  • July 18, 2025, 01:56:25 AM
Author Topic: What are you guys using.....  (Read 2481 times)
Offline Terry Bolin
  • Havin' the time of our lives!
« on: December 27, 2006, 09:25:58 AM »
 ::) What are you guys using for Stuges to hold your planes when flying by your self. Post pictures if possiable. ...........Santa was good this year.........Two kits!
Thanks to Sam's Hobbies!   Good people!
Terry Bolin
Neosho Mo.
Offline Bob Johnson
  • Lone Eagle Stunt Flyers -Have stooge. will travel.
Re: What are you guys using.....
« Reply #1 on: December 27, 2006, 09:38:48 AM »
Hello Terry,
Here is my home made Stooge. Pretty easy to do. There are of course, simplier setups than this. The day glow line/ winding paddle is easy to see, and the lenght is adjustable for different planes. If you want more info let me know.
Bob
« Last Edit: December 27, 2006, 11:03:07 AM by Bob Johnson »
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« Reply #2 on: December 27, 2006, 10:52:18 AM »
Terry:
I am not as creative as Bob and I liked his self contained kit approach and will put some of that into my stooge set. I almost always fly solo and need the stooge. However, I bought the Brodak Stooge #BH848 about $19. Works fine for me. Be careful with the stooge line used for release. I used heavy nylon cord and got tangled in it. Cost me a plane. So now I use very light line that I can break if I get my feet into it. I like the idea that Bob uses bright colored line, too.
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #3 on: December 27, 2006, 11:05:49 AM »
I also use a Brodak Stooge.  I just stake it directly to the ground with a couple monster nails and use a large line clip on the tail wheel.  Originally had it mounted to a piece of plywood but that raised the tail of some of my airplanes off the ground enough to create prop clearance problems.
One of our club members has one mounted to a large enough piece of plywood to sit the whole airplane on but I didn't want to deal with a stooge that big.
This reminds me.. My stooge is still out on my flying circle, guess I better go pull it up and reel it in before it snows again.
« Reply #4 on: December 27, 2006, 11:08:37 AM »
Here's mine
Offline mark eisenhut
    • madphotos.net
« Reply #5 on: December 27, 2006, 12:05:05 PM »
i know it isn't pretty but its cheap and it works $1.50 i had the string.
mark
mark eisenhut
Offline Clancy Arnold
« Reply #6 on: December 27, 2006, 02:41:00 PM »
My stooge is similar to Bob and Jim's but I cut the cost.
Bill of materials:
3  screweyes
1 long nail, point cut off and rounded
1 spring from a ball point pen
1 wheel lock for adjustment
60 feet of strong nylon line
1 piece of wire bent to wind the nylon cord on.
1 piece of 1/4 inch plywood about 12 x 12 inches placed under my 50 lb flight box.  50 lb is good for 1/2 A's, use heaver boxfor larger planes.
A slipknot in the end of the nylon line is placed over the head of the nail and pulled tight.  That way it is easy to remove the line when you are done.  I use mine primarily for 1/2 A's.
Clancy
Clancy Arnold
U/Tronics Control
Offline James Lee
« Reply #7 on: December 27, 2006, 03:08:07 PM »
I use a stooge quite similiar to the ones shown...   except..   Having heard of several stooge incidents relating to nails pulling out of the ground, I use a 30# lead brick to anchor the stooge...   Yes, it is a B**** to carry but it does NOT move!!!
Just a thought.   Way back in the day I used a brake rod and clevis from a Model A Ford...  1/4" rod about 12" long driven into the ground....  It didn't come out of soft ground either!
Just some thoughts.
thanks
Jim
Dwayne
« Reply #8 on: December 27, 2006, 03:15:09 PM »
I allways catch some flack for this but I fly off grass so I just use two 10" peices of coat hanger stuck in the ground, I've been doing this for 30 plus years and I've never had a problem.
Dwayne
Offline Glen Wearden
« Reply #9 on: December 27, 2006, 06:45:14 PM »
My stooge is a 18" X 4' piece of 3/8" plywood with a brodak release mounted on one end of it.  The plane sits on the pad, so it can't move and it doesn't decrease prop clearance.  My release line is a spool of orange mason's line.  After having a disaster with a line getting wrapped around my feet, I now automatically throw the spool out in front of me as soon as the plane releases.  I also use the stooge, with a piece of strong nylon cord, as a run-up pad for my RC planes.   Glen
Glen Wearden
Offline Bill Heher
  • Fix-it
« Reply #10 on: December 27, 2006, 09:25:00 PM »
My version is the el-cheapo, but reliable. 4 angle brackets screwed to a 18" long chunk of 2 X 12, a scrap of tubing to guide / stabilize the pin, and a rubber band for the tension spring. I replace the rubber band each time before I use the stooge.
Stooge release line is a cheap chalk line without chalk ( buy a new one, dont put the chalk in the housing, use it to mark your circle center instead), come in a handy winding reel, under 5$ for the whole stooge package, including the rubber band!
Bill Heher
If it's broke Fix-it
Offline peabody
« Reply #11 on: December 28, 2006, 03:23:38 AM »
I think that using the tailwheel to attach to a stooge is asking for trouble...and know from watching that a .40 powered Banshee can take off with lines and a handle and spiral out of sight....
I think that you would be a lot better served building one that holds the tail and flops forward....Windy uses one and flys about 1500 flights per year from one incident free....
Have fun
Offline Terry Bolin
« Reply #12 on: December 28, 2006, 07:18:39 AM »
That looks like a good idea. (holding the tail feathers) I have already started one listed above with the "L" Brackets but I think I will make one of these also since it does not require adding anything to any of the planes.
Thanks, Terry
Offline Russell Shaffer
« Reply #13 on: December 28, 2006, 12:44:57 PM »
I also have mine mounted to plywood.  It provides a good working surface for fueling, adjusting, starting, etc.  Also keeps the fuel off of the very nice soccer field where I fly.  My stooge line reel is an old garage sale fly fishing reel.
Russell Shaffer
Klamath Falls, Oregon
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #14 on: December 28, 2006, 02:22:18 PM »
When I get home I'll post a pic of mine. I used a chalk line reel for the line and use fluorescent strait line I got at local lumber store. It's a elevator weight used to balance elevators be for service.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Bob Reeves
« Reply #15 on: December 28, 2006, 03:35:41 PM »
Have fun
Eventually I plan to permanently build one like that at ground level on my flying field. Going to use a wireless security remote to trigger it. Just need to work out the design so when it's released it's flush so an airplane can roll over it.
« Reply #16 on: December 29, 2006, 07:39:51 AM »
Bob and all others, you have to remember that a stooge should be far enough out that you do not have to worry about moving the pit box or any thing else you are using.  Besides it should be normal to take a step or two back when taking off.  Also what ever is tied to the release should spring back toward the stooge so it does not get tangled up in the feet.  There should be a center marker also.  Don't ask me how I learned all this.  DOC Holliday
Offline Terry Bolin
« Reply #17 on: December 30, 2006, 07:16:19 AM »
 #^ ::)Doc, For what ever reason, I have always stepped back on take off. We all use a 4"square ceramic tile for our center marker, it doesn't blow away.
Terry
