  • July 17, 2025, 09:32:55 AM
Author Topic: Weeks of prep down the drain.  (Read 1824 times)
« on: July 17, 2007, 08:23:13 PM »
I don't get a lot of time in the Summer for model building. I have spent weeks cramming in paint prep time on a little Akromaster. I like to use Rustoleum on these small sport models and usually have decent results. I grabbed a can of gloss black from my shelf and a new nozzle and test sprayed on some cardboard. All looked good. BUT, halfway through shooting the plane, the paint started spitting and comming out in irregular patterns. The result is terrible. Major orange peel and thick spots. Gross. I don't have it in me to sand it off and start over for a pukey profile. I guess it's OK from 5ft away.
Totally depressing. :'(
Offline Scott Hartford
Re: Weeks of prep down the drain.
« Reply #1 on: July 17, 2007, 09:25:27 PM »
Just fly it for a month and then wet sand it smooth and lay on one more thin coat! H^^
Offline Warren Leadbeatter
  • AUS-14782
    • My Home Page
« Reply #2 on: July 18, 2007, 05:17:18 AM »
Yep thats what I would do.  It's not so bad.
Warren Leadbeatter
Port Stephens, Australia
AUS-14782
Offline Jim Oliver
« Reply #3 on: July 18, 2007, 07:08:24 AM »
Good advice from Ty.
I usually use my heat gun to warm the can, rather than hot water.
Jim
Jim Oliver
AMA 18475
Offline Phil Coopy
« Reply #4 on: July 18, 2007, 09:21:57 AM »
Over the years I've had this happen so many times with rattle cans that if I have to use paint from one I remove it from the can and use a sprayer.
Phil
Offline Ron Merrill
« Reply #5 on: July 18, 2007, 01:21:59 PM »
TY, thanks for the tip on the hot water. On several paint jobs i encountered spitting, and didn't know why. Thanks Ron. y1
Offline Keith Spriggs
    • khspriggs
« Reply #6 on: July 18, 2007, 01:49:14 PM »
Good tip on warming the can. I did not know that, but it makes sense. One thing that I have learned is that when I have paint left over in the can I turn it upside down as per instructions and blow the paint out. Then I pull off the nozzle and put a drop of lacquer or acetone on top of the pipe that is inside. I drop the nozzle in a jar of lacquer thinner or aceton and swish it around. Pick it out with a pair of needle nose and blow it out with a few pounds of air. Also point the top of the can away and blow out the drop that you put in it. Put the nozzle back on just enough to hold it but not spray any paint. Some cans I have probably used out of 10 or 15 times and they still work just like a fresh can.
Offline taildragger-j3
  • Me over 1/2 century ago with my Ringmaster Jr.
« Reply #7 on: July 18, 2007, 01:55:43 PM »
Boy Keith, those are great suggestions. I've cleaned out the plastic spray nozzle with acetone before, but I didn't think about putting a drop in the part that comes out of the can. I'll have to try that!!!
Thanks!!
David Strawn
Aggieland, TX
AMA - 10212 (original!)
Offline Leo Mehl
« Reply #8 on: July 18, 2007, 08:43:32 PM »
Warming the can on clear Poly-U is a must and lays down more even and cures faster
« Reply #9 on: July 19, 2007, 12:53:56 AM »
I know about warming the paint can. I did this on a 95 degree day and set the can in the sun for about a half hour. I have a bag of new nozzles and had one on the can. I guess it's just one of things that happens and then we deal with it.
Oh, and for Ty, Shake and Paint is my regular routine.
