if made for your specific prop.
3. I've never run one.  I gave one to Eliott, so you might first see if his disintegrated.
4. They are rough as printed, but finish up nicely.
5. They are blunter than what most people like.  I like them, though.
« Reply #15 on: December 31, 2020, 02:01:41 PM »
Charles Carter
Other than the GP spinners with aluminum backplates, plastic spinners are typically much heavier than aluminum spinners from Randy Aero, Tru-Turn and Dave Brown. If you need the nose-weight, continue as you are. If you happen to need a 3-blade spinner, Mike Haverly has successfully joined an aluminum backplate from the GP spinner and a 3-blade DuBro cone. I'd be more thinking of making a new aluminum backplate for the DuBro cone. Epoxying and/or screwing the backplate to the prop driver is always a good idea, IMO.
The problem with plastic backplates is that they are so thick that you'll run out of threads on the crankshaft on many engines, plus they tend to kick the prop loose occasionally...almost always on official flights.
Regarding those CF spinners...both Tru-Turn and Dave Brown sell adapters that usually will work or are a good start. I have had to re-machine adapters and spinner cones to make them all behave together. Boring out the counterbore in the spinner cone of a Chinese aluminum (metric) spinner to fit an SAE socket head screw isn't so much fun. Probably even worse if it's CF. I think all the adapters made here take an SAE screw thread. It might be possible to rework one to use a smaller or metric screw with the use of a Helicoil or Keensert.    D>K Steve
« Reply #16 on: December 31, 2020, 02:33:22 PM »
Steve, call me a Globalist, but I have discovered that metric screws and even metric taps are available in the USA.
I use GP backplates for the FDM spinners I’ve been using for the last six years.  The GP backplate has six spokes. All you have to do for 3-bladers is to drill and tap four (two if you’re thrifty) spokes for M3 screws. Some day I’ll have a nose-heavy airplane, but for now the plastic spinners work a treat.
« Reply #17 on: December 31, 2020, 03:03:54 PM »
Globalist, that's pretty commonly known, and I have some of each. But when you have an adapter hecho en Estados Unidos Americanos and a spinner cone hecho en Chine, you gotta fall back on technology to joint 'em up. Like I wrote above, I don't believe Tru-Turn or Dave Brown make adapters that use a metric thread for the central attachment screw. I also didn't want to drive down to Screws R US to buy one SHMS.  D>K Steve
Offline Dave Rigotti
« Reply #18 on: January 22, 2021, 11:46:23 AM »
Just rec'd 2" spinners from HobbyKing. Nearly identical to the Great Planes ones.
The red is Great Planes, white is HobbyKing.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline kevin king
« Reply #19 on: January 22, 2021, 12:24:36 PM »
Sig spinners used to have a flat backplate. Don't know if they still make them.
