Hey Randy,
This is Mike not Bill but yes, I bought mine from Aircraft Spruce. As far as shelf life goes, I really dont know. I called West before i bought mine and talked to the man who owns it (by the way, a prince of a fellow to talk to) and he did not mention any special storing instructions. I bought a quart of the 105 Resin and the 205 and 206 Hardner. One is slow and one is fast. Make sure you order the pumps so you can screw them in the cans and it will meter out the exact amount you need. The ratio is 5/1 5 parts resin to one part hardner. If you use their metered pumps that equals on squirt of hardner and one squirt of resin and that fits just right in a plastic epoxy cup. This stuf is amazing Randy. After using the hobby shop stuff, this was a pleasant surprise. The slow set, after you mix it, spreads so smooth you wont believe it compared to the Bob Smith stuff you buy from hobby shops.
Anyway Randy, hope this helped. Hope you are doing well. I am going to have gastric sleeve surgery in a week. Hope to get skinny again.
There you go...David posted while I was typing...that will answer your question about shelf life....I havent had mine long enough to tell...
Your friend
