  • July 22, 2025, 12:00:09 PM
Author Topic: Weight Matters? Carried over from SSW  (Read 6480 times)
Offline RC Storick
« on: June 19, 2009, 07:54:40 PM »
Read carefully..
For "ME" weight is the number one important thing on the list of four. Light-straight-ridged-ample power.
I will once again try to get my point across. If the aircraft is light it does not need as much power. Thats two things out of the way right off the top. If its light it does not need to be as ridged and it will flex less in a G turn. Less weight = Less G load on the wing. Now it has to be straight or it will set into motion a number of things that could be trimmed out but why?
I have heard tell light airplanes don't penetrate well? Hummmm most planes are tail heave to get the concentrated weight into motion. With light airplanes lateral roll is much less. Take your hands and hold the plane near the fuse. Roll it left to right. If it rolls easy and stops easy no problems. If you have a ton of tip weight and it rolls hard in your hands imagine whats its doing in a hard G turn? The farther you span concentrated weight out from the CG the more inherent problems you will encounter.
When I say I am a watcher of airplanes these are some of the things I am looking for. Plane comes around into view I can see stab misalignment. Plane goes over the top I can see wing walk. Plane in the turn pushes I see the weight in the nose (doesn't matter how tail heavy it is) The turn and stop function is as much pilot and it is plane.
This will be the first nationals I will attend (as long as it stays in one piece) That I have flown a truly light airframe. 53 oz after trim wishing it was 43.. LL~
The other ones I have been flying are someones else's idea of what works. This does not work for me. How will I do? well I cant say but it will not be because the plane can't do it. Just remember this if its not important how much it weighs why is everyone wishing it was lighter?
I'm sure I will be flamed and you have fun I know I will this season..
Offline Russell Shaffer
Re: Weight Matters? Carried over from SSW
« Reply #1 on: June 19, 2009, 10:04:19 PM »
Actually, Robert, I have to agree with you.  I'm just another mechanic - I fixed railcars - but if heavy airplanes were good we would build them from steel, not aluminum and balsa.  The heavier it is, the harder it is to change direction.  I think it is called inertia.
Russell Shaffer
Klamath Falls, Oregon
Offline RC Storick
« Reply #2 on: June 19, 2009, 10:41:07 PM »
BINGO
Offline Brian Hampton
« Reply #3 on: June 19, 2009, 11:36:03 PM »
Robert, I know you always get flamed for this but in essence I agree with you although I'd say it as low wing loading instead of just weight. By far the best model I've ever flown had a wing loading of 10.25 ounce/sq foot and that was with 830 sq inches. Of course there were other factors that helped make it fly so well but a low wing loading was my main aim in the design and construction. One benefit was that very little flap movement was needed to eliminate any trace of stall which in turn meant as little possible extra drag through hard turns so less speed loss (it only had 5 degrees flap movement).
As for penetration, that's a ticklish one because heading into the wind gives extra drag (puts on the brakes) so a lighter model will lose ground speed faster than a heavy model but adapt to the same air speed faster. Going downwind the lighter model will accelerate faster so get back to normal air speed quicker. I'd suspect that both a heavy and light model would end up having the same ground speed by the time they were upwind but because the lighter model must react faster to the affect of added drag (heading upwind) the perception would be that it's not as good at penetration.
A lighter (weight) model of course is better in vertical climbs because that's a matter of thrust/weight, the wing is providing no lift at all.
Just as an aside, one of the things I sometimes did with mine (for fun) on landing was to touch down on the tail wheel and hold the mains high off the ground until it was down almost to walking speed :).
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #4 on: June 19, 2009, 11:48:46 PM »
Now why am I not surprised at this subject appearing again? Hasn't the beaten
pulp of this horse been beaten enough?
Low weight is important, but so are many things. I've recently noticed that
a superior electric power system definitely offsets the disadvantages of the
weight of its batteries. In fact, when I think of it, I've noticed that virtually
every superior CL stunt ship I've seen has a very good power system. Many
ships which are clearly not at their absolute minimum build weight are still
excellent flyers, thanks to great power. There's a reason competitive stunt
ships tend to be overpowered, and it's not just to overcome weight - more,
it is the way that the power is delivered (torque/thrust characteristics) rather
than the peak amount of power available. This is a reason why the electric motors
work so well.
I'd also submit that the pilot is at least as important variable than model weight.
In conjunction with that are the pilot's talent, and the amount of time and effort
spent practicing.
I wish you the best of luck at the Nats. When you win, you can remind me that
you told me so about the lighter weight.
Best,
L.
Q. When you pat a dog on its head he will wag his tail. What will a goose do?
A. Paul Lynde: "Make him bark?"
Offline Serge_Krauss
« Reply #5 on: June 20, 2009, 12:15:48 AM »
1) I haven't seen anyone even imply that "heavy planes are good."
2) Believe it or not, those of us with physics or engineering degrees have also heard of inertia.
Also quoted from above:
>"Just remember this if its not important how much it weighs why is everyone wishing it was lighter?"
Again, no one has ever said on this or the other forum that it's not important how much it weighs.
Now here's another example of dealing with inertia. Except for negligable fuselage lift, the only force contributing to line tension directly overhead is the force needed to overcome inertia: mv^2/R. This is the centripetal force on the plane or it's reaction force (centrifugal) on the pilot. Either way you look at it, this is the only force adding to line tension. Directly overhead, the weight of the plane, W = mg, is reducing line tension. The total tension in your lines is then simply T = Fc - W = mv^2/R - mg = m (v^2/R - g), where "R" is the flight circle's radius, "m" is the model's mass,  "v" is it's speed, and "g" is gravitational acceleration (32.2 ft/sec^2). g is a constant, and I am led to believe that the ideal is to keep v constant too. That makes v^2/R - g a constant value, leaving the disputed m (which determines weight: W = mg) the only desired variable. Some want it minimized, and some don't always want it minimized.
Given adequate power to propel the plane vertically with unreduced speed, line tension overhead is directly proportional to the plane's mass. As several have explained, this mass does tend to slow the climb, if power is insufficient. So for Fox .35's, you do need lighter planes for vertical performance. However, with the modern powerplants putting out gobs of thrust, the tension overhead is really dictated by mass. As an example, if thrust were varied to keep speed constant, overhead tension would be directly proportional to mass or weight. That inertia also maintains the plane's ground speed as it changes direction or encounters gusts. So inertia can help as well as hurt performance. You need the right amount. Top pilots seem to be saying that their planes can provide a better corner than they can control; so inertia does not have to be a problem with corners at reasonable weights.
SK
Offline RC Storick
« Reply #6 on: June 20, 2009, 05:52:30 AM »
Now here's another example of dealing with inertia. Except for negligable fuselage lift, the only force contributing to line tension directly overhead is the force needed to overcome inertia: mv^2/R. This is the centripetal force on the plane or it's reaction force (centrifugal) on the pilot. Either way you look at it, this is the only force adding to line tension. OOPS I guess he forgot motor ofset.. Directly overhead, the weight of the plane, W = mg, is reducing line tension. The total tension in your lines is then simply T = Fc - W = mv^2/R - mg = m (v^2/R - g), where "R" is the flight circle's radius, "m" is the model's mass,  "v" is it's speed, and "g" is gravitational acceleration (32.2 ft/sec^2). g is a constant, and I am led to believe that the ideal is to keep v constant too. That makes v^2/R - g a constant value, leaving the disputed m (which determines weight: W = mg) the only desired variable. Some want it minimized, and some don't always want it minimized.
This is another thing that gets me. T = Fc - W = mv^2/R - mg = m (v^2/R - g), (32.2 ft/sec^2). "I have" and probably most on here, have no idea of what this represents. Its like the numbers guys are always trying to make them selfs seem Superior to the rest by putting some numbers up that only a few know. (talking down their nose) Please read this close. One test = Ten thousand formulas
This is where everyone with formula's miss it. Wing loading has nothing to do with it. "Better corner than they can control", cut the weight and it would be easer to control
 LL~ Thick skulls require more penetration. Hence the beating..   LL~
And to Larry "when I win" I will probably never win but that doesn't mean my plane is not capable. I just know this the new plane is a allot more fun and easer to fly the the old status quo type planes I have been flying. How many guys have ever won the NATS? Or should the question be. How many guys have won the NATS using someone else's design? If just a handful in either case. Everything has to be working in your favor that day or subsequent days leading up to. Everyone should have the opportunity to try and see all sides to stack the odds in their favor. Not just take the numbers mans word for it.
Just as I stated my thread this is MY idea of what works. They guys who I think like, don't post their ideas like I do because they are meet with this opposition these include many former world and NATS champions.
I don't really care who agrees or disagrees with me. I am just posting my practical observations done in real life time not on paper.
I would like to address the topic of Brian's. most people of late have setup their planes tail heavy to overcome the concentrated weigh in the nose. The sluggish feeling you get when you add the big block. Tail heavy plane turns into the wind and tends to rise thus slowing down. My Viper having been powered by both a ultra light 40 and a .65 this was a great test in this area. The turn and stop function was better with the .40. Penetration is better with the .65. Why? Not because of more power but because of the planes CG shift.
Now people tell me "I cant run nose heavy airplane in the wind" The statement should be, they can't run nose heavy airplanes in the wind" Why can I do it and not most of the rest? Weight! There are a lot of things to cover that this thread would be pages long but heres a thought. Light airplane in the wind thats nose heavy penetrates well. Does it load up in the rounds? YES. Less than if it was heavy. If it gets overwhelming in the load up department adjust the overhang on your handle.
So when you choose your power plant you have set up the baseline characteristic hence the term I use "baseline characteristics are set in weight." This makes no difference in how much you pull the engine back to the CG. Remember the one test = ten thousand formulas statement I made? Well I have many hanging on the wall with all sorts of someone else's numbers and ideas. While this may work for some it does not work for me.
« Last Edit: June 20, 2009, 09:52:55 AM by Robert Storick »
Offline John Miller
« Reply #7 on: June 20, 2009, 07:27:21 AM »
There's one element that may have been overlooked in depth.
Balance and it's relationship to tracking in the round manuevers.
Each and every plane has it's sweet spot for balance. This shows up in the round manuevers. The plane locks in and does great rounds, tracking true with minimal input, other than the initial one to start the manuever.
A plane that does this is niether nose heavy, or tail heavy. It's balanced correctly, no matter whether it appearss to be nose heavy, or tail heavy by visual inspection.
Weight, within limits, is a non factor during this manuever, but I agree that it's best to start as light as you can.
  • Red Hot Lover
    • Stephanie Miller
« Reply #8 on: June 20, 2009, 09:03:09 AM »
What Serge was referring to was the fact that overhead line tension consists of the centrifugal force minus the 1G force of gravity. That's from inertial components (ignoring aerodynamics). It's physical law.
While one test may equate to ten thousand formulas to you, I have to ask, how is the "test" being conducted? How are you measuring line tension, for example? What kind of controls do you have over the variables? (say wind speed, and model speed?). I'd challenge this notion that some subjective "test" somehow is worth ten thousand "formulas" - perhaps to you, to your way of thinking. But in reality, ten thousand formulas (equations would be a better word) can pretty well express the system dynamics of a model airplane on flying on a tether.
You seem unreasonably hostile toward physics and scientific analysis, Robert. Why? What's been described is simple algebra, the kind you learn in high school. In reality, more serious analysis uses calculus, derivatives and integrals, quadratic equations. At the Newtonian level, physical things beautifully obey laws which are well defined by now. I don't see what is inherently wrong with us using mathematics to understand physical behavior, it works so well, it's another TOOL.
As we investigate and learn about physics and the math that describes it, many of us are impressed by the *beauty* of it all. It's very "clean" and beautiful in the same way that any good design is. The incomplete nature of our understanding the real world has a lot more to do with imperfect data plugged into equations. Often there are seemingly unimportant features which end up being significant to the result. Or vice versa. This "fuzzy" nature of things is well noted in our CL stunt model airplanes.
I always am impressed with and commend people who strive for excellence, working hard. But I submit to you that a truly serious effort needs to involve a lot more than cut and try and seat of the pants evaluations. Here's what I suggest - without delving deeply into integrals and quadratic equations, give the basic ones their due; a starting point. Awareness of the properties of mass and inertia, gravity. Effects of center of gravity, and moment of inertia. Some idea of the actual forces and performance involved, from actual measurement.
So, any real ideas about the specifics of your model? What is its moment of inertia? How about its actual performance? What forces is it experiencing? What are its actual velocities at various parts of its pattern?
Oh, and don't forget - what's the definition of "good"? Specifically, what are we seeking to optimize? What define a great stunt ship? How about its control transfer function. How is it damped? Sure, we want to turn a perfect 5' radius corner. But various analyses, including my own, have concluded that our very best stunters are actually performing a 15' radius square corner (I measured 17' from videos).
Damping characteristics of the control system are particularly important. Overdamped and the ship is sluggish, underdamped, it tends toward instability and oscillation, and critically damped, it is (perhaps) "just right", not overshooting or barely doing so, and (near) optimum in terms of performance. In reality, the control system transfer function is what we "feel" when flying, it's what makes us really like or dislike a model, and a function of how well it flies and how easy it is to fly well.
Yes, the transfer function for the control system is greatly affected by weight. And how that weight is distributed (e.g. moment of inertia). But there's also a myriad of other parameters. Obvious ones include wing loading, size of flaps and elevators and their position relations (flaps dampen the control function, by generating an opposing couple). ((If you really demand highest turn performance for square corners, perhaps you should have an unflapped model - see Serge's and Ted Fancher's work in that direction.))
Note that moment of inertial, distribution of the weight, so terribly important to us, is not so easy to measure directly, at least not "by hand". And the serious computations nowadays break components into small triangular elements, which are all considered to do the analysis. In a cruder but useful manner, by knowing the weight and position of various components of your model, you can calculate and estimate its moment of inertia.
Other complexities - thrust and drag, vertical CG, centers and means for aerodynamic forces. The gear's drag and inertia effects. The quality of the stunt airfoil (I learned to appreciate just how great Al Rabe's airfoils are - watched a profile Mustunt with a broken line perform maybe twenty 8' diameter loops before eventually crashing). Airfoil performance - so very important.
Tip weight, leadout positions, flap design (full width or with stationary tip flaps?) stab/elevator design (aspect ratio, area).
And OMG, engines, props, fuel, line diameter and type.
More than WEIGHT is involved. Begin with as much information and knowledge as possible. Then meticulously work on the problem, never denying yourself any tools, including math. If you have a math barrier, work to remove it.
One other thing, Robert. Please stop with the defeatist attitude: "I will probably never win.." Where is that law written? Look at the facts, you are a prolific builder, master craftsman, and finisher. You're very serious about CL stunt and devote a lot of time and effort to it. I would venture to say you're in the top few percentile of stunt contenders, and you are working very hard to get better.
We both know that we are beyond our physical primes, but remember that CL Stunt is pretty much an old man's game. So, I admonish you to flush the defeatism. Kick some butts at the Nats.
I'll look forward to the photos and details of the contest.
Best,
L.
"And all who told it added something new, and all who heard it, made enlargements too." -Alexander Pope
Offline Dick Fowler
« Reply #9 on: June 20, 2009, 09:33:51 AM »
Robert - "This is another thing that gets me. T = Fc - W = mv^2/R - mg = m (v^2/R - g), (32.2 ft/sec^2). "I have" and probably most on here, have no idea of what this represents. Its like the numbers guys are always trying to make them selfs seem Superior to the rest by putting some numbers up that only a few know. (talking down your nose) Please read this close. One test = Ten thousand formulas"
Robert, I know Serge and the last thing this mild mannered guy would want.... would be to project an attitude of superiority. I know he's a Physicist by education and a teacher. I think the teacher comes out in Serge in these situations and he wants people to understand the physical laws and effects of certain characteristic such as weight with respect to tethered flight. If you met Serge, I bet you would like the guy.
« Last Edit: June 20, 2009, 03:06:42 PM by Dick Fowler »
Dick Fowler AMA 144077
Kent, OH
Offline RC Storick
« Reply #10 on: June 20, 2009, 09:38:17 AM »
Its not directed at him personally. I'm sure I would and mean no harm in my post. Its always the same guys posting numbers that a select few have any idea what they are referring to. I for one have none and I am sure there are many others. I think I should start a numbers section for all the people who do understand that stuff to post in.
And I did and the logical choice for moderator is? You guessed it...
http://stunthanger.com/smf/index.php?board=64.0
Believe it or not I like everyone here. My next airplane won't be built using plywood tho!
« Last Edit: June 20, 2009, 10:00:07 AM by Robert Storick »
« Reply #11 on: June 20, 2009, 11:52:03 AM »
Just curious, Sparky.
How many tests would it have taken a roomful of mechanics (with all their math books burned on the altar of pragmatism and instead relying on "TLAR" [that looks about right]) to be able to land men on the moon and bring them back?  How much would each failed test have cost in both dollars and human energy?
IMHO, any attempt to improve the breed that doesn't include an objective analysis of the shortcomings of the prior attempts is inherently inefficient ... need I say more than Viper #12 and counting?  That's pretty much why I asked the question in your Viper thread about what changes you had made from version to version, what the effects of those changes were and how did you determine to resolve those shortcomings.  With all due respect, your response that you had tried other peoples' "numbers" and found them wanting isn't particularly illuminating.  Finally, like John, I believe you have really short changed other factors that are of even greater significance than ultimate light weight (and, NO, I'm not suggesting building airplanes purposely heavy).
I share with you the lack of expertise to do the "heavy" math with which guys like Serge, Brett, Howard etc. are so facile.  Rather than disparage them for their expertise, however, I regret having either sufficient wisdom or dedication to inform myself as completely.  I regret it for the simple reason that being able to objectively analyze the specifics of our vehicles and the medium in which they operate was an anchor to my ability to excel at our joint avocation.
Notwithstanding my comparatively meager skills in math I did cobble up a mathematical system of my own whereby I could, in a rudimentary fashion, evaluate the effects of changes in the various important parameters of stunt model design.  This started by measuring and cataloging (along with Bill Fitzgerald, David's dad) the basic numbers of dozens of published designs back in the early '70s.  After informing and evaluating those numbers and addressing what we felt were shortcomings in them, we determined what we felt was necessary to accomplish the limited improvements in performance we were seeking and made "educated" decisions about how to proceed to improve the breed.
Yup, the changes were modest but functionally positive in every instance over the years. (the sole exception being my experiments with a swept forward flap hingline on the Excitation which I determined wasn't an obvious plus and might have been a minor step backward.  Hard to tell because the Excitation was very competitive at the highest levels even so.)
Oh, and by the way, I've stolen unashamedly from any number of outstanding stunt fliers over the years when it became obvious they had some great ideas (generally by virtue of them kicking my [and everybody elses'] butts).   Bob Gieseke, Bob Hunt, Denny Adamisin, Al Rabe, Paul Walker ... just to name a few.    To not do so and ignore the wealth of knowledge others have so freely given is absolutely the most foolish waste of important resources I can imagine.  In addition, I've always given credit to them as the source of the changes I made to my own program.
Sorry if you consider this a flame.  I simply consider it a difference of opinion which is sort of what makes the world move forward.
Ted
p.s. Sparky,  if you think the Wright brothers got us heavier than air persons into the sky based strictly on their skills at repairing flat bicycle tires and oiling the chains I think you should probably read up on the brothers' efforts a bit more before diminishing their willingness to analyze their ideas in an objective manner before "testing".  It takes both, my friend.  And if the analysis is good, the testing is reduced.
Offline Jim Pollock
« Reply #12 on: June 20, 2009, 01:53:47 PM »
Well, Robert
Some unexpected support coming your way regarding airframe weight is probably from the great Joseph Gabris.  I read somewhere that his Super Master had well over 600 Sq In wing area and weighed a whopping 43 ounces. Now that's some pretty light weight from a two time consecutive world champion flyer.  I think even Igor pays homage to the superior building and flying of Joseph.  Lighter may not always be necessary to win, but it sure does make planes fly better.
Jim Pollock   :o
Offline Scott Hartford
« Reply #13 on: June 20, 2009, 04:34:18 PM »
If weight is job #1, why not fly smaller planes? :!
Offline RC Storick
« Reply #14 on: June 20, 2009, 04:43:41 PM »
Thats a idea why didn't I think of that? doh I did.. Although nothing is new..
Offline billbyles
« Reply #15 on: June 20, 2009, 05:29:18 PM »
You guys need to get a grip quick. Everything we use today started in someones basement, Garage or attic. Even this computer you are talking on now. Your phone. Just about everything came from some inventor in the private sector. While some may have been engineers I don't believe for one second that everything the we use was made by one.
You are correct that many of these items may have originally been designed initially in someone's garage (and I know for a fact that they were as witness Hewlett-Packard, Apple Computer, Robert Goddard and his rocket engines/rockets, Henry Ford's cars, etc.), but they sure didn't get to the level of sophistication that exists today by being built in a garage by a guy flying by the seat of his pants using a Crescent wrench (even if it is a Snap-On wrench).
Bill Byles
AMA 20913
So. Cal.
Offline Keith Spriggs
    • khspriggs
« Reply #16 on: June 20, 2009, 05:37:20 PM »
TLAR method used by judges everywhere............
An automobile with an internal combustion engine can never exceed 176 MPH in 1/4 mile.
(Said by someone, widely quoted, and believed by just about everyone circa early 1950's)
Offline billbyles
« Reply #17 on: June 20, 2009, 05:44:00 PM »
I don't know about the 176 mph limit (I never heard of that one) but I read that back in the late 1800s when cars and automotive I/C engines were being developed some wisdom-filled wag said that the human body cannot survive at speeds over 35 mph regardless of the method used to get to that speed...
Bill Byles
AMA 20913
So. Cal.
Offline RC Storick
« Reply #18 on: June 21, 2009, 10:52:06 PM »
Edit out all the superfluous non weight topics.
Offline RC Storick
« Reply #19 on: June 22, 2009, 05:13:00 AM »
Everyone can think as they wish thats free thinking. I like many think that light is right. Here a message I got from someone, (Can you guess who)
Quote from: Robert  Storick
on June 21, 2009, 07:15:16 AM
Please post some trim and flight reports on your plane. I for one am interested to know if your ready to add weight... LMAO
I DID add ballast.
Used the next size larger motor (+1oz) and pushed the battery to the back of the box.  Also added a sub-fin (side area) to improve calm weather performance.
I'm "ballasted" all the way up to 41.5 oz.  Yesterday flew in wind/turbulence that blew Windy's 65 oz RoJett 75(?) powered "Tribute" out of his pattern.
There are a lot of things I want in the wind - but extra weight is not one of them!
Offline Mike Palko
« Reply #20 on: June 22, 2009, 11:08:06 AM »
Hi Sparky,
   I have seen a number of these threads popping up and I admit I haven't followed them as closely as I should/want to. At what point do you consider the wing loading to high? Sorry if this has been mentioned already.
Offline RC Storick
« Reply #21 on: June 22, 2009, 11:11:05 AM »
To be honest I don't really think of wing loading as it is a non factor. A 40 oz object moving at 55 MPH will change direction faster than a 70 oz object. And be easer to control to boot.
This in not real aircraft it tethered flight.
Offline Charlie Pate
« Reply #22 on: June 22, 2009, 11:36:32 AM »
Simply put : A good thing carried too far becomes a bad thing.
I find with engine weight  ,tank, wheels , gear ,horns ,there is not a ton you can take off.
Airframe ,covering and , paint seem to me to be about the only place you can lighten up.
 I would be interested in hearing the percentage (total hardware to airframe per sq. .in.
that you folks are shooting for and what you have achieved so far.
 Al Rabe (to paraphrase) said that when he put more power to his planes(recentally)
Things got better. I took this to mean power to weight per sq.  .in . Forgive me if I misinterpeted
what I read.
This might mean a power to weight ratio , would be another thing I would be interested in
hearing about as well as the above.   S?P  ???  y1
Offline RC Storick
« Reply #23 on: June 22, 2009, 11:49:22 AM »
there is 24.5 oz of fixed weight in mine and the plane is 53.5 what is that around half? 40% somewhere in there?
« Reply #24 on: June 22, 2009, 02:47:12 PM »
Robert, you said you pushed the battery to the back of the box?  Are you joshing me or is there something else I don't understand?
Russell Shaffer
Offline RC Storick
« Reply #25 on: June 22, 2009, 02:58:57 PM »
That was a letter from someone else with a electric plane.
Offline Steven Kientz
« Reply #26 on: June 22, 2009, 05:31:17 PM »
Sparky,
 I believe it is save to say that a balanced light airplane will maneuver with less loss of airspeed, than a heavier plane. I would think that would lead to rounder loops(vs. eggshape because of stall) than the heavier airframe.
The one downside I can think of is the plane "floating" on landing( if the wing loading is too light)
I do think if your building from scratch you should have your powerplant(IC or electric) finalized before you even sketchout the preliminaries. I assume some planes have gained weight and size just for that "killer" finish.I'm sure that several extra ounces are less noticed by a .60 size airframe than a .40.
If you look at combat planes from the 60s and compare them to now you well see the same trend.Probably twice the wing area with a substantial weight gain. Ask H Rush what his Nemesis(13 oz?) weighed versus the fast or speed limit planes of today.
Most of the formulas on lost on me, but if you tie 2 rocks on strings(one heavy, one light) which will change directions easier? My money is on the lighter of the two.
Just a sport flier opinion
Steve Kientz
AMA 855912
« Reply #27 on: June 22, 2009, 06:36:29 PM »
To be honest, I don't really think of wing loading as it is a non factor. A 40 oz object moving at 55 MPH will change direction faster than a 70 oz object. And be easer to control to boot.
Sparky,
You do realize, don't you, that your above statement declares that at 55 MPH a 40oz rat racer with 140 or so square inches of area will turn more sharply than my 72oz, 660 square inch Trivial Pursuit?  Are you sure you want to stick with that???
Ted
Offline RC Storick
« Reply #28 on: June 22, 2009, 06:42:03 PM »
Sparky,
Ted
Apples and oranges. You knew what I meant! Two planes of the same size is that better? Stunt planes are purpose built for stunt, Rat racers are built for Speed. If both planes are of equal size the light one will turn faster and be easer to control.
Offline RC Storick
« Reply #29 on: June 22, 2009, 06:50:15 PM »
Is this statement true? Posted on SSW by Phil
The big elephant in the room, that doesn't apply to free flying racing planes, is the weight, drag, and momentum of the lines. A set of .018 lines weighs about 35 grams, generates about .3lb. of drag(about as much as the plane), takes about .05hp to pull through the air(about 10% of the engine power) and they sail back some 2-3 feet behind the plane. It takes a 4 lb. plane to pull the lines tight enough that the big loop trailing behind the plane doesn't twist the plane out of position on every maneuver. Put the plane into a sharp corner and you can see the lines generate a twisting wave that comes down the lines, reflects at the handle, and goes back out to the plane. One a good day the reflected wave doesn't do much, but as the plane slows down in maneuvers or gets hit by a gust or the pilot doesn't help smooth things out with his hand motion, the waves in the lines can throw the plane out of control. At the very least is makes the plane yaw in and out or roll back and forth.
If you want a really practical demonstration of this, put a set of .018 lines on a 45 oz. Nobler and try to trim it to fly well. You can get it to work, sort of, but the plane is always on the edge of doing something flaky because of the lines whipping around.
Phil C
Here in the Midwest we call them floppers.. Ron has ben trying to get me to build one with no leadouts and the connectors inside the wing. Less drag.
This is one of the things I have been trying to express for a while but lack the finesse to say it.
« Reply #30 on: June 22, 2009, 11:24:01 PM »
Which, of course, is almost precisely the definition of "wing loading".  That (wing loading) is the sum total of everything you've been talking about, Sparky.  Why on earth would you say it is a "non-factor"?
I think a large part of the reason you get so frustrated with contributors to "your" threads is that you are too often imprecise in your language in ways that confound your readers.  I think it is very important to critically read everything one writes several times before punching the "post" or "send" buttons on line.
And, by the way, your sentence in purple above is another example, although not quite as egregious as the 55 MPH object of your previous post, of a comment equally subject to misinterpretation in ways that might make others wince a bit.   Had you said "otherwise identical airplanes" your premise would be reasonable (although, IMHO, not entirely accurate).  "Size" is simply too nebulous a term.  The reason it's too nebulous is because of all those other factors your debaters feel are of significant importance to a good stunt ship.
For instance, a 700 square inch area stunter ("size" in terms of wing loading which is what you're talking about) could be built in an infinite number of varieties.  It could be a classic 5 to one aspect ratio "nobler type" of ship, it could be a flying saucer, or it could be a  long winged 10 to one aspect ratio.  All these ships at the same weight would have the same wing loading.  The manner in which they will perform the pattern would be dramatically different because of the other "factors" that you feel are insignificant.
The 5 to one ship will fly like ... well ... a Nobler.  IOW, pretty darn well.
The 10 to one ship (same wing loading) will be capable of dramatically more rapid pitch changes ... so much so that controlability for precision will be near to impossible in any sort of wind because the airspeed will be changing so rapidly as it maneuvers around the hemisphere (since lift goes up as the square of airspeed) the rate of change of the very quick turns will be constantly changing.  It will also accomplish all of this gyration with a fraction of the thrust necessary for the "nobler" type.
The flying saucer (same wing loading) will produce so much drag in a turn it will require several times more thrust than the long winged ship to simply complete a decent pattern and even then, doing so won't be pretty and it will pretty much "never" turn tight in the classic sense ... although given enough thrust it could almost literally stop and flop sort of like a Bi-Slob.
I don't really care how light you make these different configured ships.  The differences in performance will remain the same.  One pretty darn good and the other two pretty much worthless for precision aerobatics.
There is more to a good stunt design than minimum weight.  That's all those who are debating you are saying.
Ted
Offline RC Storick
« Reply #31 on: June 23, 2009, 05:09:47 AM »
I wish it would go back to impartial type judging Like the NAVY way. Don't tell me it was no good either because the same same group of guys was winning. It at least eliminated the HALO effect and they watched the planes fly and not the pilot. Not to say it was imperfect there was still problems and will always remain problems, subjective judging will always have its flaws. If you say there is no HALO effect you better take humans out of the equation. Not to say I can fly as well as the top guys because I can't, but its not because my plane can't.
I almost made the cut last year with a plane that doesn't fly well at all. Why? Because I got use to it. I have changed programs and it will take me some time to gut use to new running shoes.
I don't know what to write here as its a slippery slope with anything I say. So one again I will let it go and you should too..
« Last Edit: June 23, 2009, 05:41:04 AM by Robert Storick »
« Reply #32 on: June 23, 2009, 09:03:32 AM »
sorry but I dont get where this fits into the discussion of weight Robert?
I agree that there is a significance related to weight, But BALANCE,, as in the right weight, for the design. its all a compromise, just like your selecting a bigger bore motor added weight, but in your "design" you elected to compromise your absolute goal of the lightest plane possible, WHY? because in YOUR design, the benefits of the extra power outweighed the COST of the extra weight.
its ALL ABOUT BALANCING THE DESIGN PARAMETERS not about focusing on one. Ya' gottsta make it all work in a system period,, and as you know, the pilot is part of the system.
Offline RC Storick
« Reply #33 on: June 23, 2009, 09:40:12 AM »
Agreed..
« Reply #34 on: June 23, 2009, 11:43:29 PM »
Offline Dennis Moritz
« Reply #35 on: June 24, 2009, 05:25:14 AM »
Does this mean some designs (or a given example of a design- every build differs) fly better above a minimum weight? (This has been the debate, right.)
Serge's point relates to momentum far as I can tell (I was a bust as a Physics major). Momentum is a function of mass times velocity. We need a minimum amount of momentum for a given airplane to fly well. The momentum of tethered toy planes can be increased by flying faster, weighing more or a combination of the two factors. Which means, I think, that a heavier plane can exert a given amount of momentum flying at a slower speed than a lighter plane. An obvious comparison is a combat plane vs a typical stunt war wagon. The combat plane is virtually useless flying slow (not enough momentum - too light - to stay out on the lines? at least that's part of the problem?) Dan Banjok made that point to me, years ago, when I kept trying to fly sport planes at stunt speeds. Didn't work. Even tho the planes were light. Most sport planes need to fly fairly fast in order to stay out on the lines. If I had increased the weight of those planes, in an effort to fly slower, I would, no doubt, have hit up against the aerodynamics of a typical sport plane. Not enough lift to overcome the extra load.
Offline RC Storick
« Reply #36 on: June 24, 2009, 05:35:24 AM »
Some forget we are tethered. Motor offset,rudder offset and wing asymmetry plus tip weight and line rake.
As stated before its about balance. I am relying on the engine and prop to pull the plane through the maneuvers not momentum. Over head its motor offset to hold it out on the end of the lines.
This is one change on the next Viper. Instead of 1* of engine offset it will be 2*
